 Stiff peerless 5 speed 801-038B
2 posters
mzeng100
mzeng100
Stiff peerless 5 speed 801-038B Empty
PostSubject: Stiff peerless 5 speed 801-038B   Stiff peerless 5 speed 801-038B Icon_minitimeJune 10th 2015, 10:32 am
I've got a tecumseh peerless 5 speed and the input shaft is very stiff to rotate. I have had it apart and all the bushings are seated correctly. The whole transaxle is in good condition and so it seems strange that it is so stiff. The motor does drive it but is there is some belt slippage due to the power needed to drive the input shaft. I had one of these transaxles before with a similar problem. Does anyone know why it may be like this?
PostSubject: Re: Stiff peerless 5 speed 801-038B   Stiff peerless 5 speed 801-038B Icon_minitimeJune 10th 2015, 5:05 pm
Mine was brand new and is like that, all how they are geared i guess.
» Peerless 633 3 speed hi low. low not working
» Low Speed Tractor w/ Peerless 820 + Automatic Transmission Fluid = ?
» 820-037 Peerless Manual shift 5-speed Dimensions and Mounting holes location.
» peerless 915 015
