| | '66 Sears Engine ID Help | |
TedTheDestroyer Member
![TedTheDestroyer](https://2img.net/u/2812/37/66/46/avatars/2422-6.jpg)
Age : 25 Join date : 2015-11-07 Points : 3338 Posts : 89 Location : Wisconsin
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Lawren Wimberly Established Member
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4731 Posts : 744 Location : Salem Illinois
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | TheBeal Veteran Member
![TheBeal](https://2img.net/u/2812/37/66/46/avatars/967-1.jpg)
Age : 29 Join date : 2013-06-06 Points : 5643 Posts : 1402 Location : Central PA
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | Subject: Re: '66 Sears Engine ID Help March 18th 2017, 8:10 pm | |
| Might be hard to find what your looking for... Check you local small engine shops, they might have some old Tec stuff still... otherwise ebay might have to be your friend.
If it comes down to it, you could make a gasket out of a piece of copper(?) | |
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | Subject: Re: '66 Sears Engine ID Help March 18th 2017, 8:39 pm | |
| I've seen head gaskets made out of leather... the old indian motorcycles used leather head gaskets
| ![Go down](https://2img.net/i/empty.gif) | | TedTheDestroyer Member
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | Subject: Re: '66 Sears Engine ID Help March 18th 2017, 11:21 pm | |
| Well I found the gasket on sears parts direct, who also gives the part number for partstree.com. The only problem with that is that sears uses that stupid 143 number instead of the actual model number. After looking at some diagrams it kinda looks like a H60, Especially since it doesn't have a primer that I saw on the HSK40s. | |
| ![Go down](https://2img.net/i/empty.gif) | | mr.modified Veteran Member
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | Subject: Re: '66 Sears Engine ID Help March 19th 2017, 12:09 am | |
| Looks like tecumseh to me. I've heard sears had some engines made special for them with odd sizes in certain things, so that you would have to order replacement parts from them. Not sure how true that is, but seems possible if they have a special number on their engines made for their tractors. That looks like the original engine to me, or at least, same model that it came with.
Is the gasket big bucks? Could give it a try. | |
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | Subject: Re: '66 Sears Engine ID Help March 19th 2017, 12:15 am | |
| - mr.modified wrote:
- Is the gasket big bucks? Could give it a try.
It's like $7, $14 after shipping so i'll give it a try. It should fix the "leakage" i'm having. | |
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Sponsored content
!['66 Sears Engine ID Help Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | '66 Sears Engine ID Help | |
| Who is online? | In total there are 109 users online :: 0 Registered, 0 Hidden and 109 Guests
