 What kinda fuel do you use?
CornishMorgan
crafsmankiller
Trcustoms
9 posters
Trcustoms
Trcustoms
What kinda fuel do you use? Empty
PostSubject: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeSeptember 20th 2010, 3:03 pm
What octane fuel do you use?
Has any one ever used E85?
E85 is 85 octane rite?
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeSeptember 20th 2010, 3:28 pm
Ive used some high test in my murray, plus 104 octane boost- i really didnt see a difference to be honest- all my other tractors get normal plain old low test.
Heres what wikipedia has to say about E85 :
http://en.wikipedia.org/wiki/E85
Trcustoms
Trcustoms
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeSeptember 20th 2010, 3:44 pm
In some cases it's better for racing engines but either then that it sucks!
crafsmankiller
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 8th 2013, 4:09 pm
i have a friend thats into jet boat racing, he uses a EXTREMELY MODIFIED chevy small block, thing has like thing has a hellovalot of compression,he said that higher octane fuel in a engine designed to run low octane doesnt do anything performance wise, it only works if it has high compression.
high octane+high compression=high power
high octane+low compression=same power
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 8th 2013, 5:08 pm
The above observations are correct. The reason hi test is better in (and sometimes required for) high performance engines is that higher octane fuel is more stable. It does not ignite as easily under compression + heat. With higher compression engines, the lower octane fuel, which is more volatile, tends to ignite prematurely, which is counterproductive and not very nice to your engine.
Chaos Build
Check out the pics and vids!
Haspin 2021 thread
Haspin Acres Rally 2022!
TheRainbowBoxer on YouTube
CornishMorgan
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 8th 2013, 6:22 pm
I just use normal 95 octane unleaded petrol from my local filling station. I normally put a few drops of Redex to keep it fuel system clean as well.
W1ldyOvvnZ
W1ldyOvvnZ
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 8th 2013, 7:59 pm
I run High Octane(the highest octane within 46km) which is 91 Octane, then 47km away they have 110 Octane, not worth trying to run in my engines, unless im putting it in my fathers sled but im not going to pay $5 a litre for the stuff.
http://www.stat10.tk/
Chopperhed
Chopperhed
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 8th 2013, 10:37 pm
High octane in a low compression engine is a waste of money.
You don't need it for anything less than 11:1 comrpression ratio.
However, Superchargers and Turbochargers need it as well, engines with modified timings sometimes need it.
I don't like paying 4.50 a gallon for 95 octane for the boat but I have to. Its timed so tight that any thing less will detonate it to death.. 110 avgas is out of the question. It works good in cessnas but i can't afford it. plus i think its still leaded.
To be honest, i don't like payin 4 bucks a gallon for 85 octane, but I have to.
Marines2621
Marines2621
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 9th 2013, 12:16 am
I run racing fuel plus methanol or alcohol how ever u put it mixed and get gas and mix. That gives some power to my opposed
CornishMorgan
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 9th 2013, 5:00 am
95 is the lowest I can get, Its either 95 or 98 so I don't really have a choice.
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeJanuary 9th 2013, 4:06 pm
Heres something to be aware of with today's gas - if its left in the tractor/carb - it can either corrode or build up gunk in the carb - specially if its sat around a while.
Last year i was going thru my mowing tractor's maintenence ( used once a week during season, once a month during winter) , and was giving some a regular cleaning - noticed a whole lot of 'gunk' in the float bowl - keep in mind i shut the fuel off and let the carb drain out every time , and it still left stuff in the carb. I also was adding fuel stabilizer to the gas can and or gas tank. This year ive drained the gas completely out of the tractors before winter - ill see how things look.
Its probably has to do with high ethanol content, which can draw moisture as well - possibly adding a dry gas would help.
PostSubject: Re: What kinda fuel do you use?   What kinda fuel do you use? Icon_minitimeSeptember 3rd 2013, 10:17 pm
i run 89 octane most of the time, 93 if i have money i dont know what to do with. BTW, E85 is NOT 85 octane. its 85% ethanol. run it through your mower and youll be looking for a new engine
» what kinda oil do you use in your tranny?
» Bet you've never had this kinda engine issues
» Who runs metal fuel lines?
» DIY 30$ electronic fuel injection
