| Craftsman Lt4000 mild off-roader | |
+5Crazy_Carl RichieRichOverdrive AllisKidD21 CraftsmanQuad19 muckmudd 9 posters |
biggasmowers Veteran Member
| Subject: Re: Craftsman Lt4000 mild off-roader March 28th 2018, 9:11 pm | |
| I did the same thing on a spicer with breaking the spider rod. The second version should be stronger but!!!!! Don't leave it like that !!!! Put some small prices of steel over your welds and weld It up again, as I locked a spicer that way and the gears broke around the welds and blew the case up. If you continue to build it up on each side with more material it will be much stronger with more surface area on the welds and hopefully not break. | |
muckmudd Established Member
Age : 21 Join date : 2017-07-11 Points : 3527 Posts : 825 Location : In the shop
| Subject: Re: Craftsman Lt4000 mild off-roader March 28th 2018, 9:17 pm | |
| Ooops! I guess we'll see. I sealed it up, waited an hour then tightened down the bolts and dropped her back in. I don't think I'm gonna go back until it breaks. I really hope it doesn't break. In 24 hours when the sealer is dry I will take it for a test ride. | |
Age : 24 Join date : 2016-12-30 Points : 4896 Posts : 1944 Location : Kansas
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 12:59 am | |
| Oh is that what you think. Haha I just don't quite send it as often as you do but I break something pretty much every time I go out. Kinda inconvenient to send it when my lot is in the city and it's only 1/4 acre. | |
Crazy_Carl Veteran Member
Age : 35 Join date : 2017-10-30 Points : 5299 Posts : 2561 Location : Rochester, New York
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 7:16 am | |
| There is a way to put the warped axle that you welded in between a couple of centers and use an indicator, a torch, and some compressed air blowing on it to straighten it out again. It's not an easy thing to do but there are some youtube videos about it.
This is exactly why I'm anti locker. Seems like they always break. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 12:14 pm | |
| I would love to see the videos on it. I Agree it's kinda annoying that they break quite often but I just can't live without them. When off road you just get so much more traction in those sticky spots where the un-locked diff couldn't. | |
Age : 22 Join date : 2016-10-29 Points : 7151 Posts : 3986 Location : Lewisburg, KY
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 1:26 pm | |
| Only way I'd weld lock a transaxle without a diff carrier would be to weld the entire spider and axle assembly into one solid piece. It's really the only way to go that's not a doc locker. Fearlessfront style is pretty much guaranteed to fail if you actually use your tractors. I don't understand what people don't get about that. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 2:08 pm | |
| well this time I welded them to the axles too so it should be ok for a while. The doc locker with the solid axle would be ideal if it was cheaper and I could get the parts that I need in town. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 3:04 pm | |
| On the style fearlessfront uses he strictly runs very light tread tires and has a lower hp engine which works for what he does with it, which is mainly driving through slop and not offroading it and twisting the frame or getting the tires wedged in rocks or logs . | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 29th 2018, 5:40 pm | |
| Well I popped the bead on the other front tire today. Quick fix but I guess it kinda shows that I probably romp it somewhat hard. Starting to think that I should bring a spare tire and minimal tools with me. Also, The bottom spindle bushing is mangled up and needs replacing. Where can you get one? | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 30th 2018, 4:19 pm | |
| Does searspartsdirect.com have decent shpping to Canada? It's tough to get cheap parts where you live. I wonder if @AllisKidD21 would have a better idea where to get parts in Canada. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 31st 2018, 12:21 am | |
| Yeah I could do that but they are very thin plastic ones. So I just took one off the lt1000 for now. I went for a ride today again. Lost the belt a few times, went out of a mud pit in a wheelie and the mower fell on top of me. You know, just the usual. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 31st 2018, 12:33 am | |
| ouch lol.
It's better to replace those plastic ones with bronze. I think I had a pop can on mutt's original front axle for a bushing lol. | |
| Subject: Re: Craftsman Lt4000 mild off-roader March 31st 2018, 7:31 am | |
| I'd get some measurements and go from there. Maybe you can find an oil-lite bushing that will be a direct fit. You could always make a delrin one too. | |
| Subject: Re: Craftsman Lt4000 mild off-roader July 10th 2018, 1:35 pm | |
| Well I forgot to mention I did a send a month or so ago, It started squealing and rattling quite bad after I got out of a mud pit. My buddy said the belt was bad because the belt tension was bad at the time, we checked it out but all looked good at first glance so we just rode her home. A month or so went by and I took another look at it today because I wanted to go for a ride with my cousin before he leaves. This wasn't what I was expecting but i'm glad I found out hat it was, now i'm searching for a pulley, I think my parts lt4000 might have one.. | |
| Subject: Re: Craftsman Lt4000 mild off-roader July 11th 2018, 7:59 pm | |
| Nope bearing was fine, I kept it in my bearing collection. I stole the pulley off of the build off because it will need a different clutch system anyways. | |
