| 95' yard pro gtk 20 | |
+4mrshaft696 MatthewD Crazy_Carl Dhl mudmowers 8 posters |
Dhl mudmowers New Member
| Subject: 95' yard pro gtk 20 September 30th 2018, 2:49 am | |
| Ok so just bough a 95'yard pro 20hp. I am super stoked because it's got the beefed up 633a. It was missing the 20hp Kohler magnum 20hp so I got it cheap. The 633a that was in it had blown the first and reverse gear out. Probably some idiot that didn't know how to drive. And since those perticular gears are about as easy to find as dinosaur bones I bought a mother transaxle. It now runs strong with my 16.5 pressure lube oppie. Any ways enough rambling here it is | |
Crazy_Carl Veteran Member
| Subject: Re: 95' yard pro gtk 20 September 30th 2018, 5:06 am | |
| The hood on that thing looks humongous! So this machine has the belt twist and a pan frame. Nice job sourcing some used parts. so what are your plans for the machine? | |
| Subject: Re: 95' yard pro gtk 20 September 30th 2018, 2:51 pm | |
| Thinking about making it a utility trail machine as well as a mudder. The main thing is having everything you need on one tractor. | |
| Subject: Re: 95' yard pro gtk 20 September 30th 2018, 3:42 pm | |
| That’s really hard to have it all in one rig but I think you can meet all of your needs in one. | |
MatthewD Veteran Member
mrshaft696 Established Member
Join date : 2016-07-10 Points : 4060 Posts : 870 Location : Phillydelphia
| Subject: Re: 95' yard pro gtk 20 December 8th 2018, 10:01 pm | |
| pretty cool machine, I have never seen one, who are they made by? | |
| Subject: Re: 95' yard pro gtk 20 December 8th 2018, 10:28 pm | |
| I'm assuming they're made but AYP, same frames as the GT 6000 Craftsman's.
Neat looking tires! What brand and model are they? They sorta look like mini rock crawler tires
"This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 49 Join date : 2016-09-06 Points : 15677 Posts : 10988 Location : Oklahoma
| Subject: Re: 95' yard pro gtk 20 December 8th 2018, 10:40 pm | |
| Man, I could use a set of those on one of my tractors! Carlisle Versa Trail? | |
| Subject: Re: 95' yard pro gtk 20 December 9th 2018, 9:47 pm | |
| Indeed they are! Just got the other mounted. Can't wait to test them! | |
| Subject: Re: 95' yard pro gtk 20 January 21st 2019, 2:09 am | |
| Update! Ok so I just bought a predator 301cc and due to the chassis being assembled for the vertical kohler that was on it the clutch puts the belt right in the way of the deck raise lever. I mention this because on these ayp GTs the steering box is cut out around it. Would it be ok if I cut out the lever assembly? I have a welder and angle iron to support the steering box if needed. | |
| Subject: Re: 95' yard pro gtk 20 January 21st 2019, 11:16 am | |
| Without seeing a picture it's hard to say for certain. I think you're saying that the deck raise assembly somehow supports the steering box? We here at ATLTF to fully endorse cutting things, modifying them, and reinforcing with angle iron however. | |
Age : 24 Join date : 2016-04-12 Points : 5982 Posts : 2645 Location : Indiana
| Subject: Re: 95' yard pro gtk 20 January 22nd 2019, 11:56 pm | |
| Ok so the deck lever and rod are removed.steering seems fine albeit I will still reinforce it later.The 10hp HEMI 301cc runs well so no complaints yet.We will we how she goes. | |
| Subject: Re: 95' yard pro gtk 20 January 23rd 2019, 7:14 am | |
| Pictures please! I'd like to see this motor and steering setup. | |
| Subject: Re: 95' yard pro gtk 20 February 14th 2019, 11:25 pm | |
| Anybody know about how fast a 1 to 1 pulley swap is on a 633a? My tires are 25s | |
| Subject: Re: 95' yard pro gtk 20 February 14th 2019, 11:42 pm | |
| Sorry for not getting back to this sooner but the bar I have marked white is the one that I cut. | |
| Subject: Re: 95' yard pro gtk 20 February 15th 2019, 7:15 am | |
| my guess is about 10 miles an hour. I need to know the gear ratio in the trans in high gear and I can run the math for you. | |
Age : 20 Join date : 2017-06-09 Points : 5493 Posts : 2640 Location : Literally Nowhere, Texas
| Subject: Re: 95' yard pro gtk 20 February 15th 2019, 12:14 pm | |
| - Dhl mudmowers wrote:
- The 10hp HEMI 301cc runs well so no complaints yet. We will we how she goes.
The 301 is actually 8 HP, not 10. Predators are nice engines though, she'll last you a good long while! I'm guessing, that with a 1-1, and an 8 hp single, probably about 12, because a single cyl small engine won't be able to turn at much more than 3000 RPM or so with those tires and a 1-1 ratio. | |
| Subject: Re: 95' yard pro gtk 20 February 15th 2019, 1:01 pm | |
| I got 23MPH with a 9 inch engine and stock pulley on one of those transaxles. | |
