| 1970 John Deere 112... The beginnings of MULE II | |
+19countryboy1995 Stretch44875 Moose TheRainbowBoxer Jedi HuntingWally64 Lawren Wimberly 83ratrodmurray camomanusa TroyBilt Pony willis923 richie thomas rarbaugh07 redlinemotorsportts Thunderdivine T-Dub13 LAWN MOWER MUDDER Doug Doc Sprocket 23 posters | |
Doc Sprocket Site VIP
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 16th 2014, 8:05 pm | |
| I thought about it, but one of the fullsize tractors I use time to time has that, and I consider it a pain to take the exhaust off to open the hood. Plus, the hood is fibreglass. Heat- EEK!
The weights are there to give it more grab in the snow ad such, but i suspect I will be taking them off when it melts. As I add more weight (accessories etc) the wheel weights will likely prove unneeded if not overkill.
| | | | Lawren Wimberly Established Member
Age : 57 Join date : 2013-12-21 Points : 4805 Posts : 744 Location : Salem Illinois
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 16th 2014, 9:02 pm | |
| Mule II... The plumbers paradox!
Ya know, an exhaust set up that that pivots similar to the snorkel wouldn't be a bad Idea... a galvanized 2 inch universal coupler would work similarly to the abs connector on the other side. It would allow you to lay the stack back when needed. | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 16th 2014, 9:44 pm | |
| Indeed, but still uncomfortably close to my body.I toyed with simply laying the muffler horizontally. Didn't like it. The CF part stays a reasonable temp, but obviously the end cap and outlet are a whole other matter. Having roasted myself ona bike once or twice (no doubt you have too) I'm... Uninterested. | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 16th 2014, 10:46 pm | |
| Wouldnt you want to make the brake away in the conduit tubes? i mean if you put it on its side your smashing the collector chamber and the conduit. i guess it isnt a big deal because the conduit would just bend.... food for thought | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 17th 2014, 6:22 am | |
| Food for thought, indeed- and I did think on it. However- One: How to brace it, yet still allow it to collapse? Two" how to make it collapse? Got me on that one. My solution- although I have yet to do it- is to fab a guard around it. If I drop it on its side or whatever, it will live. | |
Age : 28 Join date : 2013-04-10 Points : 5761 Posts : 1408 Location : Galway NY
| | | | countryboy1995 Member
Age : 29 Join date : 2013-09-25 Points : 4122 Posts : 45 Location : Marion,NC
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 21st 2014, 9:39 pm | |
| - willis923 wrote:
- its really simple actually... just dont roll it
Ahh... THIS IS YOUR FAULT!!! I had an exciting evening. Began by mounting a pair of 19x7-8 ATV tires I picked up. Took it for a buzz. Feels good and even steers a lot better! Sooo- I was goofing off sidehilling the snowbanks and wouldn't you know it? Rolled the bugger! And dropped it on what? Yup. The stack. So- - willis923 wrote:
This is your fault. Ban coming. LOL The good news is that the breakaway worked perfectly. Zero damage to header pipes or engine. More detail, brighter pics, and video tomorrow. | |
| | | jamcco Member
Age : 25 Join date : 2014-01-04 Points : 4216 Posts : 226 Location : New Hampshire
| | | | camomanusa Member
Age : 25 Join date : 2013-09-15 Points : 4579 Posts : 467 Location : Greensburg, PA
| | | | Moose Established Member
Age : 35 Join date : 2014-01-12 Points : 4951 Posts : 919 Location : Defiance, Ohio
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II March 23rd 2014, 3:29 pm | |
| I'll try to avoid it. Thanks for the tip! LOL
No guarantees, though. I was goofing off on some more snowbanks today, and even with the open diff it still climbs like you would not believe! | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II April 20th 2014, 9:27 pm | |
| No sir. Automotive alternator, internally regulated. Charges only. BUt if anyone wants to do such a thing, they are common as hell, as cheap as they get, require 2 mounting bolts, and easy as pie to wire up. | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II April 21st 2014, 5:08 pm | |
| I haven't done anything BIG to this yet that hasn't been posted, but I"ve done a few little things lately aside from the alternator. I had added a marine deep cycle battery, and located it under the seat. ultimately, that did 2 things I wasn't thrilled about. 1)Too much weight in the rear, not enough in the front. 2)Raised centre of gravity because I had to raise the seat. Made driving it feel a bit weird, and climbing was getting scary. Always felt like it wanted to flip back on me. So- I bought a new battery (the one I'd put in wasn't holding a charge) and the new battery JUST fit under the hood- so I put it back there. I dropped the seat as low to the pan as I could manage, using the seat brackets from the parts AWS Noma. I went out this morning, looking to protect my new alternator. I needed to try to keep the rain off it, keep mud and water from spraying up from the right front tire, and it was awfully dang close to the rear cylinder header pipe. Since I wasn't in the mood to refabricate a new header (yet) I cheated. I put a couple slices in the tube, and bent it upwards, and rewelded. Lost some beauty, bet...meh. Later. I grabbed some aluminum and put together a quickie heat sheild. I have some 1/8" closed cell foam (actually underpad- the good stuff) for engineered hardwood flooring, and wrapped it around the alternator as a rain sheild. This left the problem of splashing. Looking at it, I intended to simply extend the footoard forwards underneath and in front of the alternator. I went around the property in search of a bit of steel sheet, a mower footboard, or SOMETHING I could hack up. Next thing I know, I have two utility trailer fenders in hand- a round one, that was the twin brother of the one I hacked into MULE's rear fender extensions, and a squared off one. I stared at it awhile, and decided to go for it. Fantastic, you idiot. Now I have a PAIR of completely mismatched trailer fenders left- like the two socks sitting on top of the clothes drier, who's brothers now appear on various milk cartons. A little hack-n-whack, and MULE2 is now sporting some VERY Jeep-looking front fenders! Now- I have to decide what to do about them. I might at some point try to meet with the footboards and kinda blend them in, or I might not bother. We'll see. Oh yeah- I've also been playing with shifter modifications to get it outta my testicular area... | |
| Subject: Re: 1970 John Deere 112... The beginnings of MULE II May 23rd 2014, 2:33 am | |
| Love the look but the front fenders need some green! I gotta get some suitcases for the front of the massey I went to load it in the truck the other day and as soon as the front tires got to the top of the ramps they kept going up instead of into the truck so...... gotta even that out. | |
| | | Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5152 Posts : 1068 Location : New jersey
| | | | kawasaki220 Established Member
Age : 23 Join date : 2014-01-22 Points : 4571 Posts : 546 Location : north carolina
| | | | Sponsored content
| Who is online? | In total there are 20 users online :: 0 Registered, 0 Hidden and 20 Guests
