| Poulan Rally Machine, 250 mile trip build #2 | |
+10craftsmancole LAWN MOWER MUDDER Craftsman1998 redzz02 mr.modified Thecrazyoldcraftman MatthewD redlinemotorsportts N1ck Doc Sprocket 14 posters |
Age : 27 Join date : 2012-10-31 Points : 5164 Posts : 745 Location : The Wyo-Braska Panhandle
N1ck Member
Age : 24 Join date : 2014-06-08 Points : 3903 Posts : 74 Location : North Central Arkansas
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 19th 2015, 10:14 pm | |
| - Ariens YT11 wrote:
- Also I forgot the 50 coal trains a day blowing their horns I think the route with noise ordinance won't be a problem.
"Come along for the ride as we pass through some of the most breath taking countryside by lawn tractor..." Should sell DVD's of the ride afterwards... And happy birthday. | |
redzz02 Site VIP
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
Age : 30 Join date : 2010-05-12 Points : 6376 Posts : 899 Location : PA pittsburgh and pymatuning
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5152 Posts : 1068 Location : New jersey
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 20th 2015, 8:37 am | |
| - redzz02 wrote:
- goodluck! hope you guys can make the trip! make sure you use nylock nuts on everything and highspeed bearings on all moving parts!
Yeah lol dont want parts falling off while we are doing 50mph | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 21st 2015, 9:45 pm | |
| Well I have a somewhat of an update, I have just bought some LED lights to be put in the light sockets on the hood of the poulan, and I have aquired on some 1x2 steel a $4 for a 4' piece of steel. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 22nd 2015, 7:35 pm | |
- does anyone know why a 820 won't go into 5th gear fully?
Shift fork bent, shifter don't have enough clearances, shift keys, gears aren't lined up right, is a four speed, etc. | |
Age : 25 Join date : 2013-04-05 Points : 4962 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 22nd 2015, 7:44 pm | |
My friend had this problem and he never figured out that the shiftfork ball (I don't know the right term) fell out when he took it apart, until he blew out the back of the axle. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 22nd 2015, 11:56 pm | |
My friend had this problem and he never figured out that the shiftfork ball (I don't know the right term) fell out when he took it apart, until he blew out the back of the axle. I'm thinking on swapping the shift fork from the trusty 801 or 844 5 speed into the 820 and trying that out. if that doesn't work then i think my 5th gear is stripped in a way I wont be able to fix it. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 27th 2015, 3:45 pm | |
| Well uys I need your opinion, would a piece of 3/4" x 2" be enough to run as a front axle that is being used on a 4-link? And I have my LED lights from amazon and I am gonna try them tonight.
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 February 28th 2015, 8:50 pm | |
- Well uys I need your opinion, would a piece of 3/4" x 2" be enough to run as a front axle that is being used on a 4-link? And I have my LED lights from amazon and I am gonna try them tonight.
And a 3/4 x 2 should definitely work just make sure the wall of the metal is nice and thick but not too thick. mine is a 1 1/2x3 and it rubs some so ill have to do something about it. Maybe make it so it doesn't pivot idk. But yeah it will work. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 March 1st 2015, 9:23 pm | |
And a 3/4 x 2 should definitely work just make sure the wall of the metal is nice and thick but not too thick. mine is a 1 1/2x3 and it rubs some so ill have to do something about it. Maybe make it so it doesn't pivot idk. But yeah it will work. ok, so next time i'm in at napa i'll get a peice of steel for the front axle then it is the time to get all the parts for the new 4-link setup. and BTW the LED lights work but might not be as bright as the normal 1156 bulbs because they don't throw light around in the headlight housing but I will use them in the small bulb housings I got for extra lights. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 March 2nd 2015, 6:39 am | |
Alright sounds like a plan. | |
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 March 7th 2015, 9:20 pm | |
| Well guys today I have been running my motor all day almot and have slightly adjusted the arm for the carb to get more rpm's out of the motor without un govened the motor, and I have tried to get the 820 into the 5th gear and its not staying in gear. thoughts??? anyone?
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 March 26th 2015, 10:30 pm | |
| All right guys, I have a update on this but I haven't done anything because of weather diffaculties. yesterday there was snow and the day before was 70*F. and now I am in the stage of not wanting to do anything, period. but the questions I have is what pulley ratios do I need to get to 40-50 mph with a vanguard 16 V-twin and 820 on 23-25" tires?
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 April 1st 2015, 2:58 pm | |
| I got paint for the tractor and I have the rear fenders off the tractor and I will have photos up here as soon as possible or a video of what has happened so far. I've still got a problem with the 820 slipping in 5th gear but that should be fixable when I get the money. | |
Vortec7622 New Member
Age : 26 Join date : 2014-09-27 Points : 3732 Posts : 20 Location : Massachusetts
mikesmower98 New Member
Age : 26 Join date : 2015-04-01 Points : 3528 Posts : 6 Location : ireland
| Subject: Re: Poulan Rally Machine, 250 mile trip build #2 April 2nd 2015, 12:55 pm | |
| I would try a 7 on engine and 4 on transaxle, i wudnt go any smaller or the belt would slip, those big tires should make it go quite a bit faster , maybe a better alternative wud b to put in a new set of gears in the transaxle, they arent cheap but wud pay for themselves in the long run because you wont need to aggressively pully swap it, anyway do wat u tink is rite and be safe. | |
