does anyone know if this has a peerless 2300? or if this engine is any good? this tractor is in my price range so I may buy it if you guys think it is any good.
Runs great needs a new battery. No mower deck. $250 obo (360) 815-0924
GenevaCustoms Member
Age : 27 Join date : 2013-09-24 Points : 4341 Posts : 315 Location : Florida
Those kohlers are heavy and have some awesome torque behind them. great engines, great frame, and overall a good rear, the 2300's have 1" axles i believe
Last edited by redlinemotorsportts on December 4th 2013, 11:04 am; edited 1 time in total
1997 Murray Veteran Member
Age : 25 Join date : 2013-11-13 Points : 5372 Posts : 1311 Location : NW USA
I have pretty much the same exact tractor that someone gave me. They have a oil filled steering box, which is geared kind of low for mowing if you have to do a lot of steering. Mine has a rod knock, smokes horribly, and has a worn out steering box. Motor is cast iron block kohler, 7 hp? Fiberglass hood. Cast iron front axle. Cast iron transmission. Mower drive has a clutch build into the pulley vs the traditional belt clutch setup. High grass smokes mine. It doesn't do too good on the hills traction wise, I think it's too heavy. Mine has a million hours on it which is most of the problem. There are some rugged parts on it that would be usable. I personally don't like it for mowing even though it cuts pretty good, not that that's what this website is about. I almost forgot about the clutch, It has a variable deal in with it (lever operated). Also, when you let the clutch out, it's one of those slow release things. Instead of instant grab, you get a slow take off no matter how fast you take your foot off the clutch. I guess you could get rid of that if you wanted.
Doc Sprocket Site VIP
Didn't realize anyone wanted them. I was thinking of possibly scrapping mine sometime. After I save a few parts off of it of course... I just remembered It has some working headlights in it that I could use!
Join date : 2013-06-01 Points : 4736 Posts : 578 Location : West Virginia
