| my bayou 300 | |
+2redlinemotorsportts DirtyD 6 posters |
DirtyD Vendor
| Subject: my bayou 300 August 5th 2014, 3:44 pm | |
| Well I figure I would start a topic over here. I have a 1995 Kawasaki Bayou 300 4x4. As of right now she is stripped down to just frame I have "new shocks" on order. For the rear I am going to try and run a set of Honda 450R front shocks. Here are the shocks for the rear. and here are the shocks I am going to try to run on the front. These shocks should give me about 2" of lift. and they are adjustable which I like. I know I could have just ordered a 2" lift for it and call it a day. but I like standing out. :'D once they get here and I get them mounted I will take some pics and update this. | |
DirtyD Vendor
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: my bayou 300 August 8th 2014, 12:08 am | |
| Those look pretty fancy with the reservoirs! How are those 489's working for yea? | |
DirtyD Vendor
| Subject: Re: my bayou 300 August 8th 2014, 1:10 am | |
| Thanks, and idk about the tires, they came with the atv. and i really haven't rode it with them. | |
Age : 23 Join date : 2014-01-22 Points : 4574 Posts : 546 Location : north carolina
| Subject: Re: my bayou 300 August 8th 2014, 9:44 am | |
| ive always liked the bayous im watching this thread and are you in the army | |
DirtyD Vendor
| Subject: Re: my bayou 300 August 9th 2014, 12:39 am | |
| Yep, and this is my first bayou.. so we will see how it goes. | |
DirtyD Vendor
| Subject: Re: my bayou 300 August 9th 2014, 12:47 am | |
| There is one problem I see with this build so far.. maybe someone here could give some feed back on it.. I know when I install new shocks up front my tires are going to go | | to \ / . I was thinking about getting some "new" lower A-arms from a different atv that are slightly longer. or having mine made a tab bit longer. | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4954 Posts : 919 Location : Defiance, Ohio
| Subject: Re: my bayou 300 August 9th 2014, 1:00 am | |
| looking good would look even cooler if you mounted it all on a tractor lol | |
DirtyD Vendor
| Subject: Re: my bayou 300 August 9th 2014, 1:01 am | |
| oh when i get back to the mainland ill be starting on a mower build. | |
DirtyD Vendor
DirtyD Vendor
| Subject: Re: my bayou 300 August 13th 2014, 10:48 am | |
| I like the last ones lol adjustable ride is usually nice and their cheaper | |
DirtyD Vendor
| Subject: Re: my bayou 300 October 26th 2014, 6:40 pm | |
| For the front I end up running a set of Yamaha Banshee So far for engine upgrades I have installed a cam from a lakota. I plan on boring the jug later on down the road. I also plan on doing a K&N filter and jet kit. I have a spare head I plan on port n polishing and installing a bigger cam also (some other time) This is where I am at in this build so far. I still need to order wheel spacers, 12" rims, 27x?? tires, Primary clutch, gasket kit, and put a new exhaust on it. | |
DirtyD Vendor
| Subject: Re: my bayou 300 October 31st 2014, 3:34 pm | |
| Got a little work done (kinda) the old primary wet clutch was so shot i could pull the springs out with no problems so i took it apart and here is what the clutch looked like. Here is the one I got from ebay. It came with the housing and all so I can going to swap it all over. I also scored this on ebay. It shipped out today so the wait game starts. | |
DirtyD Vendor
| Subject: Re: my bayou 300 November 16th 2014, 9:22 am | |
| More importantly, how's it sound? How's the state treating you out there? | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: my bayou 300 November 16th 2014, 11:23 am | |
| you dont need that exhaust, mail it to me instead
DirtyD Vendor
| Subject: Re: my bayou 300 November 16th 2014, 3:53 pm | |
| I am wanting to do a snorkel, what would be the a right size tube/pipe to use and or how many? I was thinking about bring two 1" out of the stock holes in the lid.... would that be enough air flow? I figure the stock holes where good from the factory. I mean, hell idk what im doing this is my first homemade snorkel. | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7321 Posts : 2914 Location : Ontario Canada
| Subject: Re: my bayou 300 November 16th 2014, 7:08 pm | |
| 2x1" might be okay, but I'd be inclined to go bigger than that. Why? Well, you're adding pipe length, which equates to static pressure (kinda back pressure in reverse), but a restriction to flow, nonetheless. Said and done, I'd do a plug chop and see if re-jetting might be a good idea, especially considering the new exhaust, too. | |
DirtyD Vendor
| Subject: Re: my bayou 300 November 16th 2014, 7:21 pm | |
| I found that the 99+ bayou's have a "O.E snorkel" So i am thinking about getting that airbox and piping, still have to plug the top. but i figure it would work better than my idea. here is a stock 99+ bayou 300 airbox and the "snorkel" that I will extend I also plan on installing a oil catch can on this when i snorkel it. Since I will be running all the piping to the front. I am also going to re-jet and to the plug chop. but before I do that i am getting a 335 bore kit for it. | |
| my bayou 300 | |
