| | Mower powered jeep buggy! | |
+4Moose redlinemotorsportts MatthewD Stretch44875 8 posters | |
Stretch44875 Administrator
![Stretch44875](https://2img.net/u/2812/37/66/46/avatars/314-28.jpg)
Age : 49 Join date : 2012-04-05 Points : 5627 Posts : 959 Location : Mansfield, Ohio
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Mower powered jeep buggy! March 16th 2015, 1:20 pm | |
| About a month ago I picked up a frame with axles, tires, steering, transmission, transfer case, and part of a body on it. Reason I got it was for the frame. It's needed for the restoration of other jeeps. I bought another jeep in that had a couple more things on it, it's frame isn't the best. ![Mower powered jeep buggy! 0315151045d_zpsh1gc2twy](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151045d_zpsh1gc2twy.jpg) Then I get to brainstorming.... There is nothing there, it looks really light... But I have steering, brakes and pedals... Why not slap a mower engine on there, and gear it 2 to 1 to the tranny? So now I am going to install a jackshaft with a hub mounting the original flywheel and clutch, and drive that by chain with a 18hp horizontal engine. Weld on a couple school bus seats we have, plywood floor, and I'll have a 4 seater, 30mph, 4wd toy! Chains, welded diff, and I should be able to go anywhere. Leaving the hitch on for moving stuff around the yard. Haven't figured how far I'll go with lights and such. I'll pull all the gauges but the speedo. Not going to get crazy with it, no rollbar, yet... I need the frame, rear crossmember, and maybe some tranny parts out of them. But I should have plenty left to build with. Pics! ![Mower powered jeep buggy! 0315151045_zpsbu6txxzl](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151045_zpsbu6txxzl.jpg) ![Mower powered jeep buggy! 0315151044a_zps0oaoq62x](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151044a_zps0oaoq62x.jpg) ![Mower powered jeep buggy! 0315151040_zpsccqrvliq](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151040_zpsccqrvliq.jpg) ![Mower powered jeep buggy! 0315151041b_zpspzdphjzb](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151041b_zpspzdphjzb.jpg) ![Mower powered jeep buggy! 0315151041d_zpswvnuctae](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0315151041d_zpswvnuctae.jpg) | |
| ![Go down](https://2img.net/i/empty.gif) | | MatthewD Veteran Member
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | redlinemotorsportts Moderator
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 16th 2015, 2:48 pm | |
| Looks like a cj2a because you're into the earlier stuff. Our cj3a has the flat 4, peobably as much hp as the twin cyl you're talking about | |
| ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 17th 2015, 7:14 am | |
| Actually, Jeep engine is 60 hp, 105 torque, which was really good for when it was built. Mower engine is much lighter, but only 20 torque, 18 hp. I am using two Jeeps, it will be the parts left over from restoring my other 2 1946 CJ2A's. 4 Jeeps total | |
| ![Go down](https://2img.net/i/empty.gif) | | Moose Established Member
![Moose](https://2img.net/u/2812/37/66/46/avatars/1358-86.jpg)
Age : 35 Join date : 2014-01-12 Points : 4877 Posts : 919 Location : Defiance, Ohio
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | 802 Customs Member
![802 Customs](https://2img.net/u/2812/37/66/46/avatars/2139-12.jpg)
Age : 24 Join date : 2015-01-08 Points : 3684 Posts : 146 Location : Vermont
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 17th 2015, 2:52 pm | |
| This is a amazing idea! Hope the oppy has enough sack to move this beast even though it's fairly light. | |
| ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Stretch44875 Administrator
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 7:59 am | |
| I figure it will be about half the weight from stock. Plus, with low range, you have 6 gears. First gear low range idle should be 1 mph. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 9:04 am | |
| Sounds pretty reasonable. I was batting the numbers around in a free moment yesterday, and I think at 2:1 it might struggle in the higher gears in high range, but it's worth a shot. Worst case, you regear lower. No great loss. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 10:34 am | |
| I'm not sure where the weight will end up.
Stock is 2215
I'll be missing engine 3-400lbs body 5-600lbs radiator, wiring, seats, etc, 100lbs?
Adding bus seats 150lbs engine 100lbs drivetrain adapter 50lbs with clutch
I can pick the back end of a jeep off the ground(at least I could 15years ago)
Will I be able to do 30mph up a hill? doubt it. But I might be able to hold speed on the flats.
Of course adding 4 guys will slow me down alot.
Heck with regearing, I'll just find a bigger motor!
