| My 6211 simplicity dozer build | |
+7willis923 Angchor Moose B440 camomanusa TokyoDrift99 1997 Murray 11 posters |
1997 Murray Veteran Member
| Subject: Re: My 6211 simplicity dozer build July 23rd 2014, 9:17 am | |
| yeah, I know Ive been gone for a wile, but I put wheels on the wheele bars and made a weight rack on the front, and now i'm cutting my tires for traction. I ended up getting a full- time job on a farm so I don't have much time for the internet or tractors but the show is in 7 days so I got to get moving fast. | |
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
| Subject: Re: My 6211 simplicity dozer build August 29th 2014, 10:45 am | |
| well... I gave in and shelled out $171 for a pair of 25x12.5x12 kenda bearclaws last night. this is the first time I have bought new tires for one of my rigs. | |
Age : 27 Join date : 2013-03-18 Points : 7486 Posts : 3131 Location : raleigh nc
| Subject: Re: My 6211 simplicity dozer build September 5th 2014, 6:16 pm | |
| I don't think it is a peerless, cause it is cast iron. I think simplicity made it, and it has 1" axles, and it is a 3 speed H-pattern shift, no shift keys. | |
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4954 Posts : 919 Location : Defiance, Ohio
| Subject: Re: My 6211 simplicity dozer build September 6th 2014, 12:22 am | |
| peerless made cast iron 3 speeds Im gonna guess and say peerless 2300? Doubt the 1200s were 1" axle but I could check mine | |
ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3995 Posts : 221 Location : PNW
| Subject: Re: My 6211 simplicity dozer build September 11th 2014, 12:21 am | |
| Dang! I need to get my ducks in a row so we can go wheelin sometime! And do youthink that if i ran some ready rod through the holes in the wheels i could make duals that way?
ZSmachines Member
ZSmachines Member
| Subject: Re: My 6211 simplicity dozer build September 12th 2014, 6:08 pm | |
| New exhaust looks great, but with my knowledge and experience with the oppy, i would recommend a bigger pipe, maybe 2 - 2/12 inch... | |
| Subject: Re: My 6211 simplicity dozer build September 13th 2014, 9:23 am | |
| yeah, when I go to work today I will look for larger pipe. this was all that I had. I think I will build stacks for this. | |
ZSmachines Member
| Subject: Re: My 6211 simplicity dozer build September 13th 2014, 7:19 pm | |
| Naw, no stacks... Its a plow tractor so unless they will be way a ove your head you wont like them... The noise and exhaust fumes will be right in your face. Thats why the stack on my bolens is so big. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: My 6211 simplicity dozer build September 14th 2014, 1:54 am | |
| personally, i would stack it. make it about 6 inches taller than your head. pop inline, cylinder style mufflers in there, and that would be sick. put a 90 on the end and cut it like i did with mine. blows the mung away from you, looks cool, sounds good | |
