Well I have been watching the site awhile after seeing Fearlessfront's YouTube channel. Not long ago my lawn tractor cut it's last blade of grass when the deck finaly rusted bad enough that a deck support snapped off . At first I considered scrapping it . However I remembered years past how much fun I had modifying lawn tractors. So here is my build. Here are some specifics : all steering joints switched to hiems new clutch setup pulley swap- 9" front- stock rear foot brake pedal foot gas pedal governor delete locked rear axle side shift
there will probably be more as time goes on but for now here is some video
camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4557 Posts : 467 Location : Greensburg, PA
well I have been working off and on modifying the tractor . First thing was the steering and some of it didn't work as intended . But such is life. I will have some video of it soon . It's amazing how long it takes to edit video. I will also be including something people my find useful when trying to make tie rods .
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4397 Posts : 491 Location : Index, Washington
well I have been working off and on the tractor and decided to tackle the rear axle . The hardest part is trying to figure out which way to do it . You have the Doc locker the Fozzy locker and Fearlessfront has a good way of locking the rear axle . But all those require a welder ( which I have ). However I want to do one without welding anything. The way I intend to do it is with a piece of drill rod, a cast iron pulley, and a locking collar . I am just waithing for some parts to come in so I can do it . When they do rest assured I will be taking some video of how I do it. I have been working on the gas pedal . I will be doing the usual using a bicycle hand brake and cable . I will update again soon .
Age : 27 Join date : 2013-03-18 Points : 7461 Posts : 3131 Location : raleigh nc
The steering looks really professional. I understand what you mean by other things taking up time. for the locker, maybe a doc locker with a 3/4" hub in a keyed axle, and have the hub fit in the bull gear. Just coming up with some ideas. Could be done with the right machine tools, or maybe cut up a old sprocket that has a 3/4" bore.
Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4149 Posts : 347 Location : Downers Grove Illinois
sounds like we're on the same page with the locker idea . Instead of a sprocket I will be cutting up a cast iron pulley. If all goes well the most I should need in machine tools will be a 6" dial caliper , some layout tools, and a die grinder. The keyways will be ground in with the die grinder . I will be better able to explain how I do it on video.
I get what you're saying now. I wasn't sure how thick a pulley would be, but if it's cast I think it's pretty good.
Carshowkid Member
you are cutting a cast iron pulley... I'd just go with carbon fiber... Lighter than aluminanm and stronger than steel...
my1987toyota New Member
Age : 43 Join date : 2014-05-05 Points : 3856 Posts : 23 Location : Clearwater Florida
you are cutting a cast iron pulley... I'd just go with carbon fiber... Lighter than aluminanm and stronger than steel...[/quote]
When you see the video I think you will better understand why I am using cast iron. Plus carbon fiber gets to be cost prohibitive . I haven't seen carbon fiber handle the type of shock loads that I will be placing on this part. But I will admit I don't have alot of experience with carbon fiber.
Carshowkid Member
this sport is all about creative thinking and keeping an open mind. So using carbon fiber in a transmission could very well be a good idea. Joking or not. Just not in my budget.
well one thing I am going to do on my trans-axle is add in the ball bearings. there is quite a bit of clearance where the shafts go through . It will be after thanksgiving when I have all the video edited. The editing always seem to take forever to complete .
Happy new year everyone . Well so much for having the video ready sometime thanksgiving. Here is what happened . I have a rather nasty health problem called Crohn's disease . I have been dealing with the major problems associated with it for about 7 years. I have spent this last year doing test after test in preparation for having surgery to correct the bowel stricture and two fistulas that had developed . Finally I had a date set to have the surgery . unfortunately I have to put everything on hold until I am healed up. I am hoping to get back to the video by the end of January .
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5130 Posts : 1068 Location : New jersey
Man that stinks i hope your surgery goes well and you get better soon
yes the surgery went well . I am at home recovering an was told by the doctor to take it real easy for the month . But so far everything is going in the good .
Age : 25 Join date : 2013-04-05 Points : 4940 Posts : 661 Location : New Smyrna Beach,Fl
That's great that your surgery went good. I like your tractor I really wish I had never had to get rid of my Craftsman.
WOW has time flown by. 3 years almost to the day. anyway I am trying to revive my old project in the midst of working full time and having to do stuff around the house. It is amazing how these old Briggs engines can sit for years yet a quick carb clean and they fire right back up.
Age : 22 Join date : 2016-10-29 Points : 7180 Posts : 4001 Location : Lewisburg, KY
