 Rewiring 15hp Cast Iron Briggs With Starter Generator
2 posters
Hillbilly Offroading
2019 Build-Off Entrant
1st Place Build-Off 2020
Rewiring 15hp Cast Iron Briggs With Starter Generator  Empty
PostSubject: Rewiring 15hp Cast Iron Briggs With Starter Generator    Rewiring 15hp Cast Iron Briggs With Starter Generator  Icon_minitimeApril 22nd 2020, 10:55 pm
Howdy fellas I'm trying to rewire my '72 15hp cast iron briggs. Unlike the usual starters this has a starter generator and regulator. I'm dumb founded. I'm wanting to get rid of the points and use a new coil. Also wire it up where it uses a push button start and kill switch unless theres a way to use the original key switch. Any help with rewiring it be very helpful. I think this is the correct wiring diagram.
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen12
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen13
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen11
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen15
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen14
PostSubject: Re: Rewiring 15hp Cast Iron Briggs With Starter Generator    Rewiring 15hp Cast Iron Briggs With Starter Generator  Icon_minitimeApril 23rd 2020, 6:44 am
If you get a heavy duty momentary switch for use with cables, you could do a push buttom starting system. You would just need to run a cable from the postive battery post to the switch, then from the switch to the A (Armature) terminal on the s/g.
The voltage regulator is easy too, the F (Field) terminal gets wired to the Field post on the generator, and the Gen post goes to the Armature post on the generator. Some regulators have a ground terminal, but yours may not if it grounds through the mounts. Just be sure to check that out.
Then to get the charging back to the battery, a wire from the Bat terminal on the regulator goes to the hot side of the starter switch. This is also where you would put a fuse and an amp gauge if you were using one.
Here's a diagram to make it a little easier:
Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen26
One more thing.. if your regulator has an L (Load) terminal, that is where accessories such and lights would be run from. If there is a Load terminal and you will not be using it, be sure to tape it off with electrical tape.
PostSubject: Re: Rewiring 15hp Cast Iron Briggs With Starter Generator    Rewiring 15hp Cast Iron Briggs With Starter Generator  Icon_minitimeApril 23rd 2020, 12:02 pm
@AllisKidD21 that sure is basic. No starter solenoid needed? All I would need to do is wire the coil to a kill switch right? This is the start switch you talking about? Rewiring 15hp Cast Iron Briggs With Starter Generator  Screen16
PostSubject: Re: Rewiring 15hp Cast Iron Briggs With Starter Generator    Rewiring 15hp Cast Iron Briggs With Starter Generator  Icon_minitimeApril 23rd 2020, 12:21 pm
Well actually you could use a starter solenoid along with a switch like the one you posted. Just run the battery to the solenoid and wire that part up like usual.
PostSubject: Re: Rewiring 15hp Cast Iron Briggs With Starter Generator    Rewiring 15hp Cast Iron Briggs With Starter Generator  Icon_minitimeApril 23rd 2020, 1:15 pm
@AllisKidD21 thank you very much. I'll place a order for the carb and base gasket this evening.
» Almost all cast iron Toro
» Cast iron axles
» Steel or cast iron sleeve and where can i get that done
» Kohler 12.5hp cast iron block rebuild
» Murray widebody forged cast iron axle swap
All-Terrain Lawn Tractor Forum :: Technical Forum :: Electrical Related Issues :: Wiring Systems-
