| MTD off-road build (Mobile Terrain Dominator) "1" | |
+21Mow Money Mods muckmudd DiezelFuel Lawren Wimberly jfsjr92 TheBeal Mikethepigman EastCoastVinylWerkz prancstaman Mudgutz_Customs sadeoo7 1997 Murray RichieRichOverdrive Rockinator MightyRaze TheGreenHornet mr.modified AllisKidD21 Doug MatthewD CraftsmanQuad19 25 posters | |
| | | | AllisKidD21 Moderator
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 2nd 2017, 10:21 pm | |
| Yeah, we got just enough to have some fun for a couple hours. The ground could use more though, it's still very dry. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5717 Posts : 1402 Location : Central PA
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 4th 2017, 2:43 pm | |
| Hahaha, thanks Beal! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 4th 2017, 4:49 pm | |
| If you fint its getting too dirty too soon, it wouldnt take much to make a big "box" around it that conforms to the underside of the hood. Still plenty of flow and should help keep it cleaner, longer.
I might have to build a similar air cleaner... lol | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 4th 2017, 6:57 pm | |
| Yeah I thought about that as well, could even mount it directly to the hood so when I open the hood the box goes up with it. Probably not a bad idea, I'll probably keep that in mind. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 5th 2017, 10:23 pm | |
| Well I think the solenoid died on this ol' girl today. I went to start it and when I turned the key nothing happened at all. If you turn the key to "start" and hold it for about 5 seconds the solenoid clicks once, but thats it. The weird part is if you put the battery charger on the battery it cranks over just fine, even on 2 amp. But it stops working if you turn the charger off. I dont think it's a problem with the battery because its been working great lately. Hmm, I'll put a different solenoid on 'er sometime and if that works I'll just buy a new one. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | DiezelFuel New Member
Age : 27 Join date : 2017-07-28 Points : 2705 Posts : 22 Location : Michigan
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 6th 2017, 9:05 am | |
| Nice build, I like that air filter. Double check your ground wire from the battery, I had a similar problem on my huskee and it was just my ground wire where it bolted to the frame had wiggled loose and got rusty. | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 6th 2017, 9:27 am | |
| HAHA.... that's 2 of us now. - Chat Log wrote:
[22:08:33 05/08/2017] @ mightyraze : Hola! [22:08:38 05/08/2017] AllisKidD21 : Hey mighty! [22:08:43 05/08/2017] AllisKidD21 : Whats up? [22:09:09 05/08/2017] @ mightyraze : so you think your solonoid is going out? [22:09:24 05/08/2017] @ mightyraze : not much, getting ready for a long day tomorrow [22:09:25 05/08/2017] AllisKidD21 : Yeah, seems like she bit the dust [22:09:32 05/08/2017] AllisKidD21 : Yeah? [22:09:50 05/08/2017] @ mightyraze : but it works with the charger on? [22:10:08 05/08/2017] AllisKidD21 : Yep, thats weird to me [22:10:20 05/08/2017] @ mightyraze : grounding issue? [22:11:05 05/08/2017] AllisKidD21 : Im not sure, I suppose the solenoid couldve vibrated loose a little bit [22:11:26 05/08/2017] AllisKidD21 : But I had started it a couple times before it acted up [22:12:14 05/08/2017] @ mightyraze : yeah check your ground on the batt, and if that is OK, throw a linge between the base of solenoid to the block. unless it is a 4 prong, the ground prong. see what happens. [22:12:30 05/08/2017] @ mightyraze : *line not linge [22:13:19 05/08/2017] AllisKidD21 : Yeah its not a four prong, maybe I'll check to see if the mounting bolts backed off a bit and messed up the grounding.
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 6th 2017, 10:42 am | |
| - DiezelFuel wrote:
- Nice build, I like that air filter. Double check your ground wire from the battery, I had a similar problem on my huskee and it was just my ground wire where it bolted to the frame had wiggled loose and got rusty.
