 B&S 14hp Twin Fuel-Shut Off Solenoid Bypass
5 posters
JakeTheMudSnake
JakeTheMudSnake
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Empty
PostSubject: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 4th 2017, 5:38 pm
The Fuel-Shut off on my tractor was giving me some problems,
then the terminal snapped off.
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170710
So we decided to bypass it completely. Turns out an old drag link ball joint from an MTD has the same threads as the solenoid.
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170711
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170712
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170713
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170714
Doesn't leak and it runs and starts great!
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170715
PostSubject: Re: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 4th 2017, 7:02 pm
I would've taken a somewire cutters and just cut the needle, but that works too! Nice!
I see your oppy has the voltage regulator rather than a diode, I'm kinda jealous of that lol
PostSubject: Re: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 4th 2017, 9:08 pm
I'd cap off that wire or something to keep that wire from grounding out.  It does have power!  I'd probably get rid of it too!
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Sig115PROJECTS:
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Sig214B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Sig314
PostSubject: Re: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 4th 2017, 9:17 pm
Yeah we wrapped a couple layers of electrical tape around it, its the red wire tucked in behind the voltage regulator.
PostSubject: Re: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 5th 2017, 9:27 am
I got an 04 Troybilt "Super Bronco" with a 21hp v twin. The guy I got it from said it started smoking when he tried to start it... turns out it was that dumb solenoid. Melted the plastic out of the solenoid, melted the plug...
I robbed the bowl bolt from another brigs carb. I think its a 5/16 fine thread bolt.
PostSubject: Re: B&S 14hp Twin Fuel-Shut Off Solenoid Bypass    B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  Icon_minitimeJuly 6th 2017, 5:08 pm
Yeah those solenoids can be a pain.
On another note I think the coil is dying on this engine. If it gets up to operating temperature and is shut off, it will not even try to fire until like a half hour cooling down period.
Had to tow him to the barn when he shut the tractor off up at the house:
B&S 14hp Twin Fuel-Shut Off Solenoid Bypass  20170729
We'll have to see whats up with that.
» Kohler Courage 20 fuel shutoff solenoid bypass
» Electronic Fuel Solenoid - What to do
» How do i wire a fuel shutoff solenoid on a 16.5 OHV motor?
» Fuel solenoid on a b&s intek 20 horse and it will not start.
» Tractor Lockout/ Immobilizer System using Fuel Solenoid.
