| Bolens Build | |
+16Craftsman1998 richie thomas Thunderdivine 1997 Murray camomanusa Doc Sprocket Doug Stretch44875 mr.modified TroyBilt Pony LAWN MOWER MUDDER thatrandomguy TheRainbowBoxer redlinemotorsportts willis923 MoWheeler 20 posters | |
richie thomas Veteran Member
| Subject: Re: Bolens Build January 21st 2014, 7:32 pm | |
| ive got to say man.....i love the ag tread left in the ice | |
| | | MoWheeler Member
Age : 29 Join date : 2013-10-31 Points : 4108 Posts : 65 Location : Upper sandusky, Ohio
| Subject: Re: Bolens Build November 19th 2014, 8:32 pm | |
| Well guys its been quite a while since I have posted, and to say the least, the bolens has changed. Different tires, different engine, many different exhausts, new lights, new rear bumper, winch, air pump, peerless 820, plow attatchment.. the list goes on..[img:9213] https://i.servimg.com/u/f59/18/59/60/95/bolens10.jpg[/im" border="0" alt=""/>g] | |
| | | MoWheeler Member
| Subject: Re: Bolens Build January 22nd 2015, 9:25 pm | |
| Well the 25hp Intek was worn out, rings had over 1/8" ring gap. using oil like crazy and compression was very low. So I put in a 20hp Intek that I got off of a free MTD I found on the side of the road a couple miles from my house. I drained the oil and it had way too much, smelled really gassy. I took off the shroud and there was the reason for the gassy oil, a mouse nest and a plug wire chewed in two. So they must have use it running on one cylinder for quite some time and the fuel for that cylinder was just washing through the rings.. Put a coil off my 25hp and it runs beautifully, after a carb clean of course. I also ran an addition onto my exhaust. It runs all the way up around the rear fenders. Just a little update, pictures to come. | |
| | | 802 Customs Member
Age : 25 Join date : 2015-01-08 Points : 3759 Posts : 146 Location : Vermont
| Subject: Re: Bolens Build January 22nd 2015, 11:01 pm | |
| How do you find intek v twins left and right? Lol I really want a big cube intek, but I can't find a single one. | |
| | | Carshowkid Member
Age : 25 Join date : 2014-07-22 Points : 4172 Posts : 347 Location : Downers Grove Illinois
| Subject: Re: Bolens Build January 22nd 2015, 11:37 pm | |
| Bud I'm Jelious of how many tractors you have!! Your lucky you live in country... And really cool build!!! | |
| | | MoWheeler Member
| Subject: Re: Bolens Build January 29th 2015, 8:39 pm | |
| - 802 Customs wrote:
- How do you find intek v twins left and right? Lol I really want a big cube intek, but I can't find a single one.
I just get lucky I guess. lol. I only have 2 inteks. and one vanny that is mine. Then two opposed and four singles and an inline twin Suzuki motorcycle engine. Ive come across 3 820s too. kept one, got my cousin one and got my pretty much brother in law one. I just take advantage of a good deal when I can find one. | |
Age : 26 Join date : 2013-11-13 Points : 5447 Posts : 1311 Location : NW USA
| | | | MoWheeler Member
| Subject: Re: Bolens Build January 30th 2015, 10:45 am | |
| He only flipped it that time, ive flipped it twice. haha, Plus we built him ne so he has his own now! | |
| Subject: Re: Bolens Build January 30th 2015, 1:55 pm | |
| Looks good all painted up and everything. | |
| | | MoWheeler Member
| Subject: Re: Bolens Build January 30th 2015, 10:04 pm | |
| Thanks man. I need to take some pictures of it now, it looks so much different. | |
| | | moparjim Member
Age : 37 Join date : 2016-01-16 Points : 3348 Posts : 82 Location : Kent PA
| Subject: Re: Bolens Build January 4th 2017, 2:07 pm | |
| Not gonna lie, but I was searching for a new romper to build and saw your build and liked the Bolens. Then, just so happens my good buddy had the exact same tractor. Naturally, we worked out a deal and I eventually built my own Bolens. You pretty much inspired my build man, thanks. | |
| | | | | Bolens Build | |
| Who is online? | In total there are 28 users online :: 0 Registered, 0 Hidden and 28 Guests
