 Turf Tire Cutting
Angchor
untrusty huskee
Moose
T-Dub13
B440
13 posters
B440
B440
Turf Tire Cutting Empty
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 1st 2014, 8:20 pm
Has anyone cut Turf Tamers? I cut my friend's tires to use until he can find some ATV tires. I was wondering if I can cut any deeper than the lug before putting a hole in the tire?
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 1st 2014, 8:58 pm
In theory, yes- you CAN go deeper than the lug. Just HOW deep is going to depend on the carcass constuction of that particular tire. All things considered though, I would NOT be inclined to cut that deep.
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 3rd 2014, 10:48 am
yeah, mine are at most 1/4" thick, some thiner
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 3rd 2014, 2:43 pm
I think I'm going to cut the front tires on my machine. I came up with a pattern I like. I'll post the pics later.
T-Dub13
T-Dub13
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 4th 2014, 12:55 pm
We could use some tread cutting threads on here. Post it up!  Cool
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 4th 2014, 10:06 pm
My front tire:
Turf Tire Cutting IMG_1473_zpsdeb3f8cd
Using a razor blade to cut the knobs in half, then a sharp wood chisel that is lightly wider than the knob
Turf Tire Cutting IMG_1474_zps5da299ff
Turf Tire Cutting IMG_1475_zpsdb6e44fd
I didn't need to heat up the chisel or even use a hammer. Just a simple rocking left/right motion will do it.
The final pattern. I did a little bit in between welding.
Turf Tire Cutting IMG_1476_zpsabdf24d3
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 4th 2014, 10:33 pm
pics got taken down?
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 4th 2014, 11:03 pm
I was organizing my photobucket account. Refresh and tell me if they're there (I see them right now). If not, I'll fix.
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 4th 2014, 11:07 pm
gonna have to relink I believe
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 8:02 am
Fixed the pics.
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 10:50 am
Too cool man. Maybe try a hot chizzle or something, I'm sure any cutting at all will being it you.
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 10:53 am
Behold! cut tires you could probably just shave the cut lugs down to the body of the tire if you wanted
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 10:59 am
I'm working in an enclosed area that's 50 degrees. The hot chisel would make some nasty smoke and I'd have to open the door and let the cold air in. affraid
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 11:07 am
just came up with this design, might be too many lugs removed, the dark black is removed
Turf Tire Cutting Projec99
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 11:14 am
whoah super skinnies in the back
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 11:21 am
another one, on the left is a ag stile one and on the right we have a whooly bogger stile cut.
Turf Tire Cutting Img_1710
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 11:34 am
seems like itd be pretty labor intensive...
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 12:24 pm
yeah, but if you do not have much money, then it is worth the effort. if you could work overtime or cut tires, it would be cheaper to buy tires. but if you are a kid who picks blueberrys in the summer for 2 months at $2 for every 10 lbs you pick, and go to school the rest of the time, it is worthwhile
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 3:00 pm
they have laws against that D8 I didnt even get paid for working in the summer >.> my parents always told me the pay was my being a big burly kid lol
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 5th 2014, 3:03 pm
id try the left side.
T-Dub13
T-Dub13
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 6th 2014, 9:55 am
Thanks for posting! I like that process for cutting tires. Looks like you've figured out how to do it the easy way!
Please don't take this too personal, but that pattern in the pic (paint) looks like it's designed for 4WD. Since the tractor has neither brakes nor drive going to the front wheels, all that tire needs to do is steer. I'd suggest a pattern that looks more like the ribbed tires or front tires from a ATV. Like the ones I'm getting set to install on mine when I get the time.
Turf Tire Cutting Newfornttiresb_zps9727ac0f
Tires with a tread pattern that goes the long way around usually work great for steering, but not good for power traction. The 4-4 pattern that you did originally works well for steering and power / braking. And tires with tread rows going across the tire work well for braking and power, but not as well for steering.
Cut your patterns as close to this as possible and the machine will handle awesome.
Turf Tire Cutting Picture012Small-1
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 6th 2014, 10:14 am
Tdub is correct on the front wheel pattern.
B440
B440
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 20th 2014, 9:26 pm
The chisel method works great for old, dry-rotted tires, but not so well on newer tires. This Dremel Multimax tool works great on those. I'm cutting a set of rear tires here. The blade width is almost perfect. It does make a little tire smoke as it cuts though.
Turf Tire Cutting IMG_1517_zps0ee79de5
Moose
Moose
PostSubject: Re: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 20th 2014, 10:52 pm
good idea Very Happy
PostSubject: Turf Tire Cutting   Turf Tire Cutting Icon_minitimeFebruary 21st 2014, 11:09 am
you guys are correct, that tread is wrong for the front, but fine for the back. this is the best picture i could find of a turf, which is the reason for it being on the front.
Turf Tire Cutting
» my turf master
» turf saver mods
» speed rating for turf tires
» Huskee supreme cutting
