 Mr.modified's GTR Four Zero
Rockinator
STUNTMAN JON
chevy8988
MasonMcK
thewisconsinredneck5160
TheCollector
redzz02
McKmudder
RCTankboy
Deluxe66
rarbaugh07
Craftsman1998
jamcco
802 Customs
GenevaCustoms
mudman604
33 posters
Go to page : Previous  1, 2, 3, 4 ... 11, 12, 13  Next
Mr.modified's GTR Four Zero - Page 3 Empty
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 1st 2015, 11:06 pm
So to save weight, I bought the super budget stamped pillow blocks vs cast iron. They probably would bend and flex on their own, so I'll have to weld in some gussets. I would say they're a little heavier steel than exhaust pipe. Here they are under the frame which would be easier on the stamped bearing holders, but it makes the center of gravity way too high. The opposed is going to stick up pretty high as it is. Could have Z'ed the frame to drop it, but I didn't want to mess with that may cuts and angles.
Mr.modified's GTR Four Zero - Page 3 IMG_4027_zpszeqxw8pn
With the frame on top, you get a little more than 8" of ground clearance.
Mr.modified's GTR Four Zero - Page 3 IMG_4028_zps8e88nual
Frame underslung gives you about 5" of clearance. That should be plenty for some pretty rough terrain given how short the wheelbase is going to be. Obviously, your not going to be in the woods with it, but rough trails or rough gravel roads shouldn't be a problem.
Mr.modified's GTR Four Zero - Page 3 IMG_4030_zpsg7ocf6qu
This way the frame will be hanging off of the stamped pillow blocks. I think once I brace them up a bit, they should hold up ok. There will be a third bearing in the center next to the drive gear, I'll add an extention off the frame to mount it.
Mr.modified's GTR Four Zero - Page 3 IMG_4029_zpsdsgr364z
rarbaugh07
rarbaugh07
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 2nd 2015, 3:21 pm
I know you probably already know but some may not, It helps to drill slight indentations into the shaft for the set screws on the bearings. This helps to keep the shaft from sliding through the bearings. Just my 2¢
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 2nd 2015, 7:45 pm
Actually, I was going to weld a washer or something onto the axle to hold it since the bearings will be trapped with my setup anyway. I suppose the set screws might be enough to hold it if I put some indentations like you said. I guess I could try just relying on them first and weld something on later if they don't hold up. All my simplicity 5010 has to hold the front wheels on is a collar with one set screw, so I guess with two screws each in three bearings, that should be enough to hold the axle in place.
Deluxe66
Deluxe66
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 5th 2015, 4:36 pm
I can see flames coming from exhaust and stones flying from rear tires. Excelent idea me likes. Very Happy
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 5th 2015, 9:07 pm
And don't forget half the rear fiberglass fender flying around in the breeze from the trees you slid into on the last turn.
Guess your from finland, ever see much rally action before? I guess there is some rallying in the united states, but as far as I know, mostly on an amatuer level and I don't think it's too popular. Too many people complain about everything here I guess. Not much shutting down public roads in the U.S. for any kind of racing really since the early 1900's.
Hopefully I'll have all the pillow blocks braced up tommorrow.
Deluxe66
Deluxe66
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 6th 2015, 4:50 pm
From Finland yes. Seen rally action yes.
Sorry about writing offtopic. I am from middle Finland so about 20 miles to closest world rally action. Every summer here is world rally competition neste rally finland. I have not seen groupe b rally cars but maybe I will go to see some historic rally action. Under 50 miles from my home have lived or lives big rally names like Juha Kankkunen, Tommi Makinen, Harri Rovanpera and Mikko Hirvonen.
I will be watching this topic closely. Nice work so far.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 6th 2015, 11:09 pm
That's pretty neat. Nice to live close to things like that, makes it a lot easier to get there.
So... I welded up two of the three pillow blocks. Took a little longer than I thought it would. I think this probably falls into the category of "seemed like a good idea at the time." I guess it's not all that bad. We will see if they hold up or not. The bracing should be a big help. If they bend too bad, it's not the end of the world. I can always convert to cast iron pillow blocks later if I need to. I primed the one, figured I would top coat with grey or silver so when paint chips off the galvanized parts, you won't notice as much.
Mr.modified's GTR Four Zero - Page 3 IMG_4055_zps8ohd8bot
The original and modified versions. The ones I welded up look a little rough as far as the braces being the same size. The problem is cutting the pieces out, which are only about the size of a quarter and fairly thin steel. Tough to hold in a vice and cut them without bending. If your cut isn't right in the perfect spot when you start, it's pretty noticable since your working with such a small piece.
