| | Sombody help! Peace of junk V-Twin!! | |
+5Angchor B440 redlinemotorsportts richie thomas CornShuck4CE 9 posters | |
CornShuck4CE Member
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 12:03 pm | |
| - T-Dub13 wrote:
- So, when the governor calls for more throttle (power to run an accessory) the throttle opens more than usual during just riding around. Sounds like it runs fine on the pilot jet, but when the throttle opens enough to call for fuel from the main jet, it's getting too much fuel.
Or it's not able to ignite the charge because of a weak ignition. Either problem can make it seem like it's flooding out.
Make sure your spark plug gaps are no more than .020".
Check your spark plug wires and plug caps to make sure they're not arc'ing out anywhere, sometimes on the shroud or fins...
Does it blow black smoke when it's blubbering and struggling? If so, it's still too much fuel.
Try running without an air filter to see if there's a change.
Keep us posted! Been running no filter the whole time. New plugs swaped the coils to opposit sides. There still firein. Beleave me it will light you up pull the wires as its miss firein and the left cylinder settin on the mower runs dead but plug still fires. I o no. Still messin with it. | |
Age : 23 Join date : 2013-04-08 Points : 5143 Posts : 913 Location : Central Pa
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 3:03 pm | |
| Does the plug fire when it is in compression? (It takes more voltage to fire in compression than in when not in compression)
Do both sides have equal compression?
Are the plugs wet?
| | | CornShuck4CE Member
Age : 35 Join date : 2014-04-07 Points : 4170 Posts : 337 Location : Woodville Al
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 3:08 pm | |
| - LAWN MOWER MUDDER wrote:
- Does the plug fire when it is in compression?
Are the plugs wet?
Ill have to get back on that but. The compresion seems good. Need to get back to dis thing aint messed with it in a week or two | |
| | | T-Dub13 Established Member
Age : 54 Join date : 2013-12-06 Points : 4506 Posts : 540 Location : Central MA
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 3:30 pm | |
| Yep, that's what I was trying to say about weak ignition: A plug will spark out of the machine, but if the ignition is weak, gap too big, or if there's a leak in the insulation letting it arc out on something, then it won't fire inside the motor under compression. Think about it this way: If a motor is 10:1 compression, then the spark has to jump through 10 times more air with the same gap. That's why it can be deceiving sometimes checking with the plug out of the machine. | |
| | | CornShuck4CE Member
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 3:42 pm | |
| Yup did that and i understand all that. Thats why i swaped the coils to see if the coil was bad. If it was a bad coil it would have acted up on other cylinder with sam e coil. But no still missing on the same cylinder. | |
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 5:32 pm | |
| Is your connecting rod and push rods ok? We just had one exactly the same come in with a bent push rod the other day at the shop. | |
| | | CornShuck4CE Member
| | | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4353 Posts : 491 Location : Index, Washington
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 7:21 pm | |
| - CornShuck4CE wrote:
- Aint tore into it but i dont think so. I may have a valve problem
A pushrod problem would be a valve problem. | |
| | | CornShuck4CE Member
| | | | redlinemotorsportts Moderator
Age : 27 Join date : 2013-03-18 Points : 7417 Posts : 3131 Location : raleigh nc
| Subject: Re: Sombody help! Peace of junk V-Twin!! August 27th 2014, 8:32 pm | |
| I dont know how a bent pushrod would cause this but i do believe its int the valve train.
I heard a story about a tractor breaking the crank right at the front before the timing gear. It idled, drove, but reved up like crap. Highly unlikely, but possible i guess. | |
| Who is online? | In total there are 20 users online :: 1 Registered, 0 Hidden and 19 Guests ranch king pro 08Most users ever online was 412 on January 7th 2023, 7:59 am |
