| Project Frankenstein Racemower | |
+6Craftsman1998 chevy8988 ZSmachines LAWN MOWER MUDDER Ghyde97 Thunderdivine 10 posters | |
chevy8988 Member
| | | | MatthewD Veteran Member
Age : 23 Join date : 2014-11-16 Points : 5756 Posts : 1993 Location : Northern Ireland
| | | | chevy8988 Member
Age : 24 Join date : 2014-08-17 Points : 3865 Posts : 93 Location : Fulton, Kentucky
| | | | TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5704 Posts : 1091 Location : Galion, OH
| Subject: Re: Project Frankenstein Racemower August 12th 2015, 11:32 am | |
| I didn't see it already mentioned, but if you're wanting to go any faster, some major steering / front end upgrades are going to be needed. Your tie rods should be updated, as they will be the cause of most slop, and will be the most likely part to fail at speed. The high camber / zero caster front end is fine for mowing but will get squirrelly as heck around 20+ mph... There are threads on here somewhere about steering geometry. Fixing this takes effort and / or money, but not more than your hide is worth All in all, you do have a nice start! Keep up the good work! | |
Age : 23 Join date : 2013-04-08 Points : 5212 Posts : 913 Location : Central Pa
| Subject: Re: Project Frankenstein Racemower August 12th 2015, 7:32 pm | |
| - MatthewD wrote:
- Sweet! Got to get me one of those sometime! What transaxle does it have?
Those snapper tractors had a variable disc drive. Sort of like the snapper rear engine riders. Doesn't have a trans axle. | |
| | | chevy8988 Member
| Subject: Re: Project Frankenstein Racemower August 14th 2015, 11:45 pm | |
| The rear end is almost exactly like a rear engine snapper except its has a drive shaft that comes from the front on mine instead of one that comes straight down like a rear engine snapper. And the only problem I have with the race mower is the belt layout which I think I might have finally figured out, I'm probably just gonna run it directly from the engine to the trans-axle , no clutch because when I had a clutch I never used it any way because it doesn't jerk very much at all and if I tried to use the clutch the belt would usually come off no matter how many retainers or tensioners I had. | |
| | | | chevy8988 Member
| Subject: Re: Project Frankenstein Racemower October 26th 2015, 11:35 pm | |
| How hard would it be to run a clutch and chain from my engine to my transaxle, would having it upside down like that make it easier for it to fall off? | |
| | | chevy8988 Member
| | | | prancstaman Veteran Member
Join date : 2015-02-02 Points : 5099 Posts : 1412 Location : Cleveland,Ohio
| Subject: Re: Project Frankenstein Racemower April 10th 2016, 5:44 pm | |
| Good thinking on the racer's back tires on shaving the turf savers. Now you got a good paddle wheel for mud racing. like the big rear bumper sticker too. | |
| | | AllisKidD21 Moderator
Age : 25 Join date : 2016-07-10 Points : 8590 Posts : 5190 Location : Ontario Canada
| | | | chevy8988 Member
| Subject: Re: Project Frankenstein Racemower September 12th 2016, 3:33 pm | |
| Oh, that makes sense. Looks pretty cool! "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
| Who is online? | In total there are 19 users online :: 0 Registered, 0 Hidden and 19 Guests
