 Craftsman Lt2000 Project
jamcco
ZSmachines
98Murray
Jerbear0612
Ozzy's Creations
CornShuck4CE
countryboy12894
Angchor
tanis
camomanusa
24 posters
Craftsman Lt2000 Project - Page 4 Empty
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 3rd 2014, 11:20 pm
Ok I got today some 2x2 angle iron cut and "Bolted" to the axle, I used a #5 carrage bolt to mount to the axle since there is a hole in the axle for eye bolts or something to mount to the front end for the pivot??? I think that will work fine till I can get enough steel for a homemade front axle. and on the springs, I got two diff, sizes and stiffness springs, I was thinking I coulld double them up. I will have more info on this tomarrow as I am gonna be updating my project anyways.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 6:39 pm
here's a smallish update, today i welded some washers to my front wheels to fix the slop i had. i forgot to take pictures of that but i did take a picture of my craftsman next to my "parts" tractor.... my lt2000 was the same height when i first started this project and now it is quite  a bit bigger
Craftsman Lt2000 Project - Page 4 00218
Craftsman Lt2000 Project - Page 4 00314
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 7:32 pm
nice! Craftsman Lt2000 Project - Page 4 Fresse
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 7:38 pm
thanks
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 7:39 pm
say where did you get the tires, and what size are they?
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 7:55 pm
front or rears? the rears are 22x11x8's
http://www.tractorsupply.com/en/store/hi-run-knobby-atv-tire-at-22-x-11---8
the fronts are 16x8x7 off of a chinese atv
the brand of the front tiresCraftsman Lt2000 Project - Page 4 00613
the washer's on the wheels
Craftsman Lt2000 Project - Page 4 00418outside
Craftsman Lt2000 Project - Page 4 00717inside
CornShuck4CE
CornShuck4CE
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 9:33 pm
Looks good nice stance. Not bad for the second 4 link mower.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 6th 2014, 9:55 pm
thanks, i like the new wheel base and lift, it gives a more aggressive look to the tractor im going to have to redo my 4 link mounts, just to make things stronger. ill hopefully have updates on that soon
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 13th 2014, 7:11 pm
did some work today, the front brackets for the 4 links were all bent so i added a piece of angle iron to make it stronger
Craftsman Lt2000 Project - Page 4 00219
the bent mounts
Craftsman Lt2000 Project - Page 4 00315
the shelving metal that serves as the bracing, the notch is for my exhaust
i then painted the links, pan hard, and steering tie rod gold..... i then painted the axle black i will eventually paint the body black with gold accents, like the Bandit Trans-Am..........contiplating calling this build "Bandit" that is if there isnt any other build on here called that
Craftsman Lt2000 Project - Page 4 00419
Craftsman Lt2000 Project - Page 4 00514
Craftsman Lt2000 Project - Page 4 00614
Craftsman Lt2000 Project - Page 4 00718
Paint just makes me feel like my job is almost done......kind of a false sense of completeness  Rolling Eyes Very Happy
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 14th 2014, 11:58 pm
that looks really clean and from my perspective it still looks stock in ways. I will get more pictures latter this week of my setup. All I need to do is redo the exhaust some and it should be done except for reinstatement of the transaxle.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 15th 2014, 12:23 am
it turned out alot cleaner than planned, paint goes a long ways my friend  Very Happy . in person theres some flaws that still need to be worked out, little things that will complete it some more. i need to reinforce the frame still but i will to do that when the body is off for paint which is coming soon. i dont get much flex out of this mainly because of how i positioned my axle, which is better than no flex in my opinion but projects are never done
Ozzy's Creations
Ozzy's Creations
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 15th 2014, 1:33 pm
I like the way you made your front suspension. It looks sweet. Something I might need in the future.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 15th 2014, 3:39 pm
thanks man, dont forget to check out Cornshuck's build, hes the one who gave me the pointers that i needed to build this, feel free to ask any questions you may need on it too. your build is neat. the stance is really cool with those 31's on the back.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 18th 2014, 8:50 pm
major set back in the build, i feel like i might not be doing so much work on this thing for a bit. so here it goes. I think the engine is starting to give out. the ABS solenoid leaked fuel into the cylinder, hydrolocking the engine. i then pulled the plug to get all the gas out of the engine. i then drained the oil and replaced it. the kohler now smokes like crazy. i beleive i've possibly done one of these things: scored the cylinder and or cracked and ruined the piston rings. after looking up piston kits ive found that i would be better off buying a new engine.