Thanks! Yeah I should probably check that. I'm not sure if thats the cause or not because it never acted up before, just all of a sudden. But it wouldnt hurt to check haha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 6th 2017, 12:13 pm | |
| Anytime man. If you can jump start it with positive to battery side of solenoid and ground to your frame or block and it works then its a bad ground. I wish i would have checked that first lol it took me a good hour to think of the ground. | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 6th 2017, 1:43 pm | |
| Yeah I'll probably check the solenoid ground and the battery ground next time I'm out at the farm. I've taken the fenders off of the ol' girl so many times its not very hard for me to do it now hahaha "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 13th 2017, 12:28 am | |
| I had the fenders off today trying to diagnose my problem. The ground cable lugs where a bit lose but the cable wasnt corroded or anything, so I just smacked the ends with a little hammer to tighten them up and put some electrical tape around the exposed ends of the cable. Everything was fine but I eventually noticed that the cable and lug on the battery side of the positive cable was very corroded. I suspected to be the cause of the problem so I cleaned it up real good, put it all back together and it worked great! I was also able to check on the undercoating I put on underneath my fenders. It appears to be in good shape still which is nice to know! I'm glad I got 'er running again because I needed an easy way to move the steel roofing I needed for the little lean-to thing I was adding to the back of my crappy shed hahaha. Glad I got that all figured out! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Age : 57 Join date : 2013-12-21 Points : 4805 Posts : 744 Location : Salem Illinois
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 13th 2017, 12:56 am | |
| Hell yeah!! Haha, I also had to rip an old railroad tie outta the ground cause it was half buried and it was in the way. It's alot more fun to use a tractor than it is to do it by hand! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 13th 2017, 10:04 am | |
| - AllisKidD21 wrote:
- Hell yeah!! Haha, I also had to rip an old railroad tie outta the ground cause it was half buried and it was in the way. It's alot more fun to use a tractor than it is to do it by hand!
That is the truth! | |
| | | MatthewD Veteran Member
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 13th 2017, 7:35 pm | |
| Yeah it was nice to be able to use 'er again. More space is always great, hahaha. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 20th 2017, 12:19 pm | |
| Hey all, I think I'm gonna try and start painting the ol' Dominator today. I think... haha we'll see, its been a long time coming. I'm probably just gonna do like the hood and the front end of the frame and bumper. Hopefully it turns out hahaha, stay tuned! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 20th 2017, 6:52 pm | |
| Well I actually got some painting done today! Just my hood and bumper like I planned, but it's a start. I got the hood off, wire wheeled it, and primed it. Then I laid down a nice coat of red. Cleaned up the bumper a bit as well. And here she is! Like I said its a start hahaha. I put the fenders in my car to bring them home and paint them as well so they match the hood. I think it turned out pretty nice so far though so I'm excited to see how it looks with the fenders all painted to match. Let me know what ya think! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| | | muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3561 Posts : 825 Location : In the shop
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 20th 2017, 11:40 pm | |
| Thanks! The hood is steel but the grille is plastic. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 21st 2017, 12:13 am | |
| That looks great Allis! Gonna look like a whole new tractor when you are done! You know, while the back is off. Man it would be so easy to pulley swap. LOL, just yanking your chain. | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 21st 2017, 12:22 am | |
| Thanks mighty, thats the hope anyway hahaha. I cant see a pulley swap being done to this ol' girl any time soon. Maybe a mildly larger engine pulley, but its not really a priority. I wouldnt wanna leave the Jake any further behind than I already do! Hahaha! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Subject: Re: MTD off-road build (Mobile Terrain Dominator) "1" August 21st 2017, 12:30 pm | |
| I tried priming my fenders last night but I started running out so I couldnt really get the whole thing done properly. I just got the important spots and tried my best with the rest of it, I'm just gonna go ahead and paint it anyway hahaha. Should be okay. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 44 users online :: 1 Registered, 0 Hidden and 43 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
