 T-Dub's Snow and Mud Plow project
T-Dub13
T-Dub13
T-Dub's Snow and Mud Plow project Empty
PostSubject: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 11:24 am
Well, I got this plow as a freebie from a friend.  It's a Craftsman plow that is supposed to hook to the tractor in the rear pin (pintle?) location.  That was the easy part!
Here's a pic of the frame under the tractor.  There was no way of lifting or steadying the plow frame.  So I needed to figure out how to restrain it from moving left to right, but also lift it vertically.
T-Dub's Snow and Mud Plow project Mms_picture16_zpsfb2bd439
I gathered some brackets and some angle from an old bed frame and started fitting and looking.  Imagination is key here.  still not quite sure what to do...   Never seen a LT plow lift mechanism up close before.
T-Dub's Snow and Mud Plow project Mms_picture15_zps01e94761
Top plate + two brackets + a piece of pipe + Toro RER steering column = an idea...
T-Dub's Snow and Mud Plow project Mms_picture14_zps9b18ebe6
Putting the ideas together and using some more imagination...
I want to be able to disconnect the entire thing easily and simply.
The pipe will be pinned through the lift rod by bolts.
T-Dub's Snow and Mud Plow project Mms_picture13_zps6723fb5a
Mount the top plate to the stamped steel frame (hope it's strong enough)!!!
And add the next channel links to connect the two mechanisms.
T-Dub's Snow and Mud Plow project Mms_picture11_zpsff0621ea
T-Dub's Snow and Mud Plow project Mms_picture12_zpsb2f4e3b0
Welded and pinned.  I used 1/4-20-UNC bolts as pins for now.  Nyloc nuts so I can hand tighten and they won't fall off.
Used a torch to form the lift bar.
Used 1/2-13-UNC nuts and bolts for pivots.
T-Dub's Snow and Mud Plow project Mms_picture110_zpsbd997fba
Used the handlebar from an old Ariens snowblower for the handle.
Took a while to get the position right for raising / lowering from the sitting position!
T-Dub's Snow and Mud Plow project Mms_picture19_zps37fa244a
How do I hold the plow in the upright position?  Welded a hook onto the handle to hook under the fender.  I hope the fender is strong enough and doesn't fatigue after some use...
T-Dub's Snow and Mud Plow project Mms_picture18_zpsdfccf8bc
T-Dub's Snow and Mud Plow project Mms_picture17_zps12b67fc0
And DONE!  No snow around here anymore, but she does plow mud pretty well!   cheers  Laughing
Plus, I can pull two clips in the rear and remove two hand tightened nuts / bolts in front and leave the entire thing behind.
T-Dub's Snow and Mud Plow project Mms_picture111_zps3475ff6f
T-Dub's Snow and Mud Plow project Mms_picture114_zps63fa1415
PostSubject: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 11:28 am
good job! maybe you could use it for a bulldozer!
PostSubject: Re: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 11:39 am
Very well done! If I got a plow for free I'd def stab it on my mower.
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 11:41 am
Thanks Man! Yeah, I was pushing around a big leaf pile and some pretty thick mud the other night. Still running an open Diff, so it doesn't push too much dirt.  Cool
PostSubject: Re: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 1:53 pm
Nice fab work. A locked rear end makes a big difference plowing.
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 14th 2014, 2:04 pm
I can imagine. This thing is still the "Family Garden Tractor" though haha. So I'm worried about tearing up the lawn etc while doing chores and whatnot.
I'll report back after I get to push some snow.  Cool
T-Dub13
T-Dub13
PostSubject: Re: T-Dub's Snow and Mud Plow project   T-Dub's Snow and Mud Plow project Icon_minitimeJanuary 20th 2014, 12:55 pm
It finally snowed a little up here in the Northeast.  My GF took a couple vids of me playing with the plow with her cell phone.  Next time I'll get better vids with sound.
Plowing 1
Plowing 2
Edit: Hey! The sound came through. That's funny. Cool! Still running a stock muffler can.  Rolling Eyes
» i seriously need a snow plow lol
» snow video romp/ plow!
» Mud machine turned into snow plow
» Advice/info needed on snow pusher project. Check it out...
» Plow idea help?
All-Terrain Lawn Tractor Forum :: Technical Forum :: Chassis Modification :: Bumpers, Brush Guards and ATV Racks-
