oh and yah thats a pic of my dirt bike (LAWNMOWERMUDDER)
Nice Here's mine, " /> Put new grips on it since then. Now it's got lime green and black Pro-Taper Pillow Lites. I'm looking for good hand guards that aren't silly looking and plastic. LOL Love the bike so far, The only thing I don't like is the absence of a kick start. I suck at bump starting bikes . If I could find a kick start kit I'd love it! LOL
On another note. Sorry for jacking you thread.
jamcco Member
Age : 25 Join date : 2014-01-04 Points : 4216 Posts : 226 Location : New Hampshire
couple other pics of the bedlining process. I highly recommend this stuff, rolls right on and is very tough and LMM, good idea for setting up that thread for motorcycles
Jerbear0612 Member
Age : 28 Join date : 2013-04-23 Points : 4343 Posts : 89 Location : Salem ct
ok next mod, brakes....for this i am taking the drum brakes off of a chinese quad and adapting them for my tractor. this will give me brakes, something ive never had on this tractor (not the best idea). anyways i need to buy some bearings and then they should go on without to much fab work. Also the craftsman stickers were taped off, it helps break up the black.
oh yah i knew i saw someone using them before, just couldnt remember where and on what, these are on your mini mower if im not mistaking? seems like id be getting nowhere on this build if i didnt have those chinese atv's lying around the yard ....im hoping to pick up the bearings some point soon. once i get them i may need to ask some questions.
Yup. i dont see why they wont work in any application. just figuring out cables and such here.
jamcco Member
ok got the front drums mostly mounted up. i am waiting on some new bearings, but after that all i have to do is to secure the drums so they dont spin....this should give the tractor plenty of stopping power
all i had to do is drill out one part of the drum and they just slide right on. i was also able to use the stock c clips
the stock atv cables were big enough....added bonus....another cool thing is that the stock atv brake lever bolts right on to the deck adjustment lever.looks pretty cool and isnt awkward to use
jamcco Member
went for the first real drive in the woods with this thing since the 4 link and brakes have been completed.....it drives sweet. It doesnt get stuck anywhere and it is convenient to not barrel down hills and crash at the bottom...thanks to the drums of course. got some pics too
flexation! the all tires are on the ground when i am sitting on the tractor...once i get off, one of the rears leaves the ground
driving through the firns and such....
To cool! How well do the breakes work? Im working on cables for my racer, but the one that comes off the brake cable splitter isnt long enough to run it to a handle like you did, but oh well. Maybe you can write up a thread about the brakes with more pictures, im sure it would be a great mod for other people.
jamcco Member
thanks red.....they worked pretty good for the first test drive.... not quite a neck braking stop but its better than stock mower brakes in my opinion. i think once i tighten up the adjustments that are on the drums themselves i will have them pretty close to done. these came off of a 110cc mini quad so im not expecting them to be able to lock up the front wheels... once i get them working to where i want them to be i will make up a thread just for them...
jamcco Member
went for a quick ride and got stuck, brakes work good, i got stuck and had to pull it out with our tractor, broke the pan hard bar though, welded it up good as new
98Murray Member
Age : 27 Join date : 2013-01-03 Points : 4460 Posts : 89 Location : Ennis Texas
Nice tractor! Love the brake mod. Could you get some more photos around the tractor please? It looks great with the black paint and wheels, also looks good with the decals still on.
jamcco Member
home made muffler, sounds pretty good, nice deep sound. I lost the video of it running and will have it up soon, if you have any questions just ask. i am going to grind it smooth and paint it when i get the time.
jamcco Member
managed to break a shock..... somehow finished the exhaust as well
painted the muffler up
i also built a "tip" to finish up the exhaust...the exhaust does flow through both pipes via holes between both tips. there is only ONE pipe coming out of the muffler....thought i would clarify this, also the hanger for the exhaust hasnt been made, hence why it is sagging a bit
done, i hope. this is the 4th time i have redone the exhaust system on this thing. (atv muffler, redone for 4 link, straight piped, fully custom) tell me what you think. i can do a write up on how i made the muffler
Last edited by jamcco on August 17th 2014, 6:49 pm; edited 2 times in total (Reason for editing : forgot a picture)
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4419 Posts : 491 Location : Index, Washington
Exhaust looks amazing! And with the shock, it probably has to do with a side to side load, those bushings dont look to forgiving. If you havnt already, be careful welding that shock, id personally buy a new shock.
jamcco Member
sorry for the poor quality but this is what ive got for footage as of now. it has a nice deep sound and rumbles a little. ps, my return spring broke off in middle of the video, hence why it sort of surges at one point in the video. tell me what you think, like it? does need anything
Age : 37 Join date : 2013-07-02 Points : 5019 Posts : 731 Location : Logan Ohio
