 Mr.modified's GTR Four Zero
Rockinator
STUNTMAN JON
chevy8988
MasonMcK
thewisconsinredneck5160
TheCollector
redzz02
McKmudder
RCTankboy
Deluxe66
rarbaugh07
Craftsman1998
jamcco
802 Customs
GenevaCustoms
mudman604
33 posters
Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
Mr.modified's GTR Four Zero - Page 10 Empty
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 12th 2015, 10:08 pm
Just watched your test run. Looks to me like it was a success. Great job. Suspension seems to be working pretty good from what I could tell.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 13th 2015, 2:15 pm
Thanks. I think it helps quite a bit over having it solid. It's on the soft side, but not too bad. I'm going to crank on a bit more preload.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 14th 2015, 2:00 am
Cool! Yah, at your young age suspension is a cool thing to have on your project, but when your my age it's a necessity, LOL.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 22nd 2015, 8:28 pm
So here is a mock up of what the body could look like. The grill obviously could look a lot better, but it's tough to make it look good with card board. Front fenders would be separate. The grill would be slightly lower than the engine shorud and tapered up to the edge of it.
Mr.modified's GTR Four Zero - Page 10 IMG_4759_zpsnzxnznbg
Rear wouldn't be too hard to make. Couple of trailer marker tail lights, black plastic screen over the center opening, and some semi clear plastic mud flaps.
Mr.modified's GTR Four Zero - Page 10 IMG_4760_zpsdo0dts04
Mr.modified's GTR Four Zero - Page 10 IMG_4761_zpsixvgyboc
You could fill in these sides or leave them open like they are here. But if you had flat sides back here and not on the front fenders, it might look weird.
Mr.modified's GTR Four Zero - Page 10 IMG_4763_zpsz9t0pjhl
I wanted the headlights behind the grill, but I just put them on the outside near the top for the mock up to see how it would look in a conventional layout. You could put them on top of the front fenders too, but that sort of gives it the look of a lotus 7.
Mr.modified's GTR Four Zero - Page 10 IMG_4764_zpsemm5zfue
By making a couple of removable panels around the top of the engine, you still have the look of a hood without covering the starter pulley. Over all I don't really like the body all that much and I think I'll just end up making four black plastic fenders and some type of grill and hood like the mock up. The front fenders could be mounted to the a-arms so they move with the suspension. It's tough to come up with a grill that will look good. Needs to be somewhat sporty looking to keep the fast and small look of the machine. If the fuel tank is going up front, it's going to be tight with the headlights there also. Fuel tank may still end up behind the seat. Even if you didn't make the rear section, you could still have some type of wing in back, maybe made from aluminum.
Mr.modified's GTR Four Zero - Page 10 IMG_4765_zpsopltfmii
MasonMcK
MasonMcK
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 22nd 2015, 8:39 pm
Looks pretty cool. Since you're up in the air about the front end, maybe try making a few different cardboard front ends and choose the one you like the best to make the final of. Maybe try making a normal car front end where the fenders are part of the hood and have a full width front grille with fender wells. It might be easier to get the look that you're looking for. Otherwise it looks great!
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 22nd 2015, 9:02 pm
Thanks. I thought about making the front end like what your saying with a grill out in front of the wheels full width. The only problem is it makes the whole machine look a lot bigger and sort of takes away from how big the engine is compared to the frame. Also I wanted to try to keep the tractor look. A bit tougher than I thought it would be. I mocked up a rounded grill the same profile as the dash and a hood that went over the engine, but that made it look too long. Of course you'd have to take the hood off every time to rope start it that way too. Maybe I'll make some flip up headlights somehow, that might be neat.
MasonMcK
MasonMcK
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 22nd 2015, 9:09 pm
Yeah I get what you're saying. Though tbh, I kinda like it with no body on it at all. Maybe just make a small front grille but no hood or other body parts. Other than some small fenders maybe? Just my $.02
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 23rd 2015, 11:25 pm
I'm almost leaning in that direction too. I like the ultra small look without all the added stuff.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 28th 2015, 7:57 pm
Pretty much decided on just fenders and a grill. Then of course mount the lights somewhere. Anyway just about got all the way done with this thing. Only a few things left to finish up. As far as this years build-off is concerned: THIS BUILD IS COMPLETE!
