| Bolens Build | |
+16Craftsman1998 richie thomas Thunderdivine 1997 Murray camomanusa Doc Sprocket Doug Stretch44875 mr.modified TroyBilt Pony LAWN MOWER MUDDER thatrandomguy TheRainbowBoxer redlinemotorsportts willis923 MoWheeler 20 posters |
MoWheeler Member
Age : 29 Join date : 2013-10-31 Points : 4109 Posts : 65 Location : Upper sandusky, Ohio
| Subject: Bolens Build November 1st 2013, 5:20 pm | |
| I recently got a Bolens ST110 for free from a buddy along with another mower that he wants me to help him build. The bolens has a briggs 11 horse flatty but im not sure if it runs yet. It feels like it has low compression as of right now. But that might be just because im used to building high performance high compression engines. lol. Only time will tell. Here are some pictures of my build! | |
willis923 Veteran Member
Age : 28 Join date : 2013-04-10 Points : 5763 Posts : 1408 Location : Galway NY
| Subject: Re: Bolens Build November 1st 2013, 5:52 pm | |
| just a heads up, your pics didnt load. about that compression, my tecumseh flatty on my bolens feels the same way.. idk if it actually does have low compression, but it runs good. thats all i care | |
MoWheeler Member
| Subject: Re: Bolens Build November 1st 2013, 7:46 pm | |
| I cant seem to get my pictures to work? | |
Age : 27 Join date : 2013-03-18 Points : 7485 Posts : 3131 Location : raleigh nc
| Subject: Re: Bolens Build November 1st 2013, 11:32 pm | |
| if youre still having problems, photobucket is easy. thats how i host all my pics. as simple as uploading to PB, then copy and paste the "img" one | |
MoWheeler Member
| Subject: Re: Bolens Build November 2nd 2013, 11:56 am | |
| Thanks I think i got it now! Welded the front axle solid Five inch engine pulley Did the spindle mods so the larger 18 inch tires and rear rims would fit This is what the mower started out as i fixed the pics for ya~willis923
Last edited by MoWheeler on November 2nd 2013, 9:57 pm; edited 3 times in total | |
MoWheeler Member
| Subject: Re: Bolens Build November 2nd 2013, 9:53 pm | |
| [img] [/img]Thanks for the help! This is what it looks like as of right now. Shoupld have more pictures to come tomorrow. Motor has the potential to run some starter fluid so i need to get some of that gold we call gas and hopefully can take it for a test run. It has a 5 inch front pully and a 6 on the back. id imagine that is a pretty good ratio. wont be super fast but wont be gutless either. I plan on puttin a rack on the back of it and a stack or sidepipe. Maybe a snorkel. And a gas pedal. Im leaving the governor hooked up so the engine hopefully last me a long time. | |
MoWheeler Member
| Subject: Re: Bolens Build November 3rd 2013, 8:10 pm | |
| Hey guys here is kind of an update! Put the deck raise/ lower lever as a stack, going to put a larger diameter pipe after the bend so its not such a popping loud and is more of a deep engine sound. The mower sat for 9 years before I got it so a carb clean was needed, It was pretty bad with the varnished gas and the water corrosion in the bowl so i sanded it out. All clean and put a coat of rust paint on the bowl. Had to tak her out for a test run. All is good! Hood just sitting on it test fitting wiht he exaust. | |
TheRainbowBoxer Moderator
Age : 49 Join date : 2012-04-23 Points : 5703 Posts : 1091 Location : Galion, OH
| Subject: Re: Bolens Build November 4th 2013, 8:39 pm | |
| Hey hey! You aren't too far away from Stretch and I (Mansfield area). We should get together sometime and romp, talk shop, etc. | |
MoWheeler Member
| Subject: Re: Bolens Build November 4th 2013, 10:23 pm | |
| That would be awesome! Its about an hour or so from here. once i get mine dont we might have to do that ! | |
thatrandomguy Member
Age : 27 Join date : 2012-03-28 Points : 4695 Posts : 56 Location : netherlands
| Subject: Re: Bolens Build November 6th 2013, 5:38 pm | |
| i have the same tractor. those 11 hp briggs have a habbit of losing compression. the cause is the cylinder wearing out. | |
MoWheeler Member
| Subject: Re: Bolens Build November 6th 2013, 5:53 pm | |
| UPDATE! I built my gas pedal from a dirtbike brake lever that was broken. It kind of worked but my foot couldnt really get enough leverage on it to push it easy. " /> So i drilled two 1/4inch holes in it and welded in two bolts that i cut the heads off to a steel pedal and bolted it to the lever. Works way better. Also added a return spring that ended up being too strong. " /> Then I took off the original small stack and cut it after the 90 degree bend. Then i sut 4 slit into the end of a pipe thats like 1 1/2" and smacked the ends with a hammer until it fit pight on the smaller pipe and welded it all solid. Then I cut another piece with two angles and welded it on to pint out like a tractor. Sounds better and redirects the exhast from my face. lol " /> Also installed my hood and stuff! " /> | |
MoWheeler Member
| Subject: Re: Bolens Build November 6th 2013, 5:58 pm | |
| - thatrandomguy wrote:
- i have the same tractor. those 11 hp briggs have a habbit of losing compression. the cause is the cylinder wearing out.
