 68 suburban 10
Dustin M.
Braden.H
tscustoms
802 Customs
Craftsman1998
Customrust
donaldcon
27 posters
Go to page : Previous  1, 2, 3, 4, 5, 6, 7
donaldcon
68 suburban 10 - Page 7 Empty
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeJune 2nd 2020, 12:39 pm
Shes back in buissnes with a new to me used predator and a 7 inch engine pulley.
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeJune 2nd 2020, 3:25 pm
The 633 you had that failed after a long high speed run, could you tell what failed first or was it pretty hard to tell afterwards? Just wondering for my own machine as I was planning on doing some long range running. Maybe some sort of pump and oil cooler setup would be a help? You'd think they would keep on going though as long as they were filled with oil. I went about 4-5 miles with mine non stop at around 17-19mph but probably not much farther than that. It was fairly hot and kicked a little oil out but no serious issues that I know of.
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeJune 2nd 2020, 4:25 pm
We ran a 26 mile loop. Probably 20 of that was 3rd hi full throttle
20ish mph.
I litterly wore through the brass bushings in the axle tube and into the housing
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeJune 3rd 2020, 12:13 pm
I do remember mine were fairly hot to touch after going a few miles.
I suppose it wouldn't be too hard to drill and tap some holes in the top of the axle tubes and then pressure feed both sides. Maybe with a normal gear driven automotive oil pump running off the axle or something. If you had decent enough size lines so it would flow. Probably would keep them a lot cooler too. Wouldn't need a lot of pressure I wouldn't think, just a bit.
I guess the other gears and shafts make out ok with the needle bearings.
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeNovember 15th 2020, 7:59 am
So for the first time in forever this thing hit the trail again with an epic group of 25 other tractors.68 suburban 10 - Page 7 Fb_img10
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeFebruary 22nd 2021, 10:18 pm
After some rowdy trails with creepycrawler I had tontear the trans apart and replace the bent axles.
Along with finally replacing the steering and spindles.
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeDecember 12th 2023, 11:44 am
Back from the dead again. Have been a few upgrades to this thing over the last year. Like 2" rear stretch, jd front axle , winch install, and some hillvilly beadlocks on new tires.68 suburban 10 - Page 7 20231210
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeDecember 12th 2023, 4:17 pm
68 suburban 10 - Page 7 Screen10
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeDecember 12th 2023, 4:47 pm
Hey you have the Roper aluminum grille!? You lucky dog!
My All Terrain Tractors:
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeMarch 25th 2024, 10:22 am
68 suburban 10 - Page 7 Fb_img15
68 suburban 10 - Page 7 Fb_img14
Not much has changed this winter.
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeMarch 25th 2024, 7:41 pm
I saw some of the GER stuff on FB.  Looks like there was lots of carnage.
68 suburban 10 - Page 7 Sig115PROJECTS:
68 suburban 10 - Page 7 Sig21468 suburban 10 - Page 7 Sig314
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeMarch 25th 2024, 8:43 pm
Always love seeing you out on this thing! You’re definitely well matched to the tractor, having been on it for so long.
donaldcon
donaldcon
PostSubject: Re: 68 suburban 10   68 suburban 10 - Page 7 Icon_minitimeMarch 25th 2024, 8:48 pm
There always is a lot of carnage there when we have large groups show up.
This tractor is pretty basic so not a lot fails often on it, it's not changed much in the near decade I've been riidng it so it's pretty dialed in.
68 suburban 10
Page 7 of 7Go to page : Previous  1, 2, 3, 4, 5, 6, 7
» 72 sears suburban
» I seem to be new here. 1969? Sears Suburban
» Baja sears suburban
» Sears suburban off-roader
» 68 Sears Suburban restomod
