| Project Frankenstein Racemower | |
+6Craftsman1998 chevy8988 ZSmachines LAWN MOWER MUDDER Ghyde97 Thunderdivine 10 posters |
chevy8988 Member
![chevy8988](https://2img.net/u/2812/37/66/46/avatars/1908-7.jpg)
Age : 24 Join date : 2014-08-17 Points : 3788 Posts : 93 Location : Fulton, Kentucky
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Project Frankenstein Racemower October 26th 2014, 5:12 pm | |
| I just repainted Project Frankenstein, so here are the before and after pictures. Before. ![Project Frankenstein Racemower 10345514](https://i.servimg.com/u/f39/19/03/73/93/10345514.jpg) After. ![Project Frankenstein Racemower 10690010](https://i.servimg.com/u/f39/19/03/73/93/10690010.jpg) | |
Thunderdivine Veteran Member
![Thunderdivine](https://2img.net/i/fa/i/avatars/gallery/Cine_Seigneur_des_anneaux/Lotr_129.jpg)
Join date : 2012-12-21 Points : 6469 Posts : 2101 Location : Norway, Europe
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | |
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower October 27th 2014, 5:16 pm | |
| The steering wheel is two fourwheeler chains that I welded up and I melted the center out of the stock plastic steering wheel and welded it in the center of the chain steering wheel.
Ghyde97 Member
![Ghyde97](https://2img.net/u/2812/37/66/46/avatars/1937-51.jpg)
Age : 26 Join date : 2014-09-09 Points : 3719 Posts : 63 Location : Jacksonville fl
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower November 10th 2014, 2:59 pm | |
| Thanks, used the rim of a 12 in subwoofer to hold the chain in a circle and then i tack welded it and removed it from the sub and finished welding it up. And the paint job was just 2 cans 0f 0.99 cent spray paint from lowes with a 3.00 dollar can of clear coat. | |
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower November 11th 2014, 2:27 pm | |
| Hey Thunderdivine, would it be a good idea to put my engine in sideways because when i put my front axle on top of the frame to lower it took up too much space to put it in normally. | |
![LAWN MOWER MUDDER](https://2img.net/u/2812/37/66/46/avatars/825-65.jpg)
Age : 23 Join date : 2013-04-08 Points : 5135 Posts : 913 Location : Central Pa
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower November 11th 2014, 2:58 pm | |
| Redlinemotorsportts put his oppy in sideways. As long as your fuel lines and wiring is long enough, go for it! | |
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower November 11th 2014, 3:28 pm | |
| Yeah why not, I know many that have it sideways including red on here.
Edit: nvm was thinkin you had an oppy to.
Can't you rotate the engine 180 degrees instead?
Last edited by Thunderdivine on November 11th 2014, 3:40 pm; edited 1 time in total (Reason for editing : Oh thought you had an oppy also, lol) | |
chevy8988 Member
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower November 11th 2014, 4:32 pm | |
| - chevy8988 wrote:
- Can't do that because the steering rod is in the way.
Well then just go for it sideways - chevy8988 wrote:
- Would I have to get special permission to stencil "ATLTF.COM" on to my race mower?
And ofcourse not. | |
chevy8988 Member
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower December 1st 2014, 8:51 pm | |
Would it be a good idea to use a small pushmower engine for this project? It shouldn't need much power for the lightweight chassis.
ZSmachines Member
![ZSmachines](https://2img.net/u/2812/37/66/46/avatars/1923-36.jpg)
Age : 25 Join date : 2014-08-27 Points : 3918 Posts : 221 Location : PNW
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower December 1st 2014, 9:45 pm | |
| I Would say go for it as long as it is 6hp or more, and that would definitely cut down on fuel cost and weight! | |
chevy8988 Member
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower January 4th 2015, 11:31 pm | |
| I finally got around to doing some work on the race mower. Different tires on the rear, and rebuilt custom steering wheel. Im takin the dana spicer 5 speed out of the offroad mower to put into the race mower along with the 17.5 hp OHV from the offroad mower. The offroad mower is gonna be used for parts becuase I dont have time for two projects at once.
Non working pictures removed- Willis923 3/2/2015 | |
chevy8988 Member
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower January 28th 2015, 1:51 pm | |
| I wont be able to post pictures for a while but i finally got the racemower running all that left is theshift linkage. | |
chevy8988 Member
![Project Frankenstein Racemower Empty](https://2img.net/i/empty.gif) | Subject: Re: Project Frankenstein Racemower February 24th 2015, 7:23 pm | |
| Im finally almost done with the racemower i just need to make some belt retainers. this thing probably does about 20 with the current pulley ratio, not sure what the sizes are, i will eventually swap it to go faster, hoping for 40-45. it has already tried to kill me multiple times during test drives and i have crashed it twice. Modifications since the last post i made: -rims -tires -transaxle(now a spicer 5 speed) -6.5 hp predator 173cc engine -custom belt system -new steering wheel -paint -vise grip shifter ![Project Frankenstein Racemower DSCF0047_zps2ihzsnfd](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0047_zps2ihzsnfd.jpg) ![Project Frankenstein Racemower DSCF0035_zpsxfsjnhxc](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0035_zpsxfsjnhxc.jpg) ![Project Frankenstein Racemower DSCF0034_zpsy3xv19rm](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0034_zpsy3xv19rm.jpg) ![Project Frankenstein Racemower DSCF0033_zpscowuneo6](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0033_zpscowuneo6.jpg) ![Project Frankenstein Racemower DSCF0032_zpsfo4rb4av](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0032_zpsfo4rb4av.jpg) ![Project Frankenstein Racemower DSCF0031_zps2prow7pm](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0031_zps2prow7pm.jpg) ![Project Frankenstein Racemower DSCF0030_zpsvfx1vy9l](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0030_zpsvfx1vy9l.jpg) ![Project Frankenstein Racemower DSCF0029_zpsrdt0qmff](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0029_zpsrdt0qmff.jpg) ![Project Frankenstein Racemower DSCF0028_zpslsftaaob](https://2img.net/h/i357.photobucket.com/albums/oo19/chevy8988/DSCF0028_zpslsftaaob.jpg) | |
Craftsman1998 Veteran Member
![Craftsman1998](https://2img.net/u/2812/37/66/46/avatars/1167-45.jpg)
Age : 26 Join date : 2013-10-30 Points : 5078 Posts : 1068 Location : New jersey
chevy8988 Member
chevy8988 Member
