| 68 suburban 10 | |
+23RichieRichOverdrive AllisKidD21 Dustin M. MightyRaze CraftsmanQuad19 Braden.H MatthewD tscustoms 1997 Murray Stretch44875 Creepycrawler mr.modified TheRainbowBoxer willis923 802 Customs Craftsman1998 kawasaki220 redlinemotorsportts LAWN MOWER MUDDER craftsmancole Customrust TheBeal donaldcon 27 posters |
donaldcon Member
| Subject: Re: 68 suburban 10 December 19th 2015, 6:53 pm | |
| Oxy with a guide.. Can cut just about any pattern if I can trace it
Yes the 20s will help in sure! | |
Age : 34 Join date : 2013-11-02 Points : 7142 Posts : 2907 Location : New Jersey USA
| Subject: Re: 68 suburban 10 December 22nd 2015, 7:57 pm | |
| Came out pretty good for oxy/ace. I found out that a good clean cutting tip helps. Tried a new one after using an old beat one for a long time and it made a big difference. | |
donaldcon Member
Age : 38 Join date : 2015-04-28 Points : 3939 Posts : 401 Location : Roseville, OH
| Subject: Re: 68 suburban 10 February 13th 2016, 7:27 pm | |
| New larger idler Just showing my home brew belt guard Mounted an ammo box for tools | |
MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5731 Posts : 1993 Location : Northern Ireland
donaldcon Member
Age : 27 Join date : 2013-03-18 Points : 7461 Posts : 3131 Location : raleigh nc
| Subject: Re: 68 suburban 10 February 14th 2016, 11:13 pm | |
| interesting. is the 26 like a 27 and the 25 a 24? Sometimes is like that i guess. Looking for a rock tire myself. | |
donaldcon Member
| Subject: Re: 68 suburban 10 February 14th 2016, 11:16 pm | |
| 26 measures about 26.
The 25 measures 22.
Same type tire on the other tractor is a 20 and measures as such | |
| Subject: Re: 68 suburban 10 February 15th 2016, 9:23 pm | |
| Nice hubs! I've got to get myslef a set of those Woolyboogers. Seem like a good tyre. | |
donaldcon Member
donaldcon Member
| Subject: Re: 68 suburban 10 March 27th 2016, 9:51 pm | |
| Another set of wheels reentered with new tires. These babies should dig Drilled the 4 spot welds. Knocked the center out Set it in place where I wanted it. And rewelded. | |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5424 Posts : 1311 Location : NW USA
donaldcon Member
| Subject: Re: 68 suburban 10 March 29th 2016, 9:19 pm | |
| Ordered a set of honda atv tie rods for it today and installed a new belt | |
| Subject: Re: 68 suburban 10 March 29th 2016, 9:45 pm | |
| High tech rim welding there. Nice deal. | |
donaldcon Member
| Subject: Re: 68 suburban 10 March 30th 2016, 11:44 am | |
| Thanks. It's really fairly simplr to do.
I used a 3/4 drill bit and drilled the 4 spot welds that held the wheel center to the wheel. Then knocked it out with a hammer, and flipped it over and tapped it back in place. I rotated it a hair so.the holes were not perfectly lined up so that I wasn't welding a hole shut, I was instead welded plug welding the wheel to itself on both sides.
To center it I first lined it up.with the rust line and then used a digital micrometer. | |
donaldcon Member
| Subject: Re: 68 suburban 10 April 7th 2016, 8:49 pm | |
| Looks nasty man. Plan on rim paint or anything?
Id be nice to have a few set to throw on, my ags suck on rocks. | |
donaldcon Member
| Subject: Re: 68 suburban 10 April 7th 2016, 8:53 pm | |
| Yes I have to paint them. Can't be having that color of yellow in a sears! | |
donaldcon Member
| Subject: Re: 68 suburban 10 April 9th 2016, 6:25 pm | |
| First draft of a flip up seat bracket. | |
Braden.H Member
Join date : 2016-03-29 Points : 3194 Posts : 48 Location : Indiana
Braden.H Member
| Subject: Sweat build April 9th 2016, 9:01 pm | |
| What are some of you future plans | |
Braden.H Member
donaldcon Member
| Subject: Re: 68 suburban 10 April 10th 2016, 7:35 am | |
| No they are not valve springs. But they are about the same size. My parts pile is getting small so I had to go to the hardware store and just dig around thier selection.
Not to much else planned for it other than a winch and I may build new spindles for the front. Only a matter of time until I break these ones. | |
donaldcon Member
Braden.H Member
| Subject: Sweat build April 10th 2016, 11:14 pm | |
| How would you make a trunk like yours mine does not have one | |
donaldcon Member
| Subject: Re: 68 suburban 10 January 22nd 2017, 9:19 am | |
| I built it out of angle iron I had laying around, and an old plastic tote. Update: Didnt like how high my seat sat, so I cut 3 inches out of the mount. | |
| 68 suburban 10 | |
