so you all know that i got a new motor well i have bad news i just dug out our creek so it would be deep for me to ride in well i put my tractor on high thorottle and 7th gear and when i hit the creek i flipped it and pumped water in the moror and oil out the moter after all the oil was out i saw small fish and frog dead comeing to the surface so i had to use my winch which is broke now to get it up the hill past out gate just so i could tow it, it took 2 hours
Age : 27 Join date : 2013-03-18 Points : 7417 Posts : 3131 Location : raleigh nc
so i bought some cheap rubber that is thin and its only $1.92 dollars for a 3 foot section code what it would look like on my tractor taking my tractor to the show
in the mud just playin around i was trying to get over it but i spun the tires and bottomed it out
Age : 23 Join date : 2014-01-22 Points : 4505 Posts : 546 Location : north carolina
so i said that i was going to paint it yellow but i was thinking and it will be your choice yellow or desert tan you pick if u look closely u can see my tractor so you guys know that i have a winch on it but for some reason the cable wont come out and you have to use a crow bar to pull out the the thing on the side and when you get it out it will go back in just fine do you guys know what is wrong with it or should i get a new winch
so i did paint it yesterday (tan) and when i am done ill post pic i need new front tires dose anybody recommend any tires i was thinking 16-17 inches tall and could u put a pic of them
