| Briggs Stroker Build | |
+7goesman TroyBilt Pony Doc Sprocket WilliesBuilds redlinemotorsportts Lawren Wimberly Naterater 11 posters |
Naterater New Member
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Briggs Stroker Build March 13th 2014, 10:34 pm | |
![Lawren Wimberly](https://2img.net/u/2812/37/66/46/avatars/1273-1.jpg)
Age : 57 Join date : 2013-12-21 Points : 4730 Posts : 744 Location : Salem Illinois
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 13th 2014, 10:45 pm | |
| Keep us posted, and include as many pics as possible. Good luck!
Age : 27 Join date : 2013-03-18 Points : 7408 Posts : 3131 Location : raleigh nc
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 13th 2014, 11:00 pm | |
| once clearanced, how do you plan on closing it up again, out of curiosity? weld? plate? | |
WilliesBuilds Member
![WilliesBuilds](https://2img.net/u/2812/37/66/46/avatars/983-20.jpg)
Age : 28 Join date : 2013-06-19 Points : 4494 Posts : 329 Location : Florida
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 8:50 pm | |
| WOW that piston has some above the deck height... any plans on shaping the piston head? or are you leaving it flat? | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7243 Posts : 2914 Location : Ontario Canada
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 8:58 pm | |
| I'd be afraid to take that much off a piston crown. I can see blowing a hole in it. Shorter rod, methinks. Do I see porosity in the cam lobes? | |
![TroyBilt Pony](https://2img.net/u/2812/37/66/46/avatars/942-63.jpg)
Join date : 2013-06-01 Points : 4735 Posts : 578 Location : West Virginia
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 9:13 pm | |
| Id leave that piston how she sits and clearance the head by cnc-ing it out. Or go 50/50 on the head an piston. Looks good! If I had a 11hp, i'd make one. | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 9:25 pm | |
| I was thinking profiling to promote swirl in the chamber. I will admit that the proximity of the ring grove to the deck height is concerning me... when the rod heats up, and "Grows" I'm concerned it may actually protrude past the cyl itself... Time will tell. | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 9:55 pm | |
| I was planning on going 30/70 on the head and piston clearance. (More from the head). If it does have a ring problem then a shorter rod is in the future. As for the cam, I ran it in a stock motor today and it was very torquey on low end. Hoping to do this cheap but if need be, I can get the necessary parts. | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 16th 2014, 10:25 pm | |
| Does it help having the cam lobes more square? Or is that so it opens sooner
Last edited by redlinemotorsportts on March 17th 2014, 7:00 am; edited 1 time in total | |
goesman Member
![goesman](https://2img.net/u/2812/37/66/46/avatars/256-89.jpg)
Age : 45 Join date : 2012-01-18 Points : 4778 Posts : 119 Location : Salem, Mo.
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 17th 2014, 12:00 am | |
| Interesting project you have. I am very curious of how it turns out. several years ago i was building up a old cast iron 16hp briggs for a puller project. I was going to use a motorcycle carburetor and a custom made ignition. To up the compression i machined a head out of a chunk of 1.5 inch thick aircraft aluminum. The head never got finished, all it needed was the spark plug hole finished. I made the head so the thickness of the gasket was all the clearance there was between the top of the piston and head. One thing i was going to do was to put the spark plug directly above the exhaust valve. I got that from some of the big time Kohler builders. the reason for it had to do with the fuel mix wanting to go to the hottest spot in the cylinder. And the hottest spot in the cylinder was the exhaust valve. Really i don't know and all that's over my head but i did it any way. Any way maybe this would give you some ideas. Daniel ![Briggs Stroker Build 20140316_224538_zps63177433](https://2img.net/h/i1257.photobucket.com/albums/ii501/dgoesman/20140316_224538_zps63177433.jpg) ![Briggs Stroker Build 20140316_224546_zps0e03bff9](https://2img.net/h/i1257.photobucket.com/albums/ii501/dgoesman/20140316_224546_zps0e03bff9.jpg) | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 17th 2014, 9:00 am | |
| The exhaust lobe is more square in the idea of keeping it open longer. Goesman, I would have loved to see that build finished. That looks sweet. | |
Age : 34 Join date : 2013-11-02 Points : 7089 Posts : 2907 Location : New Jersey USA
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 17th 2014, 8:35 pm | |
| Neat to try stuff out with cheap parts. Should be interesting. If you think that the upper ring might be a problem, maybe just run the compression ring in the scraper ring groove with the top groove left empty. If I had an aluminum welder, I'd be cutting up engine blocks all the time. | |
83ratrodmurray Member
![83ratrodmurray](https://2img.net/u/2812/37/66/46/avatars/1005-59.jpg)
Age : 28 Join date : 2013-07-05 Points : 4217 Posts : 94 Location : Kentucky
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build March 19th 2014, 8:03 pm | |
| interesting build. ill be very interested to see how it turns out because I do have a spare 25 c.i. sitting around. | |
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build April 1st 2014, 6:27 pm | |
| Sorry for the lack of updates. The build is still in progress but there was some difficulty finding time to get the machine work done. With spring break around the corner I promise an update with more progress made. | |
camomanusa Member
![camomanusa](https://2img.net/u/2812/37/66/46/avatars/1098-34.jpg)
Age : 25 Join date : 2013-09-15 Points : 4504 Posts : 467 Location : Greensburg, PA
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: Re: Briggs Stroker Build April 1st 2014, 9:49 pm | |
| i like watching thireads like this, its neat to see the stuff people are building when its like this, not just a plain build or work on | |
TheEquineFencer Member
Join date : 2013-02-19 Points : 4346 Posts : 90 Location : Farmville,NC, USA
![Briggs Stroker Build Empty](https://2img.net/i/empty.gif) | Subject: about tyour cam mods... October 15th 2016, 7:17 pm | |
| I'm not sure if you thought about doing this, but you can grind the side of the cam off on the backside, opposite the lobe, then add some length to the tappet to make up the difference to increase the valve lift. Basically you're making the base circle of the cam smaller like they do to get really high lift cams in a car engine because you're limited to the area the cam has to work in. | |
