| 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] | |
+8TheBeal AllisKidD21 CraftsmanQuad19 Rockinator sadeoo7 mr.modified MatthewD 1997 Murray 12 posters |
MatthewD Veteran Member
Age : 24 Join date : 2016-04-12 Points : 5977 Posts : 2645 Location : Indiana
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5442 Posts : 1311 Location : NW USA
Age : 25 Join date : 2016-07-10 Points : 8583 Posts : 5190 Location : Ontario Canada
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 7th 2016, 7:32 pm | |
| Man, that thing is sweet! I like the idea of a diesel in a Craftsman. You should use a choke knob to pull the throttle closed when you wanna kill it, it would be like an old diesel tractor! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100
Last edited by AllisKidD21 on July 25th 2017, 10:19 pm; edited 1 time in total | |
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 7th 2016, 8:42 pm | |
| Thanks guys, yeah I love it, I finally got the injector overflow line plumbed and the idle adjusted so it will idle. Took it for a cruse in the woods, runs real nice. I also put belt retainers on so the belt declutches and good stuff like that. I will have to work on paint soon. My brother wants to be a painter when hes old enough to work so it will give him some practice. | |
TheBeal Veteran Member
Age : 30 Join date : 2013-06-06 Points : 5713 Posts : 1402 Location : Central PA
Age : 23 Join date : 2014-11-16 Points : 5749 Posts : 1993 Location : Northern Ireland
Tractorhead Member
2016 Build-Off Finalist
Join date : 2016-07-10 Points : 3142 Posts : 75 Location : England
prancstaman Veteran Member
Join date : 2015-02-02 Points : 5092 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 9th 2016, 8:54 pm | |
| ^^Filter out the bacon bits. I know a few people around here run %100 in their trucks. Its thicker than diesel, so it doesnt work so well when its cold. Might be wise to keep an extra fuel filter on the rig too. {EDIT} I dont know how it would work on this engine, it may take some experimentation. My brother runs veggie oil in his kubota diesel. | |
Tractorhead Member
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 10th 2016, 5:38 am | |
| - 1997 Murray wrote:
- yeah maybe your timing is too advanced.
Aha hadn't thought of that, I just assumed my engine was worn. How do i adjust the timing? Shims behind the pump mount?? Yikes... research needed... Cooking Oil, heating oil etc?? I've known so many people try to save money that way and it never ends well. Lots of snotted up tanks, blockages, poor running, breakdowns etc e.g. I sold a VW Jetta diesel to a friend who ran it on cooking oil, never had a problem on local trips other than black oily soil on the rear panels, but on a long trip it totally destroyed itself stranding him 200 miles from home. Just not enough lubricants and detergents. He wishes he had stuck to forecourt diesel. You can add 2stroke oil but that pushes the price back up. These tiny tractor engines use so little diesel anyway. Sorry guys, it ain't worth it. Just Say No | |
Tractorhead Member
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 10th 2016, 10:06 am | |
| Ive heard of people running a 70/30 mix of diesel and filtered used motor oil in their yanmar clone generators without problems. 70 percent diesel btw. 30 is the filtered oil. I'm not sur what a good ratio is for cooking oil. Maybe 80/20 since its so thick? | |
| Subject: Re: 1997 Murray's DIESEL Craft Quad II [2016 Build-Off Entry] September 10th 2016, 7:29 pm | |
| - prancstaman wrote:
- How would you feed that veggie oil to the motor? Do you just put it in the tank?
I think you filter it threw a 2 micron filter and pour it in the tank. mix with a little diesel to thin it out in the winter. Yeah used motor oil is a bit risky. | |
Off Road Domination Member
Age : 22 Join date : 2016-02-17 Points : 3278 Posts : 74
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6372 Posts : 899 Location : PA pittsburgh and pymatuning