Figured I would post a few pics of the finished product. Of course i've got the test run video a page or so back in case you missed it before. Also I finally weighed the thing. So here's all the important junk.
GTR Four Zero Specifications:
Weight (wet) - 192lbs
Wheel base - 39"
Width - 30.5"
Height (Top of steering wheel)- 26.25"
Ground clearance - 5"
Power - 18hp @ 3600rpm
Max speed (estimated) - 40mph
Transmission - 5 speeds forward
Mr.modified's GTR Four Zero - Page 10 IMG_4785_zpsvaaqndv6
Switches installed.
Mr.modified's GTR Four Zero - Page 10 IMG_4786_zpspmhoulnw
Front
Mr.modified's GTR Four Zero - Page 10 IMG_4787_zps4u4dkm01
Rear
Mr.modified's GTR Four Zero - Page 10 IMG_4788_zps8bswbqpb
From above
Mr.modified's GTR Four Zero - Page 10 IMG_4789_zpskib4dhhz
The twin tecumseh carbs.
Mr.modified's GTR Four Zero - Page 10 IMG_4792_zpslnb7kfy4
Thanks for anyone who helped out or made suggestions.
MasonMcK
MasonMcK
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 8:48 am
Looks great! I'm glad you chose to go with no body on it. It looks so much better in my opinion.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 3:42 pm
My JD Mini has a 31 inch wb i think, but well done!
redzz02
redzz02
1st Place Build-Off 2015
1st Place Build-Off 2017
1st Place Build-Off 2018
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 4:20 pm
great fab work its looking so good!
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 6:51 pm
Great job!! My favorite parts are the exhaust and duel carbs.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 7:32 pm
Great job! best part is the dual carbs for sure. Cool Twisted Evil
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 7:43 pm
Thanks a lot. Looking around now for some plastic to make the fenders out of.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 29th 2015, 10:46 pm
Looks good dingus, I demand a ride! Maybe.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeNovember 30th 2015, 4:56 pm
I told you that you wouldn't get a ride if you kept bad mouthing my choke setup....and now look. lol, nah you can try it out, if you can get it started.
Just relocating the test ride video to the end of the thread for easy finding in case you guys are gonna move it somewhere like you did with last years stuff.
-THIS BUILD IS COMPLETE-
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 16th 2016, 5:59 pm
I finally move it huehuehuheuhe
Unlocked.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 16th 2016, 11:29 pm
Thanks Doug.
Here's a few pics of the bump stop setup and also the front grill. This bar bolts onto the shock tower. Rubber spacer threads onto a bolt welded to the bar.
Mr.modified's GTR Four Zero - Page 10 IMG_4844_zpslt3g6jvd
Closer view of things. The tab with the hole is where the grill bolts on.
Mr.modified's GTR Four Zero - Page 10 IMG_4846_zps4mn5kheg
Grill was a belt guard on a walk behind mower. Has a little more weight to it than plastic or fiberglass, but it helps brace the bump stops when everything is bolted in place. Also added a front bumper/grab bar.
Mr.modified's GTR Four Zero - Page 10 IMG_4847_zpsdr9iqcqy
View of behind the grill.
Mr.modified's GTR Four Zero - Page 10 IMG_4849_zpslnfqmp0x
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 17th 2016, 9:34 am
Neat! Love the grill, got a nice curvy look to it. Is that opposed twin hard to pull start or not too bad?
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 17th 2016, 10:09 pm
Thanks, It's not so bad. I pull it up to top dead center before I pull it over. For the most part it starts pretty quick.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 19th 2016, 6:07 pm
Neat. I love how small and compact it looks but yet I bet it packs a punch!
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 19th 2016, 9:41 pm
Center of gravity is a little higher than it could be, but it's usable. Right now I'm mounting the gas tank and putting on a permanent drive chain tensioner to replace the wooden block I had. Probably in a few months I'll have it 100% done and be able to get a better video of it running.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 19th 2016, 10:09 pm
Its cause youre too tall lol.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 20th 2016, 2:27 am
Tall? Maybe thats sarcasm. lolol Razz
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 10 Icon_minitimeJanuary 20th 2016, 1:56 pm
I doubt that's the problem......
Page 10 of 13Go to page : Previous  1, 2, 3 ... 9, 10, 11, 12, 13  Next
» Redlinemotorspotts, Doug Fackler, and Mr.modifieds rompin' PA meet
