| Turf Tire Cutting | |
+9Angchor untrusty huskee mr.modified redlinemotorsportts Moose T-Dub13 1997 Murray Doc Sprocket B440 13 posters |
1997 Murray Veteran Member
| Subject: Turf Tire Cutting Fri Feb 21, 2014 10:09 am | |
| you guys are correct, that tread is wrong for the front, but fine for the back. this is the best picture i could find of a turf, which is the reason for it being on the front. | |
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4573 Posts : 540 Location : Central MA
| Subject: Re: Turf Tire Cutting Mon Feb 24, 2014 11:54 am | |
| Great idea B440! I may try that along with my "professional" tire cutter to see which one is better for different durometer rubber. | |
B440 Member
Join date : 2014-01-22 Points : 4205 Posts : 226 Location : Thompson, CT
| Subject: Re: Turf Tire Cutting Mon Feb 24, 2014 7:42 pm | |
| In poking around the internet, I found out that tire groovers can be had for around $70-$80 or so, possibly less if you look in the right place. I know you guys are talking about doing things cheap, but just an idea if you wanted to play around with a lot of different tires. I've never used one, but I guess they have different sized cutters ect. for different applications. I was always thinking about cutting some knobs out of the tires on my simplicity for the heck of it, but I didn't know an easy way to do it. Too bad the tread isn't just a little higher on these turf treads. | |
B440 Member
| Subject: Re: Turf Tire Cutting Mon Feb 24, 2014 10:07 pm | |
| Finished one tire this evening. Used the Multimax on it. Weight of the original Turf Tamer: 14.2lbs Weight of the cut Turf Tamer: 11.6lbs. So I removed 2.6lbs from one tire. What I really saved: approximately $150.00 in new tires. I was going to buy a set of Duro HF244's for the Craftsman tractor that actually cuts my lawn. I need something more aggressive than Turf Savers. I tried these 22x11x8 Turf Tamers, but they occasionally rub the deck and feel unstable while side-hilling. | |
untrusty huskee Member
Age : 26 Join date : 2014-01-04 Points : 4079 Posts : 79 Location : Fulton IL
| Subject: Re: Turf Tire Cutting Thu Feb 27, 2014 11:20 am | |
| heres my cut tire that i had got the idea from atv nobies " /> and here it is on my mower " /> | |
Age : 26 Join date : 2013-11-13 Points : 5447 Posts : 1311 Location : NW USA
| Subject: Turf Tire Cutting Thu Feb 27, 2014 1:21 pm | |
| good work! i'm cutting my tires that way next time. | |
B440 Member
Angchor Member
Age : 67 Join date : 2014-04-14 Points : 4420 Posts : 491 Location : Index, Washington
| Subject: Re: Turf Tire Cutting Mon Apr 28, 2014 6:40 pm | |
| The only thing I cut was the half knob on the outside edges of my turf tamers. I used a standard utility knife to do the job with. No hot knifes or chisels needed. I didn't want to cut much of the tire away. Biggest reason I did this much is so that it will hold onto chains better, once I get some made up. (And yes, I am making my own tire chains out of old car tire chains.) Those chains will go on and stay on. For traction, and for weight. | |
ZSmachines Member
Age : 25 Join date : 2014-08-27 Points : 3993 Posts : 221 Location : PNW
| Subject: Re: Turf Tire Cutting Tue Dec 23, 2014 2:25 pm | |
| i found that the easiest and quickest way to cut tires is to sharpen an old butter knife then get it red hot and slice away. my freind and i knocked out a pair in under an hour | |
Age : 23 Join date : 2014-01-22 Points : 4572 Posts : 546 Location : north carolina
B440 Member
| Subject: Re: Turf Tire Cutting Tue Dec 30, 2014 9:16 am | |
| An atv tire with deep lugs, no.
But when you don't have the money to spend on tires, these work better than a stock mower tire, or a semi-bald atv tire. | |
rarbaugh07 Member
Age : 36 Join date : 2014-01-22 Points : 4078 Posts : 117 Location : Logan, iowa
| Subject: Re: Turf Tire Cutting Tue Dec 30, 2014 10:18 am | |
| Cut tires also flex a lot better at low psi compared to before with full tread blocks. | |
| Subject: Re: Turf Tire Cutting Tue Dec 30, 2014 8:26 pm | |
| I was thinking of cutting some blocks out of my truck tires for off road use... | |
N1ck Member
Age : 24 Join date : 2014-06-08 Points : 3904 Posts : 74 Location : North Central Arkansas
| Subject: Re: Turf Tire Cutting Fri Apr 10, 2015 7:25 pm | |
| Pretty much what I ended up doing with my snow tires on my truck. Who knows how much it helps. I figured there might be some improvement in loose snow. I didn't run it enough to notice one way or the other. I knocked these blocks out with a sharp chisel and a hammer. Just have to be careful not to go too deep and cut into the cords ect. | |
