| Belt coming off | |
MatthewD Veteran Member
| Subject: Belt coming off October 10th 2015, 4:10 pm | |
| Hi, I have done a pulley swap to my Westwood but the belt keeps on falling off even when the belt is really tight and I have belt retainers on. It isn't twisted. It comes off the rear pulley and sometimes it falls off the front one too.
What is happening?
1997 Murray Veteran Member
| Subject: Re: Belt coming off October 11th 2015, 12:16 am | |
| your pulleys may be misaligned. I.E the rear pulley is mounted higher than the engine pulley or vise-versa. | |
| Subject: Re: Belt coming off October 12th 2015, 1:25 pm | |
| No they are all fairly well aligned. It's really baffling me | |
| Subject: Re: Belt coming off October 12th 2015, 2:30 pm | |
| I had a lot of trouble with my simplicity. Maybe redesign the retainers some. Or add something under the edge of the belt to keep it from flopping around with the clutch in. Assuming vertical shaft setup of course. | |
| Subject: Re: Belt coming off October 12th 2015, 3:16 pm | |
| The engine pulley has quite a deep grove and only one belt retainer and it hardly ever comes off. The rear transmission pulley has quite a shallow grove and 2 belt retainers and it always comes off. It is a vertical setup.
How far out would the pulleys have to be to cause problems? | |
| Subject: Re: Belt coming off October 14th 2015, 5:09 pm | |
| Been researching and found out that a worn belt could cause it to come off. Would this be the case? | |
| Subject: Re: Belt coming off October 14th 2015, 7:44 pm | |
| Could be I guess. Belt probably a bit looser when worn and maybe stretched a bit. Then when you push the clutch in, flops around a lot more and jumps over the pulley. | |
| Subject: Re: Belt coming off October 15th 2015, 12:23 pm | |
| Yeah. So I tried another belt that was the same size and it helped but didn't stay on forever.
But now the whole belt system is locked up, I dont know what is happening | |
| Subject: Re: Belt coming off October 15th 2015, 2:07 pm | |
| Found the problem. The "upper end" of the gear box has seized. The diff is still working. | |
| Subject: Re: Belt coming off October 15th 2015, 2:38 pm | |
| hope you can fix the trans, at least the case hasn't snapped. | |
| Subject: Re: Belt coming off October 15th 2015, 3:53 pm | |
| Yeah. I think it was running on no lubricant. What do you think would have seized? | |
donaldcon Member
Age : 38 Join date : 2015-04-28 Points : 3961 Posts : 401 Location : Roseville, OH
| Subject: Re: Belt coming off October 15th 2015, 5:19 pm | |
| Don't think there are any bearings in a Peerless 801? | |
donaldcon Member
donaldcon Member
| Subject: Re: Belt coming off October 15th 2015, 8:50 pm | |
| With no lubricationanywhere there are bushings, bearings or gears rubbing one another can seize | |
| Subject: Re: Belt coming off October 16th 2015, 2:52 pm | |
| Not good to run with no lubricant. Bad things happen. Gears can get hot and melt together, bushings cans seize fast to shafts (especially steel bushings in cheaper trans axles), or bearings can seize. It's like trying to drive your car with no oil in the engine, like I said, bad things will happen. | |
| Subject: Re: Belt coming off October 17th 2015, 5:21 am | |
| Just found out that it isn't seized, a nut was stuck in the pulley?? Im gonna check the trans anyway when I have it out | |
| Subject: Re: Belt coming off October 18th 2015, 2:16 pm | |
| Oh good, no damaged bushings then. Where was the nut? Between the belt and pulley?
| Subject: Re: Belt coming off October 18th 2015, 4:00 pm | |
| Jammed between the spokes of the pulley and the supporting fins of the input shaft. Really not sure how it got there | |
| Belt coming off | |
