 Rewiring a kohler cv14s
2 posters
Torotorquehorse
Rewiring a kohler cv14s Empty
PostSubject: Rewiring a kohler cv14s   Rewiring a kohler cv14s Icon_minitimeAugust 4th 2015, 11:07 pm
I removed all the wiring and have got this setup so far I have a 4 post solenoid on the two big posts I have the positive battery cable hooked up and on the other side is the starter cable. On the two small posts one is a ground and the other one goes up to the key switch. As of right now it starts great but I don't have the charging system hooked up could I just simply take the hot wire from charging cool and connect it to the same solenoid post as the battery and then backfeed power into the battery and charge it up? I have never wired anything in my life so getting it to start was a bug achievement so any help is appreciated
PostSubject: Re: Rewiring a kohler cv14s   Rewiring a kohler cv14s Icon_minitimeAugust 12th 2015, 11:19 am
Assuming the wire in question is the charging circuit, yes, it is perfectly acceptable to connect it to the battery post on the solenoid.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
» How do you know what wire is what when rewiring a tractor?
» 92craftsman II 19 opposed twin rewiring using factory key
» Rewiring 15hp Cast Iron Briggs With Starter Generator
» 15 hp kohler
» "Kohler Afficionados"
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Wiring Systems-
