| What is a good way to clean out a carb? | |
+6TroyBilt Pony Doc Sprocket T-Dub13 Craftsman1998 slim67 matt-man 10 posters |
matt-man Member
Age : 27 Join date : 2013-07-26 Points : 4357 Posts : 221 Location : North Fort Myers, Florida
| Subject: What is a good way to clean out a carb? January 4th 2014, 11:45 am | |
| Ok so I have the carb all taken apart and it is disgusting inside I've heard of soaking it in diesel fuel but what other ways are there to soak the carb in to get it clean? | |
slim67 Member
Age : 57 Join date : 2013-11-05 Points : 4048 Posts : 45 Location : richfield,ohio
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 11:59 am | |
| if you have access to a parts washer then put it in something and let it soak. If not use carb cleaner in an aerosol can and a pan. Use compressed air if you have it and blow it out. Be careful not to blow the needle seat out and lose it. | |
Craftsman1998 Veteran Member
Age : 26 Join date : 2013-10-30 Points : 5118 Posts : 1068 Location : New jersey
T-Dub13 Established Member
Age : 54 Join date : 2013-12-06 Points : 4538 Posts : 540 Location : Central MA
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 1:21 pm | |
| You can use a torch tip cleaner set to help clean out the jets and the passageways. A small brass wire brush works well for the larger surfaces. | |
matt-man Member
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 1:39 pm | |
| - slim67 wrote:
- if you have access to a parts washer then put it in something and let it soak. If not use carb cleaner in an aerosol can and a pan. Use compressed air if you have it and blow it out. Be careful not to blow the needle seat out and lose it.
This would work but I don't have access to a parts washer or compressed air | |
matt-man Member
| - T-Dub13 wrote:
- You can use a torch tip cleaner set to help clean out the jets and the passageways. A small brass wire brush works well for the larger surfaces.
I don't have any of those things, what else would work? | |
slim67 Member
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 2:44 pm | |
| - Craftsman1998 wrote:
- Get some carb cleaner, paper towels, wire and a old bucket with a paint brush and some gas or kerosene in it.
Do you have any of these items that are mentioned here? | |
matt-man Member
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 2:46 pm | |
Do you have any of these items that are mentioned here? Yes, I have them all | |
Doc Sprocket Site VIP
Age : 51 Join date : 2013-04-21 Points : 7284 Posts : 2914 Location : Ontario Canada
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 4:44 pm | |
| Take one of those paper or plastic covered wire ties you use for garbage bags, and strip the paper or plastic off. Gives you a good bit of wire to work with. | |
matt-man Member
| Subject: Re: What is a good way to clean out a carb? January 4th 2014, 5:08 pm | |
| - Doc Sprocket wrote:
- Take one of those paper or plastic covered wire ties you use for garbage bags, and strip the paper or plastic off. Gives you a good bit of wire to work with.
Thats a good idea, thanks for the tip Doc | |
Join date : 2013-06-01 Points : 4776 Posts : 578 Location : West Virginia
bbuckler Member
Age : 32 Join date : 2013-12-07 Points : 4043 Posts : 58 Location : Killeen,Tx
Cubhorse80 New Member
Age : 29 Join date : 2014-01-01 Points : 3957 Posts : 10 Location : Loveland, OH
| Subject: Re: What is a good way to clean out a carb? January 5th 2014, 1:53 pm | |
| this may sound strange, but i boil all my carbs both on lawn tractor carbs, full sized tractor carbs and car carbs. STEPS: 1. empty all gas from the carb 2. Seperate bowl, and float assembly (upper carb for updrafts and opp. twin engines) 3. get a pot and add water 4. add a spoonful of lemon juice and bring to a boil 5. place carb in boiling water ( NOT FLOAT and ASSEMBLY THIS IS IMPORTANT) and let sit there for 20-30 minutes 6. take carb out and let it cool 7. Season to taste and Vwala! a Carb De Cleanest with a side of gunk water ANYWAY... boiling the carb sxpands the metal and cleans every nook and cranny. The water will be dark brown to black by the time its done. be sure to dry and wipe down with gas so nno rust froms on steel parts | |
matt-man Member
| Subject: Re: What is a good way to clean out a carb? January 5th 2014, 1:56 pm | |
| - Cubhorse80 wrote:
- this may sound strange, but i boil all my carbs both on lawn tractor carbs, full sized tractor carbs and car carbs.
STEPS:
Thanks for the tip, right now I have it soaking in a bucket of diesel fuel and I'll see how this works and if it doesnt clean it then I will use your method | |
simplicity14twin Member
Age : 26 Join date : 2014-01-13 Points : 4080 Posts : 112 Location : New Hampshire
Age : 57 Join date : 2013-12-21 Points : 4771 Posts : 744 Location : Salem Illinois