I'll take on the banner tractor when done! | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 10:39 am | |
| This project just has so many advantages. Bullet proof 4wd drivetrain, with a real clutch!(using stock flywheel/clutch on jackshaft) Brakes and steering are already done. Suspension! Cheap. I paid 160 for one jeep, 200 for the other, and can get most of the money back selling extra parts. Old jeeps are everywhere with bad bodys. Parts are cheap and easy to find. Heck maybe some day we will abandon the mowers and go with this idea. | |
| ![Go down](https://2img.net/i/empty.gif) | | RCTankboy Member
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 11:55 am | |
| @Stretch Stop giving me ideas for more projects! I dont have the room or the time as it is now!
...that said, I always wanted to put one of those Kubota 3 cyl diesels in it for giggles......ACK! Must...stop...thinking about..it! | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 12:18 pm | |
| If you could find one of those wisconsin v4 engines that would be killer, or possibly two twins. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | Doc Sprocket Site VIP
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 18th 2015, 5:03 pm | |
| - Stretch44875 wrote:
Heck maybe some day we will abandon the mowers and go with this idea. Hang a deck off it... LOL | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 23rd 2015, 9:53 am | |
| The restored jeep will have a PTO for running farm equiment, such as a mower... Moose and Therainbowboxer stoppey by saturaday. After a quick, muddy romp, we got started on the buggy. Pulled engine, radiator, fenders, grilled, tub, and tires from my old jeep. This has the worst frame and rear axle, and will be used for the buggy. All the good parts are going to another frame I have for restoring. Pulled partial body for buggy use. Pulled another jeep engine for flywheel and clutch. A ton of work got done, thanks for the help guys! Future buggy frame. Tires are swapped and engine is gone since pic. ![Mower powered jeep buggy! 0321151515a_zpsmbafal1b](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0321151515a_zpsmbafal1b.jpg) | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 26th 2015, 10:05 am | |
| Made some progress. Got a horizontal shaft engine. Made hub adapter to mount flywheel to 1 in shaft. Got a 1 in shaft and bearings. Almost ready to start putting things together. Front side of hub adapter. Pretty cool, this started out as a chunk of round stock, turned it on the lathe, drilled and tapped 3/8 fine for bolting flywheel, broached 1/4 keyway, and drilled and tapped set screws. ![Mower powered jeep buggy! 0325151056_zpszombvfg0](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151056_zpszombvfg0.jpg) Backside ![Mower powered jeep buggy! 0325151056a_zpsbeknlawl](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151056a_zpsbeknlawl.jpg) Mounted to flywheel, has a nice press fit into recessed part of flywheel. ![Mower powered jeep buggy! 0325151105a_zpsmkglvkfi](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151105a_zpsmkglvkfi.jpg) ![Mower powered jeep buggy! 0325151105_zpsfaxpp199](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151105_zpsfaxpp199.jpg) 16hp briggs opposed engine. ![Mower powered jeep buggy! 0325151737a_zpsijqnzbv3](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151737a_zpsijqnzbv3.jpg) Flywheel, hub, shaft and bearings on transmission, just stuck on there for now. ![Mower powered jeep buggy! 0325151737_zpsspweekld](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151737_zpsspweekld.jpg) Frame, with drivetrain and old tires. ![Mower powered jeep buggy! 0325151737b_zpsmwjbwiiw](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151737b_zpsmwjbwiiw.jpg) Body section being used. ![Mower powered jeep buggy! 0325151737d_zpsmcmgpzrb](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151737d_zpsmcmgpzrb.jpg) Hand winch. ![Mower powered jeep buggy! 0325151737c_zpsjtw7ufxy](https://2img.net/h/i70.photobucket.com/albums/i104/mjenera/Jeep/0325151737c_zpsjtw7ufxy.jpg) | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 26th 2015, 11:20 am | |
| Stretch, you mad man.
It's not going to be the fastest thing ever, but I hope to see it crawling up some hills. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | TheBeal Veteran Member
![TheBeal](https://2img.net/u/2812/37/66/46/avatars/967-1.jpg)
Age : 29 Join date : 2013-06-06 Points : 5643 Posts : 1402 Location : Central PA
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 27th 2015, 2:03 pm | |
| Offer some sacrifices to the Jeep gods(maybe just set some old tires on fire or something), and beg for their blessings... I have a 5 speed jeep or ranger trans stashed away, Id like to someday link it up to a big engine and a cut down jeep rear end. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! March 28th 2015, 8:38 pm | |
| Moving along nicely. Its stuff like this that makes me really want a lathe and a mill, great machine work. | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | Subject: Re: Mower powered jeep buggy! February 21st 2016, 8:27 am | |
| Maybe a bit of an old thread but have you done anymore work on this? I cant wait to see it climbing some hills and going through mud! | |
![Mower powered jeep buggy! Empty](https://2img.net/i/empty.gif) | | ![Go down](https://2img.net/i/empty.gif) | | | Mower powered jeep buggy! | |
| Who is online? | In total there are 131 users online :: 0 Registered, 0 Hidden and 131 Guests
