| My 6211 simplicity dozer build | |
+7willis923 Angchor Moose B440 camomanusa TokyoDrift99 1997 Murray 11 posters |
1997 Murray Veteran Member
Age : 26 Join date : 2013-11-13 Points : 5449 Posts : 1311 Location : NW USA
| Subject: Re: My 6211 simplicity dozer build June 6th 2014, 11:26 am | |
| well I got the engine readdy to start, and the starter was sized. so, i got the starter gear in the flywheel gear and spun the engine to break it loose I put some oil down it to free it up. when I start it I will put on the dozer blade and dualies. | |
TokyoDrift99 Member
Age : 25 Join date : 2014-03-28 Points : 4037 Posts : 111 Location : Vermont
| Subject: Re: My 6211 simplicity dozer build June 6th 2014, 4:21 pm | |
| talk about it! lol in other news, it started and ran, but I need more coils for all my oppeys. now to put on the blade! | |
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4582 Posts : 467 Location : Greensburg, PA
| Subject: Re: My 6211 simplicity dozer build June 9th 2014, 10:49 am | |
| I got tired of the variable and ripped it out, then built a new clutch. It goes pretty good even with the stock pulleys on it, like 7 mph. | |
| Subject: Re: My 6211 simplicity dozer build June 12th 2014, 11:00 am | |
| well i finished school yesterday and went out to use the simplisity. the starter is toast, so i got the grinder out and cut a notch in the mower deck pulley to use as my pull starter. got it started and added a belt retainer to the clutch pulley. I still need to tinker with it and fix some of the linkages though. | |
B440 Member
Join date : 2014-01-22 Points : 4207 Posts : 226 Location : Thompson, CT
Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4954 Posts : 919 Location : Defiance, Ohio
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4422 Posts : 491 Location : Index, Washington
| Subject: Re: My 6211 simplicity dozer build June 12th 2014, 2:50 pm | |
| - B440 wrote:
- How do the dual wheels mount to the standard wheels?
I could be wrong, so don't quote me. But it looks like... A spacer gets bolted to the axle along with the first rim. Then the second rim gets bolted to the spacer. | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5764 Posts : 1408 Location : Galway NY
| Subject: Re: My 6211 simplicity dozer build June 12th 2014, 3:05 pm | |
| Angchor is correct. just like on farm tractors, there is a spacer of sorts, that goes on before the lugnuts, then has studs on the other side for the dual to bolt to. | |
B440 Member
| Subject: Re: My 6211 simplicity dozer build June 24th 2014, 10:28 am | |
| ok so I got it to stop surging (it was because the p/o took off the air cleaner) made one out of a rag and rubber band, and it runs great! and with the new clutch it does a wheelie no matter how soft you let it out! willis- maybe NOT lol. now i'm building wheelie bars and a hitch so i can go to the pull this saturday. | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5155 Posts : 1068 Location : New jersey
| Subject: Re: My 6211 simplicity dozer build June 29th 2014, 9:54 am | |
| wow it pulls nice i hope my cub pulls that nice how much weight do you have to pull? and what weight class are you in? I have a tractor pull august 9 so we shall see how good the cub does | |
Age : 23 Join date : 2014-01-22 Points : 4574 Posts : 546 Location : north carolina
| Subject: Re: My 6211 simplicity dozer build July 23rd 2014, 9:17 am | |
| yeah, I know Ive been gone for a wile, but I put wheels on the wheele bars and made a weight rack on the front, and now i'm cutting my tires for traction. I ended up getting a full- time job on a farm so I don't have much time for the internet or tractors but the show is in 7 days so I got to get moving fast. | |