Mr.modified's GTR Four Zero - Page 3 IMG_4058_zps8vj66hzx
Started working on the exhaust ports. I've read the exhaust ports should be about 95-100% of the exhaust valve diameter. Probably talking about high rpm stuff of course, but I figured it's not going to hurt much either way to have the exhaust port too big when your headers will be larger than the threads. The most important thing is...it looks cool.
Mr.modified's GTR Four Zero - Page 3 IMG_4064_zpsnjxjyxbz
One exhaust port with pipe threads removed. Decent increase in diameter. Like I said, who knows exactly what changes help what. All of your performance books and junk are dealing with much higher engine speeds where sizes and shapes of things are more critical. So your kind of guessing as to what is going to help at fairly low lawn tractor engine speeds. My theory is that the intake port has more effect on things on an engine as "de-tuned" as these are. You could play around with things if you had a dyno and the patience.
Mr.modified's GTR Four Zero - Page 3 IMG_4060_zpsjmczsb2f
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 9th 2015, 9:24 pm
Started working on one of the junk cylinder heads to move the spark plug out into the middle of the combustion chamber. Carefully cut the fins and then broke them out of the way with needle nose plyers. Just needs to be wide enough for a plug socket.
Mr.modified's GTR Four Zero - Page 3 IMG_4073_zpsk9cmq2el
Marked out about where the plug will be and started cutting down what's left of the fins.
Mr.modified's GTR Four Zero - Page 3 IMG_4075_zpsaegpimuf
Now I can drill a hole and tap to the correct size, then try to get a flat enough surface for the gasket to seal. If it works out ok, maybe I will do another one and use them on the engine. If not I can use the stock heads. Takes quite a long time to cut the fins out of the way and flatten it off. I think it should be thick enough for the threads of the plug. I checked a head from a briggs 400cc single (12hp maybe). The four head bolt holes around the cylinder are the same, but around the valves are far off enough where you can't just drill new holes in the single head to make it fit an opposed. The holes would be right on the inner edge of the gasket surface. The original plug hole will be plugged off with a steel billet.
Mr.modified's GTR Four Zero - Page 3 IMG_4076_zpswhglb7z1
rarbaugh07
rarbaugh07
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 10th 2015, 11:02 pm
You can always use another spark plug to fill old hole just for testing.
PostSubject: runner porting   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 10th 2015, 11:46 pm
Got some tips for porting for you. I'll do the exhaust. It all comes down to your target rpm's, for low to mid range rpm you just want to clean up the bowl area with attention to the short radious, keeping the runner small and just cleaning up the high spots, the idea is to have the gasses move fast through a small pathway which will help draw in fuel/air on the overlap of cam. Mid range rpm you want to open up the bowl and runner evenly with attention to the short radious so when the exhaust valve opens, it will fill the bowl and then through the runner at ofcourse a faster speed, which in turn will help draw in more fuel/air on the cam overlap. At high rpm, open up the bowl with attention to the short radious with the runner opened up a little bigger then the bowl, this will establish flow direction and increase suction the most for the fuel/air charge on the overlap of cam. For extreme example of mixing up the port job, if you do a high rpm port job on a low rpm exhaust port, it will literally suck part of the fuel/air charge out the exhaust port, loosing power. You also want to match the pipe to the port to because a missmatch pipe will loose efficiency also. Small pipe for small runners with big pipe for large runners. Bad example of wrong pipe is a big pipe on a low rpm runner will have an effect of when the gasses exit the engine block into the big pipe will expand and create more suction then normal and suck some of the fuel/air charge out the engine before the exhaust valve closes. Hope it helps. Got tips on intake also if interested.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMarch 11th 2015, 1:16 pm
Barely any valve overlap with the stock cam. Pretty much just trying to get things where they should be for the stock rpm range. At least make some improvement anyway.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeApril 18th 2015, 8:59 pm
Finally got around to checking rod clearance for the heck of it. Looks like about .003
Mr.modified's GTR Four Zero - Page 3 IMG_4190_zpsv3ijse7f
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMay 10th 2015, 5:20 pm
Picked up this snapper that someone used for racing at one point. Had a single cylinder 2 stroke on it. Spindles look usable for the GTR and bearing hubs might be usable too. Front rims are bad so I would need to drill lug holes in the rims I have or find different wheels.
Mr.modified's GTR Four Zero - Page 3 IMG_4243_zpspris20xf
Front axle welded up from cast iron pipe by the looks of it. I drilled holes in the GTR frame to mount the rear axle bearings, so now I can start on the front suspension.
