| My 150MPH Go Kart | |
+5Doc Sprocket redlinemotorsportts k2500life TroyBilt Pony xxXMowerdudeXxx 9 posters |
xxXMowerdudeXxx Established Member
| Subject: My 150MPH Go Kart November 17th 2013, 2:36 pm | |
| I traded my mtd grass cutter for this thing, it started as a rattler gokart, but someone along the line stretched it, rebuilt the back to fit a suzuki 500cc gsx motor, so its basically a shifter kart , but safer has a rollcage. I need to get the carbs rebuilt, a shifter linkage made, find a gas tank like 4 gallon or so. Get the stuff bolted down, un getto it, battery, fix alignment, and should be able to drive it. Fix the brakes, and clutch also. | |
Join date : 2013-06-01 Points : 4810 Posts : 578 Location : West Virginia
| Subject: Re: My 150MPH Go Kart November 17th 2013, 2:40 pm | |
| Thats badass! Bet it flys! Make sure your tires are good for 150mph... lol | |
k2500life Veteran Member
Age : 27 Join date : 2013-06-19 Points : 5371 Posts : 1135 Location : Southern Florida
| Subject: Re: My 150MPH Go Kart November 17th 2013, 3:36 pm | |
| Sweet, always wanted to build one like it but a custom frame | |
| Subject: Re: My 150MPH Go Kart November 17th 2013, 4:14 pm | |
| Yea, I wouldn't go over 45 on them tires.... Name it death trap lol | |
| Subject: Re: My 150MPH Go Kart November 17th 2013, 4:41 pm | |
- Yea, I wouldn't go over 45 on them tires.... Name it death trap lol
ur refering to the knobbies right? the rears i would hope can take 150, lol | |
| Subject: Re: My 150MPH Go Kart November 17th 2013, 4:45 pm | |
| - xxXMowerdudeXxx wrote:
ur refering to the knobbies right? the rears i would hope can take 150, lol Both tires, car tires could probally do 120 but there unbalenced... when 60mph rolls by it will shake like a whorehouse lol | |
Doc Sprocket Site VIP
| Subject: Re: My 150MPH Go Kart November 17th 2013, 4:48 pm | |
| The front tires DO look questionable. But I'm more concerned about the rest of it. Yard/fun karts are NOT known for particularly well-built frames, nor components that can tolerate a lot of abuse or power. That's the basics- THEN you got a questionable chassis that has been severely structurally altered by somebody that maybe welds like a drunken monkey, and dropped a stoopid amount of torque in it.
Just be vigilant, is all. | |
| Subject: Re: My 150MPH Go Kart November 17th 2013, 5:39 pm | |
| - Doc Sprocket wrote:
- That's the basics- THEN you got a questionable chassis that has been severely structurally altered by somebody that maybe welds like a drunken monkey, and dropped a stoopid amount of torque in it.
The welds on the roll cage are pretty bad in spots, but the chassis looks good(I think there was to people building this, one built the cage other did chassis, guy that did the chassis welds better, LOL). I have been tseting it, it seems pretty strong, I will be putting another pillow block or 2 bearings on the the axle. Ill be making it like a truck, clutch on left, brake in the middle, gas on the the right. heres some more stuff I got done, pulled the engine, I think it may need a clutch..... Look at the wiring mess some one did... should I put a box on it? | |
Doug Site Owner
| Subject: Re: My 150MPH Go Kart November 17th 2013, 8:24 pm | |
| Id question the chassis too. How thick is the steel? Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: My 150MPH Go Kart November 17th 2013, 8:54 pm | |
| - Doug Fackler wrote:
- Id question the chassis too. How thick is the steel?
im not sure, but even after taking the motor off, the frame still weights about 100lbs easy, w/o tires on | |
Doug Site Owner
| Subject: Re: My 150MPH Go Kart November 17th 2013, 8:58 pm | |
| Id still be a little skeptical. Id see about beefing it up some. Head Forum Administrator ** Chat Moderator ** Facebook Page AdminATLTF Facebook Page ** Chatbox ** How To Upload Pictures
| Subject: Re: My 150MPH Go Kart November 17th 2013, 9:19 pm | |
| I want to build a miniature truck chassis with 2/4 steel, and truck (shortened) rear end, tranny, and a 350. and sit a mower body on it. | |
| Subject: Re: My 150MPH Go Kart November 17th 2013, 11:23 pm | |
| - TroyBilt Pony wrote:
- I want to build a miniature truck chassis with 2/4 steel, and truck (shortened) rear end, tranny, and a 350. and sit a mower body on it.
2/4 translates into 1/2 u know that right? | |
| Subject: Re: My 150MPH Go Kart November 18th 2013, 6:55 am | |
2/4 translates into 1/2 u know that right? Lol I was looking at that to... | |
richie thomas Veteran Member
Age : 29 Join date : 2011-08-04 Points : 6400 Posts : 1434 Location : east dublin georgia
| Subject: Re: My 150MPH Go Kart November 18th 2013, 6:57 am | |
2/4 translates into 1/2 u know that right? Lol I was looking at that to... i think he was meaning like 2x4 box steel, but i might be wrong | |
| Subject: Re: My 150MPH Go Kart November 18th 2013, 6:24 pm | |
| Saw the bent axle coming, just didn't expect it'd be bent already.
New axle- Note: If axle ends don't match old ones, your hubs may not fit. $. Also keep an eye on existing bearing, rotor, and sprocket bore sizes/type. Again, a mismatch=$.
I'd put a support bearing in the approximate middle of the axle, too. The axle you linked to, should do the trick. | |
| Subject: Re: My 150MPH Go Kart November 18th 2013, 10:30 pm | |
What rich said lol.. my bad.. | |
| Subject: Re: My 150MPH Go Kart November 19th 2013, 8:00 am | |
| Craigslist be like
Super fast go kart gs500 engine 150mph racing seat and cage highly modded only needs carbs cleaned..... | |
Thunderdivine Veteran Member
| Subject: Re: My 150MPH Go Kart November 19th 2013, 1:06 pm | |
| Awesome But for 150mph, you'll need 2 more rows of Suzuki | |
| Subject: Re: My 150MPH Go Kart November 19th 2013, 3:21 pm | |
| - Thunderdivine wrote:
- But for 150mph, you'll need 2 more rows of Suzuki
LIES ALL LIES | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5701 Posts : 1091 Location : Galion, OH