It seems to run really super strong. I think i was just used to my perforamance flathead that I have and nout used to a stock one. lol | |
MoWheeler Member
Age : 23 Join date : 2013-04-08 Points : 5211 Posts : 913 Location : Central Pa
| Subject: Re: Bolens Build November 14th 2013, 4:26 pm | |
| Dude that's TOTALLY RAD you took that thing from looking so small and wimpy looking to something big and AWESOME looking! | |
| Subject: Re: Bolens Build November 14th 2013, 6:56 pm | |
| that thing is *exploitive* AWSOME! thats some pretty slick welding on the hub. FCAW? or GMAW? i really like it.. gotta get some atv tires on it now, even ags | |
Join date : 2013-06-01 Points : 4812 Posts : 578 Location : West Virginia
| Subject: Re: Bolens Build November 14th 2013, 6:57 pm | |
| Love the MTD seat.. round here we call that seat the fat man chair.. lol The one ranch king had flexed back like a recliner... | |
MoWheeler Member
| Subject: Re: Bolens Build November 14th 2013, 9:19 pm | |
| Thanks man. Its a hell of a tractor. Still have plans for a rack on the back and bumpers front and back. maybe swapping in an 18 hp oppy i have. who knows! | |
MoWheeler Member
| Subject: Re: Bolens Build November 14th 2013, 9:21 pm | |
| - willis923 wrote:
- that thing is *exploitive* AWSOME! thats some pretty slick welding on the hub. FCAW? or GMAW? i really like it.. gotta get some atv tires on it now, even ags
Well i was gonna keep it a secret, but i have a set of ags in my garage ready to go on! And honestly I have no clue about the welder. its just a 90 amp flux core from harbor freight. | |
| Subject: Re: Bolens Build November 14th 2013, 9:33 pm | |
| i love it.. and btw, FCAW= flux core arc welding, GMAW= gas metal arc welding (mig) | |
MoWheeler Member
| Subject: Re: Bolens Build November 15th 2013, 7:06 pm | |
| Welp boys now I did it.. Fudged the tranny ups! Input shaft was all dickered up and some of the theeth on other gearsa were chewed up so i took a geatset out os a 930 and swaped em in plus the bevel gear. The input shaft needs to be shimmed to make contact with the bevel gear but i put it back together and mounted it before I noticed I forgot to do so. I just left her there for the night gonna fix her tomorrow after I put a slave cylinder and radius arm bushings on dads truck..
MoWheeler Member
| Subject: Re: Bolens Build November 20th 2013, 9:25 pm | |
| Well guys Im back on the build.. Painted my rim gloss black, not that youll be able to see it very long. Also was testing some stuff and made a glasspack style muffler for it.. Drilled a bunch of holes in my exaust pipe. ( 1.5 inch or so) Then bent the holes so they kinda grab the exhaust flow Then wrapped the holes with steel wool and slit 2 brake cleaner cans over the steel wool with an interferance fit. I then installed it to my exhaust in place of a straight pipe. Makes a huge difference. I also coated it with some silver paint. Dont have a picture yet it gets dark to dang early.. | |
| Subject: Re: Bolens Build November 20th 2013, 9:39 pm | |
| Cool glass pack. i hope it works out for you. i saw someone take a screwdriver to each of those holes and bend the screw drivder over, so the holes had little holes to pick up the air flow better, like little scoops
MoWheeler Member
| Subject: Re: Bolens Build November 20th 2013, 9:44 pm | |
- Cool glass pack. i hope it works out for you. i saw someone take a screwdriver to each of those holes and bend the screw drivder over, so the holes had little holes to pick up the air flow better, like little scoops
Yeah thats what i meant when i said i bent the holes to trap the exhaust flow. it works great. | |
| Subject: Re: Bolens Build November 21st 2013, 10:21 am | |
| - MoWheeler wrote:
Yeah thats what i meant when i said i bent the holes to trap the exhaust flow. it works great. Oh, I didn't notice my bad lol. | |
| Bolens Build | |
