 LT4000 Craftsman Mudding/Racing 250 mile trip build
Craftsman1998
RCTankboy
the old guy
mud boggin mtd
willysjeepmb
KohlerCoalRoller
redzz02
MasonMcK
18 posters
Craftsman1998
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Empty
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 2nd 2015, 7:53 pm
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 2nd 2015, 7:54 pm
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 4:41 pm
Looks like it should work pretty good. Do you think you'll have much issue with belt stretch on such a long continuous run? I guess probably not as bad as off roading. Even though things might eventually heat up more on a long run, at least your not dumping the clutch and getting stuck on logs ect.
802 Customs
802 Customs
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 7:10 pm
Great progress. but you may want to slow down the wire feed speed a little bit.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 7:32 pm
My wire speed is on 3 lol
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 7:35 pm
Im sure the belt will heat up and stretch and there isn't anything i can really do about it besides bring a few spare belts lol. Only time will tell though.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 7:45 pm
And i upgraded my engine its got more hp and more cylinders lol. Ill post some pics tomorrow its too dark to get pictures. Its a 17 hp opposed twin and i think it needs a new starter because it cant really turn over the engine. So if anyone knows where to get a starter for it let me know. And i had to do alot of work to get it running because it was outside for awhile and it had water in the cylinders. so i need to drain the oil asap. but i cleaned the water out of the cylinders and put some oil in the cylinder just to fire it up. And the motor came out of a murray widebody. And ill have to do something with the hood because the engines to big. I was thinking of cutting a hole in the hood and adding A scoop so the hood will fit and it will make it look coller but idk havnt thought about it much. Might even build my own hood. sort of like mudkings.
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 8:41 pm
I think overall, everything will probably hold up pretty good. Pavement running should be relatively easy on things. It's mostly flat lands out there anyway right?
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 3rd 2015, 9:52 pm
For the most part it is flat, for most of the trip but there are hills at the start and near the end.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 4th 2015, 9:02 am
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11021163_341809836020287_606835544034976057_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10403594_341809916020279_1066967935624963637_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11044524_341809846020286_3521082712620880065_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11046831_341809839353620_4703280709154540994_n
I cleaned the outside of the carb i just haven't cleaned the inside yet. It Definitely needs it.
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 4th 2015, 9:58 pm
hey if you want I can end out the 3-screw I have for that if you want if I can get your carb off that motor.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 4th 2015, 10:16 pm
I think im going to leave the carb thats on it. Thanks for the offer
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 11th 2015, 9:55 am
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10409240_344116805789590_6403986803007053345_n
Cleaned the carb and got it running better
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11034280_344116809122923_7643444407806462574_n
Made the spindles a little stronger
And i had to pull my transmission apart Again because the ball bearing for the shifter fell in to the case so i had to fish it out.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 16th 2015, 8:06 pm
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 21698_347190955482175_7309251920455967696_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11067485_347190958815508_9195827164799618287_n
Started working on the muffler it sounds good.
And i welded up a 9in pulley for the front and i have a 3 1/2 in the back so this things going to fly. And i need a 96in belt. So now i need to do some work on the steering then i can test drive it.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 17th 2015, 8:53 pm
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10405476_347553448779259_4298092926184813054_n
Found some of the parts ill need to do my steering. And yes the shaft is 1in. i would like something thinner but at least it won't bend if it rolls over.
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10431532_347553485445922_1334113508538952396_n
Heres my 9in front pulley its not the straightest thing but for testing purposes it will do.
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10511103_347553502112587_8352157778244259468_n
Made 2 of these one for the top which i boxed in and one for the bottom which i haven't boxed in yet.
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10476469_347553505445920_3024588944604918956_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 20482_347553508779253_4839876463659749230_n
Heres what the top one looks like. Dem welds tho
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10446016_347553542112583_7462395813059582105_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 1897780_347553555445915_8178630055053910793_n
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 17th 2015, 8:57 pm
And i did have more progress than this but it got too dark and i couldn't take pictures. So more updates tomorrow.
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 18th 2015, 12:14 am
im liking the steering mod looking good!
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 26th 2015, 10:26 pm
Nice to see some progress on other peoples builds, I haven't done anything on my tractor because of weather problems, there was a tornado warning and a tornado this week on Oklahoma that killed one person. Sad
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 30th 2015, 7:04 pm
Whats better for high speeds Disc brakes or band brakes?
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeMarch 30th 2015, 7:30 pm
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11102786_352339374967333_9078983056610062006_n
Started making foot boards out of pipe today finished one and half of another but ran out of wire.
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11008804_352339294967341_2305992305989140523_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11031136_352339291634008_5025298852223799731_n
Lowered the seat and fenders 3in for a lower center of gravity.
There not mounted yet which is why there resting on the tire. they wont when its done.
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11083900_352339298300674_4280937162473942265_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11081277_352339338300670_7351387877138788677_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10995568_352339341634003_6608520442809085535_n
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeApril 4th 2015, 2:18 pm
I would think disk brakes would be better, but probably not too big of a deal either way if your not going to be riding them all the time. Steering setup is looking pretty beefy. What are you planning on using for running boards under the pipe. Solid or some kind of screen?
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeApril 4th 2015, 6:04 pm
I'm liking the foot boards and the lower stance in the back. Are you going to do the same in the front?
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeApril 4th 2015, 9:19 pm
Thanks im going to try and keep the front end low. and i might make my own fender because i don't like these fenders.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeApril 4th 2015, 9:26 pm
You remember that diamond plate tool box i have im going to use some of that. And i did some more work on the foot boards today but didnt take any pictures so ill do it monday. And i got a belt for it and i started it and watched the tires turn really fast so once i do the steering i can test drive it.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeApril 8th 2015, 9:29 am
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11119705_354454691422468_1492895351144221827_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11050847_354454688089135_4305483503675845883_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11133666_354454694755801_6022229736786814975_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 10407772_354454598089144_1855767724817967320_n
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11138521_355099961357941_4906225447097365182_n
Added a pulley to pull the belt away from the shifter
I think im going to fabricate my own fenders
LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 11133878_355099964691274_7195600802679265723_n
And i welded n a temporary steering wheel ant stole the axle off my sisters tractor and took my tractor for a rid and wow its fast. but found out 2 things my engine pulley isnt all that straight and i need better belt retainers. now im going to cut out where the axle mounts and tilt it a few degrees then re weld it because im using a different front axle.
Craftsman1998
Craftsman1998
PostSubject: Re: LT4000 Craftsman Mudding/Racing 250 mile trip build    LT4000 Craftsman Mudding/Racing 250 mile trip build  - Page 4 Icon_minitimeJune 29th 2015, 12:13 pm
I need to get cracking on this build again
Page 4 of 5Go to page : Previous  1, 2, 3, 4, 5  Next
» Poulan Rally Machine, 250 mile trip build #2
» OFFROAD Craftsman LT4000-2 mudding mower (MTD12HPTURBO)
» My Craftsman Lt4000 Mudding mower!+MTD12HPTURBO YOUTUBE CHANNEL!
» 1993 Craftsman LT4000 heavy mud build.
» Craftsman LT4000 utility / mower build
All-Terrain Lawn Tractor Forum :: Competitions and Challenges :: Build-Off Competition :: Build-Off Archives :: 2015 Archive-
