 The 18hp Yard-Man Trailmower
DiezelFuel
Mudgutz_Customs
Hillbilly Homer
TheGreenHornet
sadeoo7
19 posters
The 18hp Yard-Man Trailmower  - Page 2 Empty
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 5:35 pm
Well for that style carb the high throttle mixture screw is on the bottom of the float bowl. If is running a wee bit rich you wanna turn it in like youre tightening it. Just a little bit though, too much and it will be running too lean. Also when you adjust the high idle screw you should rev the engine a few times to see if it will still rev up smoothly, and run it at WOT to see if it is misfiring or having trouble running. Just a slight adjustment should necessary to fix the smoke problem. That is if its fuel smoke.
TheGreenHornet
TheGreenHornet
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 7:48 pm
If its bluish, you probably have some oil burning problems. or it could be your PCV breather. the actual plate thingamajigger. ive had to replace one of those before and it was the same symptoms you are experiencing. For you it seems like it could stand for some adjusting though. ya really just gotta play with the screw and find what works best. i know i spent 3 hours trying to find the sweet spot on the 12 horse on CQs simplicity.
Does the engine have good compression?
Spark plug covered in carbon/ oil/ other debris?
If your spark plug is really grody, your combustion chamber is probably the same way, along with the valves and the ports. i would recommend starting with adjusting the carb, check the pcv breather, check the spark plug, take off your carb and muffler and check the ports, and if the plug and ports are nasty, take your head off and wire wheel it with a dremel and maybe even do some porting with the dremel. Do it in that order too. i always check the little and easy stuff before i dive into ripping the head off lol
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 8:01 pm
Yeah I agree with TheGreenHornet about the oil problems. If is it the oil burning it could be the PCV, sometimes you can soak them in gas for a while and it kinda cleans them out and what not. But I would try adjusting the high throttle screw first because it sounds like fuel smoke to me.
TheGreenHornet
TheGreenHornet
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 8:28 pm
cool. i didnt know you could soak em in gas. i just keep a whole bunch of spares around. i probably have 15 of those little suckers, all different sizes from engines ive thrown out over the years. they dont die like that very often. at least they havent for me.
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 9:12 pm
Usually you can tell by the smell. If its gas it will smell like a mix of carbon and fuel.
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 2nd 2016, 9:21 pm
Yeah I did that to the one on the MTD because the reed was kinda stuck and it wasn't working properly. I just soaked 'er in some gasoline and it cured it!
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 3rd 2016, 9:27 am
Those B&S Flatheads always smoke a wee bit. It's just part of their character Wink I have a fairly new I/C Quiet 12.5hp (2001 I think) and it smokes a bit when you let the throttle off.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 3rd 2016, 7:29 pm
yep adjusting the carb seems to have made it much better and the spark plug is clean and the oil level never dropped so i think its gas related. it also has good compression. ill finish adjusting the carb because its dark and it was hard to seet he smoke.
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 3rd 2016, 7:49 pm
It wont burn oil that fast, just a little will blacken exhaust.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 4th 2016, 12:59 am
oh ok
ill check the pcv thing tommorow cuz it still smokes...
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 4th 2016, 9:20 am
Yeah well if the spark plug is clean then it probably isn't burning oil. Seeing as it isn't the original carb for the engine, it probably is still out of adjustment. Btw, are you sure there isn't oil in the gas? That causes bluish black smoke.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 4th 2016, 8:19 pm
no theres no oil in the gas when i hoocked up the gas tank it was empty and i filled it up with fresh gas. i havent had time to check the pcv but ill do that tommorow.
http://gdftech.com
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 5th 2016, 10:22 pm
u had al;ot of fun with this thing today, but i really need to get my straith axle to lock it, i do want to put a bigger pulley on the engine. maybe this week ill get a 7 in for the front.
firt and second gear a pretty much useless.
The 18hp Yard-Man Trailmower  - Page 2 Imag0126
The 18hp Yard-Man Trailmower  - Page 2 Imag0127The 18hp Yard-Man Trailmower  - Page 2 Imag0128
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 6th 2016, 1:12 pm
What size is on the front at the moment? I plan on running a 5 1/2 on the front and a 4" rear on my Westwood. Hoping for about 20mph.
Also, how well does the brake lever work?
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 6th 2016, 5:39 pm
at this time im running a 1:1 setup 6inch frond an rear it does a little less than 20 mph.
i want to put a 7inch in the front and keep the 6 in the rear to get a little more speed.
the brake lever work very well i still havent done the spring return but it works very well, you do have to pull it hard to lock the rear wheels but its possible.
hopefully this week im to be able to order the parts to lock my trans but im not sure, also i may go on a romp this weekend ill see.
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 7th 2016, 11:49 am
Ah right. The reason the braking power is not that strong is probably because the pads are worn. How are you planning on locking the trans?
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 7th 2016, 11:50 am
doc locking style, straight axle.
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 7th 2016, 12:17 pm
Nice. Gonna get new tires?
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 7th 2016, 12:39 pm
maybe when ill have the money. probably used but idk yet.
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 8th 2016, 10:12 am
I got them pretty cheap from Wal-Mart's online store. Duro 22x11-8 knobbies. There were others, but these were what I liked and they were $40 each
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 8th 2016, 1:42 pm
Could be a leverage issue too. I had similar issues when I had a dash set up.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 8th 2016, 5:13 pm
i think something is binding in my brake linkage because i can feel a ''clunk'' when i pull it hard enought and the it lock the wheels, ill have to check that but hey it works so its good enought for now. ill have to take the trans out soon so ill fix that then.
http://gdftech.com
TheGreenHornet
TheGreenHornet
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 9th 2016, 9:54 am
something binding or it might be catching on something. id check that out. Im sure you dont want any unnecessary wear on the brakes, since they are kinda important.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 9th 2016, 11:38 am
ya brakes are important. especially when you go fast haha, no its not catching on anything. ill check that soon for sure tho.
http://gdftech.com
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 9th 2016, 11:46 am
It could be binding where the linkage meets the arm, either on the brake/trans or your lever.
sadeoo7
sadeoo7
PostSubject: Re: The 18hp Yard-Man Trailmower    The 18hp Yard-Man Trailmower  - Page 2 Icon_minitimeDecember 12th 2016, 11:49 pm
i got the transaxle out today. ill lock it probably fozzy lock for now. until i get the money to get a straight axle. i also want to convert my trans from grease filled to oilfilled. ill post pictures tommorow. tommorow i need to clean up the inside of the trans i checked all the bearing and the bushing and they seem good. but theres water inside the trans.
http://gdftech.com
Page 2 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
» yard pro gt
» 95' yard pro gtk 20
» MTD Yard Machine Build
» Yard Machines MTD Build
» MTD Mud Mower "Yard Machines"
