| Snowblower issues | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4951 Posts : 919 Location : Defiance, Ohio
| Subject: Snowblower issues November 6th 2014, 12:14 pm | |
| Welp after last winter we decided to get a snow blower for the craftsman. Woo cool right? nah We got it together and all that fun junk pulled it onto the pad and pulled the clutch engagement only to be severely disappointed. The engine just dies when the clutch is engaged even at high rpms it goes kerput, mind you this is a 25hp kohler so theres no shortage of power at wits end though with it so info would be appreciated | |
| Subject: Re: Snowblower issues November 6th 2014, 2:41 pm | |
| Pictures of the attachment and setup?
Sounds like its one or the other, like bearings in the attachment or the motor has no power. Can you turn the snowblower over by hand easy? | |
| | | | Doc Sprocket Site VIP
| Subject: Re: Snowblower issues November 6th 2014, 2:57 pm | |
| Pretty much what Red sed. Make sure everything spins freely. If not, engine may be in worse shape than you thought. | |
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| Subject: Re: Snowblower issues November 6th 2014, 3:52 pm | |
| check for safety switches, bypass them all, and look for other electrical gremlins. | |
| Subject: Re: Snowblower issues November 7th 2014, 1:21 am | |
| Well the bearings are fine it spins like a top engine doesn't smoke and was spinning a 50 some inch deck last week mowing like a boss I'd get pics but there's to much crap in the way and tomorrow is D-day for a possible hernia :/ will see what happens
It's a 01 gt 5000 and 42" 2 stage blower | |
| Subject: Re: Snowblower issues November 7th 2014, 7:35 am | |
| I wonder if you have a gearing problem. If it's just kinda cobjobbed together, perhaps you've got 'er geared too high? | |
| | | B440 Member
Join date : 2014-01-22 Points : 4204 Posts : 226 Location : Thompson, CT
| Subject: Re: Snowblower issues November 8th 2014, 4:59 pm | |
| Single stage or two stage blower? I would suspect the worm gear first if it's a two stage. | |
| Who is online? | In total there are 34 users online :: 0 Registered, 0 Hidden and 34 Guests