Mr.modified's GTR Four Zero - Page 3 IMG_4244_zpsmzffjwxg
RCTankboy
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMay 11th 2015, 1:14 pm
I have one of those Snappers, with a seized 11hp engine on it(I might have overstressed the engine when I swapped the 12hp carb on it without adjusting it downwards).
That thing is a freaking TANK, weighs as much as one, but tries to turn in its own length. I'm debating between junking it, putting my spare 12hp on it and continue using it, or stripping it for some future project. If I go for the last one, it may cause marital problems on the issue of storage.
The front end on this mower is bulletproof. Good choice if you ask me, but it is going to be heavy for your build.
I did see someone turn some of those pillow blocks sideways and use them for steering gear. Just a seed for an idea. Either way, I cant wait to see this build running.
802 Customs
802 Customs
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMay 11th 2015, 6:29 pm
This is coming along real well. That drilled out key is just too funny. Leave it to Porsche, I bet the blank costs 20x more than a regular Chevy blank even though it has less metal in it. Why? Because Porsche.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeMay 11th 2015, 8:53 pm
The steering knuckles on this snapper aren't real bad weight wise I don't think. They probably look bigger in the picutres than they actually are. I think they are go cart parts that they welded up. Got the front axle off the tractor and took the rims off. Hubs have sealed bearings I think and turn real easy for sitting outside for years. Front rims were split rims. Looks like it was fairly cheap parts to start with, kinda light looking. I'm going to cut the old axle maybe half an inch from where they welded it and weld in my A-arm tubes from there. I didn't really have a good plan for the steering before, these should work pretty nice. Just have to get some rims or make them up. Maybe this weekend I will start on the front end.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 1st 2015, 10:25 pm
Scavanged two pedals. These were E brake pedals from a mercury sable and a ford taurus around the same year. About the same car of course. I'll use these for clutch and brake. Just have to take the rubber off and then weld up my own stems for them.
Mr.modified's GTR Four Zero - Page 3 IMG_4287_zps9wdxkx8a
Made all eight billets for the suspension joints from nuts with the correct thread. Had to do some grinding. Now I can press them into the a-arm tubing and spot weld the inner one, then weld around the edge of the outter one. When they are inside the pipe, I'll have them arranged about how they are on the joint in this picture. I've got them so they press in pretty snug.
Mr.modified's GTR Four Zero - Page 3 IMG_4292_zpscsoaboru
What it will look like when it's all assembled. Joints will be both adjustable and replaceable if needed. Originally I thought I was going to have to step down a size with the pipe after the joint, but now I see how small/short the a-arms will be, I'll just stick with that size all the way to the spindle. Next step is to weld brackets to hold the joints on the frame, then put the a-arms together. After that I can deal with mounting the front shocks. That pipe is push mower handle, pretty thick wall stuff. Painted, but at least not rusty. I'll be painting it anyway later.
Mr.modified's GTR Four Zero - Page 3 IMG_4297_zpsgyeny2ge
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 11th 2015, 10:44 pm
Some slow progress. Working on some engine parts. Worst of the valves.
Mr.modified's GTR Four Zero - Page 3 IMG_4301_zps45wsmnui
Most of the other valves cleaned up ok. This one has some deep pits on the seat. I should have a good extra from my parts engine.
Mr.modified's GTR Four Zero - Page 3 IMG_4307_zpsg5g0ckwh
Drilled a pilot hole in the experimental head. Here is where the plug is supposed to end up. Been trying to get a 14mm x 1.25 tap for a few days...
Mr.modified's GTR Four Zero - Page 3 IMG_4308_zpszkrkw5vs
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 17th 2015, 5:29 am
Nice progress, I'm following most builds, but hard to comment on everyone.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 19th 2015, 7:30 pm
Thanks, good to see your still around. I'd like to spend some more time messing around on here myself, but I've been relatively busy. Hopefully I'll have the main parts of the front suspension roughed out in the next few days.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 20th 2015, 9:27 pm
Finally some work getting done at the GTR research and development facility. Measured things out on cardboard so I would have a flat surface to work on and also so I could tack weld things without getting weld splatter on the frame. Trying to keep the inside of the tires out 1.5" from the main sides of the frame rails.
Mr.modified's GTR Four Zero - Page 3 IMG_4320_zpsrb0unyfq
Cut some tubing from the push mower handle. Set the billets and joints in the tubes without welding.
Mr.modified's GTR Four Zero - Page 3 IMG_4321_zpsiqodio25
Steering will be in front of the suspension. Threaded rod holds everything in place while trying to line it up.
