| Simplicity Broadmoor 717 steering problems? | |
+21997 Murray simplicity14twin 6 posters |
simplicity14twin Member
Age : 26 Join date : 2014-01-13 Points : 4111 Posts : 112 Location : New Hampshire
| Subject: Simplicity Broadmoor 717 steering problems? January 15th 2014, 12:57 pm | |
| Hi so My broadmoor just got a new motor which is a 14 hp twin. since I did the swap it has really hard steering to the rite. I think it is because the motor is so heavy but I dont know. If anyone has any tips ore better steering ideas send me a reply thanks | |
1997 Murray Veteran Member
T-Dub13 Established Member
Age : 55 Join date : 2013-12-06 Points : 4569 Posts : 540 Location : Central MA
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 11:49 am | |
| Sounds like the linkage is binding up on something. Most likely related to the engine swap since it's a new symptom. Anyway, when I had my Broadmoor, it didn't steer all too well anyway. The front tires "plowed" instead of gripped. I wanted it to steer more like a gokart not a tractor, so I did some modification to the front axle. Here's what I did to make it steer 10 times better: Cut a notch in the top of the axle next to the kingpin and tip the top of the kingpin in towards the motor, creating NEGATIVE CAMBER. Rotate the front axle rearwards (or just twist the top of the kingpin rearwards while doing the camber mod) to create POSTITVE CASTER. Be sure to weld it back together correctly or you could end up with a 2 or 3 wheeler! I'm going from memory, but I know these tractors steer like crap. This will help a lot! Look up the steering terminology on google. Here's a couple pics. CAMBER CASTER ALL | |
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 12:05 pm | |
| little confusing but i will figure it out and its not that it steers bad its that th grinds the stering gears and wont work unles going really fast but i will try that if i can figure it out | |
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 1:31 pm | |
| haha, first get the tractor to steer as good as it supposed to. We can talk about modifying the front axle for agressive camber and caster later on. Sorry I got a little carried away, such is my nature. | |
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 2:17 pm | |
| Typical settings for gokarts is: 9-12 degrees caster -2 to -4.5 degrees camber I just posted this for reference. I need to do some work on my own front end when I switch tires. | |
richie thomas Veteran Member
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 2:59 pm | |
| That;s from the baja college competition. They have to run stock B&S 5hp horizontal shaft motors. Cool program. BTW, your dragster looks like it has negative caster... Might wander a bit on the road! Are you dropping the rear eventually? | |
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 3:03 pm | |
| - T-Dub13 wrote:
- That;s from the baja college competition. They have to run stock B&S 5hp horizontal shaft motors. Cool program.
BTW, your dragster looks like it has negative caster... Might wander a bit on the road! Are you dropping the rear eventually? na the rear is going to stay that highth, and ive still got some fine tuning to do on the front end, im modding the spindles some and ive got some ideas to keep it from wandering | |
Thunderdivine Veteran Member
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 16th 2014, 8:01 pm | |
| I think it is from all the weight on the front tires. If it grinds and skips then it is the steering gear. mr.modified might know some about it because he has a 5010 (close to a 717). | |
| Subject: Re: Simplicity Broadmoor 717 steering problems? January 17th 2014, 10:40 am | |
| Standing still, the steering will be 10 times harder obviously. But doing this will force any steering problems to show themselves pretty quickly. Can you post a pic of the steering mechanism? I forget what that all looks like. Try lifting the front end onto a jack. Then cycle the steering and look / listen for any scraping / binding etc... If the problem goes away, then take it off the jack and repeat the test. You will eventually find the problem if you go slow and pay attention and look really closely to all the components. Looking at the angle of those king pins YIKES! Even if the steering wheel is easy to turn, the tractor itself isn't going to like changing direction lol. | |
| Subject: Simplicity Broadmoor 717 steering problems? January 17th 2014, 11:18 am | |
| - simplicity14twin wrote:
- yea you are probably rite. I had a hell of a time taking it out the motor weighs at least 60 lbs.
it is 110 lbs | |
