Well everyone, i've done some digging around and found a rack and pinion off of an old sxs. Anyone have any ideas on retrofitting that into the huskee here?
Would be a good idea to move the rack a little closer to the axle so the arms are angled back while going straight. That way when at full turn you are pulling the spindle arm with a straight or angled back rod. If the rod is slightly forward while at full turn, the rod might lock up at full turn.
Little sample of what I mean.
Good info on doing one.
well i think this weekend is the weekend, im finally ripping into the old girl. i'm most likely to build some type of solid axle 3 link suspension. About time to stop dealing with the murray steering bs
fbisurveilancevan Member
Age : 38 Join date : 2022-05-20 Points : 1157 Posts : 220
Finally got some pictures and some more work done. Waxed the paint and added a 12 volt cigerette light port to charge my phone or use a worklight. Nest i think will be the pully swap sice im needing new belt anyway.
Joe_the_mower_man_1320 Member
Age : 18 Join date : 2021-09-25 Points : 1233 Posts : 69 Location : Northwest Iowa
