All this is a hypothetical, so bear with me. Lets say, you had a strong engine, and a perfect pulley set up where nothing slipped. Now, take all that, and add PERFECT traction. Now, alone, all of these may be good right? But what about together? I'm saying this because if I were to pull something that REALLY tested my engine, what's the possible outcomes?
Chopperhed Moderator
Age : 58 Join date : 2012-10-14 Points : 5256 Posts : 801 Location : Edmonton, Alberta, Canada Eh!
you flip, happened to me this week, i have excellent traction, a stong motor and the belt dont slip, it flipped the lifted one on me, so add a bar on the back to prevent that
Murray modder Member
Join date : 2012-11-23 Points : 4803 Posts : 356 Location : Somewher in Va
Assuming the engine is healthy, there's not much potential for damage. A load too great will stall it- that's all. That's also assuming you're not dumb enough to rev it up to 9 million RPM and dump the clutch with such a load. You do that, you got what's coming...
Full throttle with that load?
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7320 Posts : 2914 Location : Ontario Canada
No problem. It's not the load that will F it up- it's shock. PROPERLY applying a load that is too great won't do it. The shock load will.
I know from experience, that revving a 2.2 litre hemi, up to 4 grand, in reverse, in 4 low, on slick cement, and dumping the clutch.....
will twist a transfer case right out of the frame.
I learned from it and it Was fun.
Thunderdivine Veteran Member
Join date : 2012-12-21 Points : 6545 Posts : 2101 Location : Norway, Europe
