 kawasaki 220 Bayou
tntchitwood
kawasaki 220 Bayou Empty
PostSubject: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 28th 2012, 7:26 am
This is what is left of a chopper I built over the winter. It is an 800 suzuki.
kawasaki 220 Bayou July-Nov2008010
I needed a motor for my 220 bayou.....so there you go! I have the motor mounted, now there are about a million other things to get it finished. I think it will turn out pretty cool though.
kawasaki 220 Bayou July-Nov2008003
Check out some of the stuff I have built over the years on my youtube channel......tntchitwood.
matthew sidor
matthew sidor
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 28th 2012, 8:26 pm
Is the motor off the chopper driveshaft because i see that the kawasaki bayou is, and if it isn't how are u gonna get past that problem.
Jamus
Jamus
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 28th 2012, 9:17 pm
Cool project. I have a parts bayou and am looking at getting a runner. You don't see much about them, either stock or modified.
http://www.rcbashers.com
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 7:21 am
They are both driveshafts. It will be as simple as connecting the two with a home made shaft.
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 7:26 am
What do you need to make yours a runner? I still have everything for this one, The motor needs rebuilt though. It had no compression.
Jamus
Jamus
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 8:40 am
Locked up motor, no seat, no wiring, pretty much just a parts bike. I have a cheap running one lined up, just haven't had time to go check it out.
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 4:01 pm
Got the back bone (top) of the frame, the tank mounted, and the steering done today. It is all just tacked together right now. I guess I will connect the two drive shafts next.
kawasaki 220 Bayou July-Nov2008013
kawasaki 220 Bayou July-Nov2008012
What do you all think?
matthew sidor
matthew sidor
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 5:11 pm
looks good once u get all those wires hooked up and hidden. Are u gonna put any of the plastics back on.
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 29th 2012, 7:27 pm
More than likely I will put some of the body back on.....only with severe fender trimming. I want it to have a "sporty" look and the stock bayou plastic is anything but "sporty". I also don't want to cover any of the motor because that is the coolest thing about this bunch of junk.
Here is a pic with the rear plastic on. The front will not fit in any way form or fashion. Also there will be a radiator on the front.
kawasaki 220 Bayou July-Nov2008014
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeJuly 30th 2012, 5:49 pm
HMMM........ 92 views and only two responders.................. HMMMM,Tough crowd. Sleep
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeAugust 1st 2012, 7:42 pm
Have those rear tires seen any mud? I bot a pair of similar ones ( wooley boogers) at a flea market for $25 - wondered how well they work- plan on putting them on my trail GT murray ( when i get around to it).
tntchitwood
PostSubject: Re: kawasaki 220 Bayou   kawasaki 220 Bayou Icon_minitimeAugust 2nd 2012, 11:40 am
Those tires are AWESOME! I used to follow the big boy 4-wheelers around on my little bayou.
kawasaki 220 Bayou
» my bayou 300
» bayou 4x4 selector
» 76' Kawasaki KZ750
» 1980 kawasaki klx250
» Kawasaki's FORD F-100 restoring project
