| Speed Lever - Can I remove it | |
+3willis923 Doc Sprocket Phatmatt 7 posters | Author | Message |
Phatmatt Member
Age : 35 Join date : 2014-07-09 Points : 3830 Posts : 26 Location : Canada
| Subject: Speed Lever - Can I remove it July 19th 2014, 10:04 am | |
| While Lowering my rear end yesterday, I've noticed that the speed lever is attached to the clutch/brake pedal shaft. What does it actually do? Tighten the clutch so it gets better grip? Anyways can I simply remove it? And what are the consequences? The setup is in the way of the tranny, and If I don't really need it I don't want to relocate it. | |
| | | Doc Sprocket Site VIP
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 1:15 pm | |
| - willis923 wrote:
- If its there, its there for a reason
So is the cutting deck, the seat switch, and the dashboard throttle lever... NEXT!!! LOL | |
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 3:08 pm | |
| - Doc Sprocket wrote:
So is the cutting deck, the seat switch, and the dashboard throttle lever... NEXT!!! LOL But you don't NEED any of that.. Kinda need a 'speed control lever' Gotta go fast! | |
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 3:19 pm | |
So is the cutting deck, the seat switch, and the dashboard throttle lever... NEXT!!! LOL But you don't NEED any of that.. Kinda need a 'speed control lever' Gotta go fast! na, i think its like the governer, you could use it, but it aint needed LOL the lever your talkin about is basically how you "shift" gears on mtd's it controls the belt tension, which when in corralation to the sucky (in my opinion) vari-drive speeds it up and/or slows it down. budy of mine disabled it and then used a smaller rear pulley and a biger front pulley, but left the rest of the vari drive set up, it ran decent, but the rpms ended up controlling the speed | |
| | | Doug Site Owner
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 3:30 pm | |
| The speed lever stops the CVT from moving so it stays "in gear". If you remove it the speed wont function right and it will be stuck in either 7th or N, I cant remember which. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| | | Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4419 Posts : 491 Location : Index, Washington
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 3:41 pm | |
| - Doug Fackler wrote:
- The speed lever stops the CVT from moving so it stays "in gear". If you remove it the speed wont function right and it will be stuck in either 7th or N, I cant remember which.
From what I have seen lately, it looks like it would sort of 'float' around 3rd gear. With as Richie pointed out, the actual speed being determined by the RPM of the engine. The clutch pedal could slow you down or speed you up, as well. | |
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 3:50 pm | |
| the way his drove, it was good for speed, say if you want to dragrace, or just do straights, but it would suck in the corners, the damn thing would haul ass, ive actually thought about building a drag racer from a mtd gt rearend so i would have 2 "gears", but thats a project for later
| | | Phatmatt Member
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 7:38 pm | |
| Ok, makes sense. Now if I was to change the pulley and put like a 3" pulley and remove that selector. it would pretty much always in the the same "gear" and the throttle would pretty much decide how fast I want it to go..
I have a MTD vari-drive something like that (#MTD 717-764). I could just change trannys, I Havent heard much good out of them. lol.
Too bad since the other day there was a peerless at the junkyard but it had a hole in the casing :/ | |
| | | Phatmatt Member
| | | | Doug Site Owner
| Subject: Re: Speed Lever - Can I remove it July 19th 2014, 9:11 pm | |
| Peerless MST205, MST 206, 820, 930, 633a (horizontal input, 5 lug hubs)), 2300(horizontal input, 5 lug hubs). Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
Age : 25 Join date : 2013-04-05 Points : 4962 Posts : 661 Location : New Smyrna Beach,Fl
| Subject: Re: Speed Lever - Can I remove it July 20th 2014, 2:53 pm | |
- Peerless MST205, MST 206, 820, 930, 633a (horizontal input, 5 lug hubs)), 2300(horizontal input, 5 lug hubs).
forgot 801s | |
| Who is online? | In total there are 80 users online :: 0 Registered, 0 Hidden and 80 Guests
