| | Shaft powered lawn tractor | |
+3dangeroustoys56 Chunk arild365 7 posters | Author | Message |
arild365 Member
Age : 29 Join date : 2010-02-11 Points : 5779 Posts : 320 Location : Canada, BC
| Subject: Shaft powered lawn tractor February 25th 2010, 11:43 am | |
| I wanted to know if any of you had a shaft driven lawn tractor. It would be ideal for water. I think some Cub cadets have have em. It wouldnt be too hard to make. | |
| | | Chunk Established Member
Age : 33 Join date : 2010-02-10 Points : 6186 Posts : 779 Location : Angus, Scotland
| Subject: Re: Shaft powered lawn tractor February 25th 2010, 12:56 pm | |
| It would be very easy to do with any lawn tractor. You'd need two Right Angle Gear Boxes, one under the engine and one on the tranny. That would give you a 1:1 ratio. Only problem is you'd need a proper clutch like a car. Can you tell I've thought about this before? lol. The biggest expence would be the RAGBs, theyre not cheap new. | |
Age : 53 Join date : 2010-02-10 Points : 7042 Posts : 1726 Location : Florida, USA
| Subject: Re: Shaft powered lawn tractor March 9th 2010, 3:57 pm | |
| Someone somewhere mentioned about home making one out of two axles that have pinion gears - use two pillow blocks to support them - id say mount them to some square tubing ( L shaped) and add a cross brace - then build a box with oil seals out of steel sheets, welding all the sides but one ( to access the thing, bolt the unit to the bottom ( to remove it if needed) - i think its possible and sometime i wanna try it!
Only hard bit would be to mesh the gears correctly- might need to check it like when checking a differential ( to see if they mesh right). | |
| | | ncredleg Member
Age : 59 Join date : 2010-05-16 Points : 5361 Posts : 59 Location : NC
| Subject: Re: Shaft powered lawn tractor June 10th 2010, 10:21 am | |
| - arild365 wrote:
- I wanted to know if any of you had a shaft driven lawn tractor. It would be ideal for water. I think some Cub cadets have have em. It wouldnt be too hard to make.
I don`t see why a transaxle couldn`t be mounted at a 90 degree orientation to original and use a steering U-Joint attached to the input shaft . You would have to figure a method to clutch it though to change gears, unless it was a hydro. | |
| | | Guest Guest
| Subject: Re: Shaft powered lawn tractor August 10th 2010, 7:51 am | |
| my honda has a shaft n it goes ok in the mud its just kinda heavy if u get better tires itll do better |
| Subject: Re: Shaft powered lawn tractor August 10th 2010, 4:26 pm | |
| The bigger cubs have shaft drive - they weight alot as well. Thats why alot of tractor pullers use a cub trans as a starting point.
I dont know how well a transmission mounted sideways would work - where would you mount it? They take up alot of room - plus theyre weak ( unless filled with oil and heavy duty berings) - only way to find out is build one actually.
Belts will still work when wet- IF theyre the better quality ones - i ran my agway in the mud and water up to the bottom of the motor and it still moved easily ( only lost traction from the crappy stock tires is all). | |
| | | CraftsMAN Member
Age : 38 Join date : 2010-06-01 Points : 5753 Posts : 364 Location : NY
| Subject: Re: Shaft powered lawn tractor January 6th 2011, 7:36 am | |
| Yeah that guy Tommarytn on YT uses all those old Bolens tractors with the wisconsin and kohler motors - neat things about those are the trans can be locked like a front axle on a 4x4 - just twist the knob on one of the rear wheels- plus the tube chassis is cool. He takes those things everywhere - mud, water.
The shaft setup is sorta weird- it hooks to the motor by belts- its not directly hooked to it - its mounted a few inches below the motor back to the trans. | |
| | | DICE464 Member
Age : 28 Join date : 2010-07-30 Points : 5327 Posts : 129
| | | | Jordan Member
Age : 30 Join date : 2010-10-03 Points : 5321 Posts : 170 Location : Ontario Canada
| Subject: Re: Shaft powered lawn tractor January 6th 2011, 1:41 pm | |
| - dangeroustoys56 wrote:
- The bigger cubs have shaft drive - they weight alot as well. Thats why alot of tractor pullers use a cub trans as a starting point.
Belts will still work when wet- IF theyre the better quality ones - i ran my agway in the mud and water up to the bottom of the motor and it still moved easily ( only lost traction from the crappy stock tires is all). i had 2 similar tractors a few years ago and they both had the exact same belt, i replaced both belts within 2 months but i bought them at the same time because i knew id need it anyway one of them i could completely submerge and itll still grip fine but on the other it didnt take much at all and the belt was slipping and i had to get the other tractor to pull it out | |
| Subject: Re: Shaft powered lawn tractor January 6th 2011, 7:55 pm | |
| On Tommarytn's YT cahnnel- when they went into deep water- water would spray up like a water fountain when the hood was open , just in front of the steering wheel- pretty funny. | |
| Who is online? | In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests
