 Stx38 problems
jonjunk
jonjunk
Stx38 problems Empty
PostSubject: Stx38 problems   Stx38 problems Icon_minitimeMarch 16th 2015, 9:11 pm
Hey guys I haven't posted in a while, but I have had an stx38 for a few years and It worked great until now last fall I used it to mow perfectly then I parked it and now we got some warmer temps so I got it started and everything works except the deck belt is really loose so it will not spin the blades the electric clutch works good , and I even bought a new belt and put it on and that's not the problem then I dropped the deck again and hoisted it up and inspected all of the underside and see that none of the deck lift components have any wear or damage I tried a few of the different holes for mounting the deck to see if that would tighten it up a little but nothing worked I could buy a belt that is even smaller and that would work but I'd rather figure out why it went screwy just sitting. And I bought the manufacture correct sized belt.
PostSubject: Re: Stx38 problems   Stx38 problems Icon_minitimeMarch 16th 2015, 9:41 pm
I'd check all your idler pulleys and the springs for them. I'd also check all the bearings on your mower deck. Make sure the belt is going the right way through the pulleys and idlers. It could be as small as putting the belt on the wrong side of the pulley, but it could make a HUGE difference. There should be some sort of belt diagram on your tractor or mower deck.
jonjunk
jonjunk
PostSubject: Re: Stx38 problems   Stx38 problems Icon_minitimeMarch 16th 2015, 10:09 pm
There are no idlers for the deck drive it goes directly from the electric clutch to the main deck pulley, I've had the deck off several times in the last three years since I got it and I've been using the same belt and its been tight every time, always has gone off and on with no troubles. even when the engine mounting bolts were all gone(sheared and wobbled out) the belt was still tight enough to work without flaw(besides the motor bouncing side to side).
kieranruffell
PostSubject: Stx38 Problems   Stx38 problems Icon_minitimeMarch 16th 2015, 11:00 pm
stonykill
PostSubject: Re: Stx38 problems   Stx38 problems Icon_minitimeApril 8th 2016, 8:42 pm
There is a spring on the discharge side, at the back, which hold tension on the idler pulley that the PTO belt runs off of. The PTO belt runs the deck from a double pulley, and the idler spring holds that tension. If you haven't figured it out yet, and need pics just let me know and I'll take some.
Stx38 problems
» STX38 Rebuild
» Transaxle problems
» Starting Problems
» Future problems for this?
» Belt Problems