so what does this mean to the build....well i think im going to run the kohler till she dies. i will keep an eye on the oil level and add as needed. but if she goes she goes. in the meanwhile ill keep an eye open for a replacement engine.
but i dont want to have to resort to abuse of an engine when i dont have to. the engine runs great at the moment. so if i could get any input on to as why this engine is doing this. any help would be appreciated
engine: early 2000's Kohler Command 17 hp single
model number: CV490S
symptoms: burning oil and spitting it out of the exhaust. SMOKE
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 18th 2014, 10:53 pm
sorry for the awful footage but this is what the tractor was like when it first started smoking. its gotten worse now and the camera barely pics up any of the smoke.
Ozzy's Creations
Ozzy's Creations
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 20th 2014, 10:40 pm
Engine sounds pretty good. Its a shame it started smoking now...
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 21st 2014, 7:52 am
How much can it articulate without shocks? Like have you ever removed both shocks and just picked one tire up? How much does it flex?
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 21st 2014, 3:29 pm
there isnt much articulation with this setup. i havent tested how far it can travel yet..... i guess it's on the list of things to do now. as is there is a 1-2 inch gap between the axle and frame. i built this mainly to have better handling around corners and over bumps. i didnt want to weld the axle to have 0 movement, but i didnt want to have body roll all over the place, i just wish the engine will last me until i get a job bounce
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeMay 22nd 2014, 7:53 pm
just messing around with youtube seeing that i haven't had the motivation to get out side to work on this puppy. this is just a short slide show consisting of the pictures i had on my computer at the moment
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJune 27th 2014, 7:57 pm
Well recently I have been doing some work to this thing, the Kohler is still running, she's burning oil but besides tht there is still plenty of power in it. I put a straight pipe on it to let the engine breath better as well.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJune 27th 2014, 7:59 pm
I also bedlined the entire body on the tractor. The dash, grill, and bumper is gloss black. Pictures will be up shortly
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJune 27th 2014, 9:35 pm
@ 0:43. What kind of Bike is that? The rear end looks like my Kawasaki KLX140 except yours doesn't look like the black monster energy edition.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJuly 1st 2014, 8:05 am
Good eye and yes that is my 2012 kawasaki klx140l.... The klx140l is the big wheel version of the klx140. (2 inches taller basically). The only mods that I have done to that is a senge graphics kit. It's a great bike, and I actually looked into getting black plastics because I always liked the way those monster energy bikes looked.
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJuly 1st 2014, 11:42 am
NICE! I wish that mine was a big wheel, but is isn't Sad.  They are nice bikes though! cheers
BTW mine is a 2009.
Also, on another note.  I don't like the black because there is TOO much of that color on the bike.  I ended up getting pro-taper pillow lites (grips), I got the lime green ones to add a different color to it.  I'm still trying to get stuff in lime green to break up the black.
jamcco
jamcco
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJuly 1st 2014, 8:01 pm
Craftsman Lt2000 Project - Page 4 Img_0610
Craftsman Lt2000 Project - Page 4 Img_0611
Craftsman Lt2000 Project - Page 4 Img_0612
Craftsman Lt2000 Project - Page 4 Img_0613
Craftsman Lt2000 Project - Page 4 Img_0011
a couple pictures of the newly bedlined and straight piped craftsman. the exhaust is 2 pieces, with a piece of smaller pipe that slips into a piece of larger pipe. Really simple system and sounds great. oh and yah thats a pic of my dirt bike (LAWNMOWERMUDDER)
PostSubject: Re: Craftsman Lt2000 Project   Craftsman Lt2000 Project - Page 4 Icon_minitimeJuly 1st 2014, 8:16 pm
The look of the black and matching tires looks awesome. Very nice.
Page 4 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
» Craftsman LT2000 Mud Mower
» Craftsman rally project
» New Craftsman Project
» Craftsman II Mudder Project
» Craftsman LT1000 Project