Mr.modified's GTR Four Zero - Page 3 IMG_4322_zpsjf7xh88f
Welded the tubes together in the center and tacked some places. The spindle bolt/king pin (whatever it's called) is set in place to help keep things square. Had to eye ball things because there isn't an easy way to measure it out. Bunch of different angles at once.
Mr.modified's GTR Four Zero - Page 3 IMG_4323_zpsxu9tpgnp
Ended up with a usable part (I think). Close to being pretty straight and where I wanted it.
Mr.modified's GTR Four Zero - Page 3 IMG_4328_zpsd95jyyr8
Next to cut out and drill the brackets that will hold the joints. Then weld to the frame. I think the best way to go about it would be to weld on the brackets for this side and also the opposite side so they match on the frame. Then make the opposite a-arm to fit. I've gotta get moving on this thing or I'll never be done by the cut off. Still all that fiberglass work to do at the end...
Mr.modified's GTR Four Zero - Page 3 IMG_4329_zps6ei9ugxj
rarbaugh07
rarbaugh07
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 22nd 2015, 9:01 pm
Just a heads up but the tie rod needs to be wider than steering knuckle pivot if infront of the axle. To keep the Ackerman angle in check.
rarbaugh07
rarbaugh07
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 22nd 2015, 9:02 pm
It does look friggin sweet tho.
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJune 23rd 2015, 9:32 pm
Thanks, and thanks for the steering info, I have a rough idea of how it will go. Hopefully it won't be too hard to set up.
Drilled holes for the a arm brackets.
Mr.modified's GTR Four Zero - Page 3 IMG_4332_zpszbicptv8
Eight total plates. 1/8" steel I think it was.
Mr.modified's GTR Four Zero - Page 3 IMG_4334_zpsvmam3j9l
My cuts didn't come out perfect, so I had the idea to bolt all the plates together and true them up with a grinder. Worked ok.
Mr.modified's GTR Four Zero - Page 3 IMG_4335_zpsyrxmx3vd
Got them welded on one side of the frame. I was having a bad day welding though, beads didn't come out too nice. Outside two plates will have a gusset later. Of course if you Look at how the a arm will move in the brackets because of the almost 45 degree angle, you'll realise that the joints will be twisting sideways when the a arm moves up and down. There isn't much room for movement before the joint bottoms out against the brackets. This isn't ideal, but won't really be an issue because I only need about 1.5-2" of suspension travel at the wheel.
Mr.modified's GTR Four Zero - Page 3 IMG_4337_zpsp1qh126j
Started welding the nuts in the ends of the tubing. Back one has 3 spot welds in a triangle around the pipe, outside one is just welded around the edge. Have to at least tack them in place while a bolt or one of the joints is threaded in to keep the threads lined up. I'm going to leave the spot weld bumps stick out instead of grinding them smooth because for some reason I think it looks cool that way. Like a factory made part almost. Except the disaster area where the pipes join together, that will clean up later once I cover it up with some gussets and the shock mount.
Mr.modified's GTR Four Zero - Page 3 IMG_4336_zpszmwbsu7h
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJuly 5th 2015, 10:15 pm
Starting on the other side
Mr.modified's GTR Four Zero - Page 3 IMG_4353_zpsmuwhzlhd
Second A-arm mocked up
Mr.modified's GTR Four Zero - Page 3 IMG_4354_zpsiddevmki
Marked with white out for cutting
Mr.modified's GTR Four Zero - Page 3 IMG_4355_zps9bmjbuzg
The horrible mess before plating over. Things don't fit too good here, but I finally got it hooked together pretty good.
Mr.modified's GTR Four Zero - Page 3 IMG_4357_zpsnzx1y2jf
Everything welded up and smoothed out. Should be enough to hold it.
Mr.modified's GTR Four Zero - Page 3 IMG_4358_zps5cnmojyb
Also I had better luck welding this time. Went back over some of the welds on the first side I did too. Now everything is about how it should be. Next to do is drill the holes in the A-arms for the spot welds and weld in the threaded billets. After that, front wheels and shock mounts. Gotta organize my shop and get back on the engine and trans too.
Mr.modified's GTR Four Zero - Page 3 IMG_4359_zpsi2a3xgj3
PostSubject: Re: Mr.modified's GTR Four Zero   Mr.modified's GTR Four Zero - Page 3 Icon_minitimeJuly 5th 2015, 10:41 pm
Nice lookin A-frames. Was everything TIGed up? Looks like pretty clean welds with no spatter all over.
Page 3 of 13Go to page : Previous  1, 2, 3, 4 ... 11, 12, 13  Next
» Redlinemotorspotts, Doug Fackler, and Mr.modifieds rompin' PA meet
