| 1984 SimpleQuad 6220 [2016 Build-Off Entry] | |
+5MatthewD MasonMcK Rockinator steeldaytonas 1997 Murray 9 posters |
1997 Murray Veteran Member
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5750 Posts : 1993 Location : Northern Ireland
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Thu 25 Feb 2016, 1:01 pm | |
| Yeah I am lifting it. The rear I'm leaving, and I'll settle for the frame stance for now, I could lift the frame off the factory mounts, I may end up doing that. I have to figure out steering, I want to do direct steering with handlebars, and a long seat like a big atv. | |
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Wed 16 Mar 2016, 11:37 am | |
| Looks like a gasser. I might have missed it, but how did you adapt those wheels on? On my old simplicity trans I just have the bolts through the axle to hold on the rims. Is that what you have too or do your axles have key ways? | |
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Wed 16 Mar 2016, 2:10 pm | |
| This one has 1" shafts with a1/4" key with a c clip to hold the hubs on. I got these tires off a ford LTD, they are snow tires, and they have a 4.5" pattern, which is the same as the stock hubs. I have 5 on 4.5" hub pattern.
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Mon 21 Mar 2016, 7:39 pm | |
| I got it up and running, and driving under its own power. I need to build a better clutch though, mine is next to the transaxle and I want one by the engine. I'm also going to go return my 4" TSC pulley, it was a 3/4 bore instead of 5/8 like the shaft. I used a 3.5" pulley I had off an old mower but the belt slipped around it too much. | |
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Tue 22 Mar 2016, 10:19 am | |
- 45mph? i wouldnt go near that on mine even, be careful
Yeah i'm thinking now more like 30 or so, especially since its so tall now. | |
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Wed 23 Mar 2016, 9:51 pm | |
| Well I got a belt on her, and took it for a drive. I didn't dare open the throttle all the way in 3rd. I need to hook up my breaks and my foot/hand throttle, the lever in the dash isn't safe at all. | |
| Subject: Re: 1984 SimpleQuad 6220 [2016 Build-Off Entry] Sun 27 Mar 2016, 5:17 pm | |
| - MatthewD wrote:
- Yeah 40mph is a bit much! Especially as she is so high. You could maybe lower the front to even out the stance by lifting the shocks up a bit.
Thats what i was thinking. Some shock hoops would improve handling and the looks for sure | |
Braden.H Member
Join date : 2016-03-29 Points : 3213 Posts : 48 Location : Indiana
| Subject: AWSOME FREAK IN MOWER Wed 30 Mar 2016, 3:59 pm | |
| I just have to say that is a awesome freak in mower cant wait to see how it turns out. You will have to let me know
-BD | |
