| homemade mini dozer | |
+13Double W Cross Ranch Hillbilly Homer hotrod-craftsman MatthewD RichieRichOverdrive George Gooding AllisKidD21 prancstaman Camdg2010 Crazy_Carl muckmudd frostypaws MightyRaze 17 posters |
Camdg2010 Member
| Subject: homemade mini dozer July 18th 2018, 9:52 pm | |
| Hello everyone! its been a long long time since ive been on here. Ive been working on a few projects the last few years. And as many people dont know, I have a thing for tracks! here is a few pictures of my current build. Its utilizing 2 zero turn wheel motors, 1 snowmobile track cut down the middle, 1 set of snowmobile drive cogs drilled to fit the factory zeroturn wheel hub (1 on each side) 1 early 2000's craftsman frame A whole bunch of 1 1/4 square tube So far only (4) 5" front lawnmower rims 3/4 all thread with a nut welded to the ends as wheel pins/axles (has lock nut on other side) my 18 hp briggs and stratton opposed twin Hood and grille off an 80's Montgomery Wards mower painted to replicate CAT still working on linkages and a few minor odds and ends. it will have small stacks with mufflers and clap caps. And why did i build this??? Because Im obsesed with tracks, using my atv plow on front so i can plow snow! and for fun!! | |
Camdg2010 Member
Camdg2010 Member
| Subject: Re: homemade mini dozer July 18th 2018, 9:56 pm | |
| Also, each front rim setup has adjustable bolts i guess you would call them. on the 3rd picture down you can see them. that allows me to set track tention as well as adjust the tracking of tracks right to left. i havent driven it yet. hopefully i get a chance to this by the end of next week. still lots of work ahead of me! | |
| Subject: Re: homemade mini dozer July 18th 2018, 10:00 pm | |
| Welcome back... cool looking rig you are building there. Love to see it progress! Very neat. | |
muckmudd Established Member
Age : 22 Join date : 2017-07-11 Points : 3561 Posts : 825 Location : In the shop
| Subject: Re: homemade mini dozer July 19th 2018, 1:21 am | |
| Wasn't even aware this build was happening, curious to see how you make it. | |
frostypaws Member
Age : 30 Join date : 2012-07-01 Points : 4689 Posts : 131 Location : iowaaaa
Camdg2010 Member
Camdg2010 Member
Crazy_Carl Veteran Member
| Subject: Re: homemade mini dozer July 20th 2018, 3:04 pm | |
| No angle grinder? Seriously? How on earth are you fabricating?
I actually like the wood dash. It has a custom touch to it.
You'll have to weld some drive teeth onto the driven rims or else the rims will just spin the the tracks.
I'd add some bogey wheels between the front and rear rims to help spread the weight across the track better and you could build them in such a way that they could also serve the purpose of keeping the tracks on and aligned. | |
Camdg2010 Member
| Subject: Re: homemade mini dozer July 20th 2018, 8:10 pm | |
| I had one. For many years, been dropped, kicked...ect then it stopped working. Been using a sawsall then using my bench grinder to make things perfect. I got a little more done today, new mufflers, belt is on, ignition switch, throttle and choke are mounted on dash and dash is installed. And as far as the rims, those don't power the tracks. Not sure if I posted a picture of what I've done. As stated above I'm using stock snowmobile sprockets mounted to the zero turn hubs to power the tracks. The rims are there to act as boogie wheels. I haven't decided yet on if I want to use snowmobile slides and not use boogie wheels in between the 2 rims or if I want to take the wheels off snowmobile suspension and make them work. | |
Camdg2010 Member
prancstaman Veteran Member
| Subject: Re: homemade mini dozer July 20th 2018, 11:03 pm | |
| The snowmobile slides should work. I think a simpler guide setup would be extending the horizontal support beams, for the bogies, past the tracks on both ends with rollers on them so when the track moves to the sides, the rollers will roll on the track to prevent wearing on the sides of the track. | |
Camdg2010 Member
| Subject: Re: homemade mini dozer July 21st 2018, 1:07 pm | |
| Well guys. Not sure how I want to do my levers and linkages. Throwing a few through around on paper. But I really need a name for it. Here's what I've got. (MD11 for Mini D11) (C18 for Cameron 2018) (K11 for kitten 11). Any thoughts? I really like the sounds of MD11. | |
| Subject: Re: homemade mini dozer July 21st 2018, 3:10 pm | |
| Yeah I'd have to agree MD11 sounds pretty cool. "This'll either wake you up or put you to sleep forever!"- Red Green "Whatever you do you should do right, even if it's something wrong." - Hank Hill - MTD Off-Road Build - Ford LT 110 Off-Road Build - Craftsman GT 6000 Off-Road Build - Sears LT11 Rat Rod Build *2019 Build-Off Winner!* Garden Tractor Collection: Allis B-110 x2, 710, 716, & 410 - Wheel Horse 655, 953 & 500 Special - Case 444 - Bolens Versamatic, G10 & 1668 Diesel Swapped - Cub 106, 124 & 1000/149 Frankentractor - Ford 120, LGT 125 & 145 - White 1650 Yard Boss - Moto Mower 710-100 | |
Camdg2010 Member
Camdg2010 Member
Camdg2010 Member
| Subject: Re: homemade mini dozer July 22nd 2018, 3:05 pm | |
| I like the straight sticks! Looks old school. I vote MD11. Have you checked over your grounds? | |
Camdg2010 Member
| Subject: Re: homemade mini dozer July 22nd 2018, 3:32 pm | |
| yes ive checked all grounds and connections. anytime i build a mower project the first thing i do it go thru the wiring harness and rewire everything. there is no safety switch plugs anymore, just magneto, solenoid, charging wire and ground on the ign switch. engine crangs over great with no spark plugs in it. its the same exact engine as my zero turn seen in the back ground of my pics, i swapped plugs and still nothing. i even hooked it up to my ole ladys car battery. same thing, jump started off my truck while it was running. same thing... what else could it be? it seems like its building WAY to much compression. pull valve covers and look for bent valve/ broken spring?? | |
Camdg2010 Member
Camdg2010 Member
| Subject: Re: homemade mini dozer July 22nd 2018, 3:46 pm | |
| well i got to looking online. seems these are known for the compression valve to act up. unfortunately that means tearing into engine form what people are saying.. | |
| Subject: Re: homemade mini dozer July 22nd 2018, 6:20 pm | |
| I would take apart the starter first, and clean it out and put it back together. The compression release valve is usually for pull starting the engine. The starter should be strong enough to start the engine with no issues without it. | |
| Subject: Re: homemade mini dozer July 22nd 2018, 6:31 pm | |
| Not sure if anyone has mentioned it. But before you tear into the engine to check compression release, maybe even before looking at the starter. Check the valve lash adjustment. I think I set mine around .004. | |
