 Video of adjustment for briggs carb's
Video of adjustment for briggs carb's Empty
PostSubject: Video of adjustment for briggs carb's   Video of adjustment for briggs carb's Icon_minitimeApril 7th 2014, 1:02 pm
My son's ride wasn't idling right, so we took a video of adjusting the carburetor.  This works on older briggs carb's with main fuel mixture screw on bottom.
A common problem with these carb's is the butterfly valve wears out the throttle body.  If you can wiggle the idle adjustment screw(a lot), which is attached to the throttle, that means it is leaking air past, and you will have a hard time getting the idle rich enough.  You can turn the idle up, but then it wants to either rev, or die.
Thankfully, this carb is still in decent shape.
Here's the video!
/watch?v=VWXiCs9qCj0
» Video of valve repair on a briggs and stratton flathead.
» Dual Carbs
» Walbro LMT Chinese copy carbs, any good?
» Can you Put Dual carbs on a twin cylender engine?
» How i fexed it. "Tip of idle fuel adjustment screw is broken off in the carb."
